  • August 02, 2025, 07:56:32 AM
Author Topic: APC 12x4.5 MRP Pusher-Any tried them?  (Read 1448 times)
Online Paul Taylor
« on: May 29, 2014, 08:41:49 PM »
Has anyone tried the multi rotor pushers?
APC 12x4.5?
Offline Crist Rigotti
Re: APC 12x4.5 MRP Pusher-Any tried them?
« Reply #1 on: May 29, 2014, 08:47:23 PM »
I haven't, but I'm thinking the pitch is too low.
« Reply #2 on: May 29, 2014, 08:59:20 PM »
DON'T! The APC multi rotor props are not usable (for most aircraft) because of lower structural limits & lower rated RPM capability
The 12" multi rotor props have a lower max speed rating than the normal electric props  The max RPM for the 12" Multi rotor prop is only 8,750 RPM.  The 12" Electric props are rated for a max of 12,083 RPM.   If you would like to try the math yourself check-out:
http://www.apcprop.com/v/html/rpm_limits.html
If you want to try a 12x4.5, take a 13x4.5EP and clip it to 12", try at around 9800 RPM - should be close.
Online Paul Taylor
« Reply #3 on: May 29, 2014, 09:54:57 PM »
Wow Guys!
This thread was a life saver!
I just got one and was going to give it a spin. Just thought I would ask as I did not know if I might have found a lower pitch prop that was new. Most people seem to be running higher pitch props.
Maybe this is why?
Thanks again!
« Reply #4 on: May 30, 2014, 06:02:06 AM »
If/when you get your new PAMPA Stunt News, I did an article that discussed prop speeds, Governor Range, Motor KV & Cell Counts.  There's a chart there that shows most all of the APC Pushers & their max rated speeds.
The 12x6 EP is a (roughly) 8600 RPM prop, the 12x4.5 (clipped from a 13" is a 9800 RPM or so prop.  If you are looking for higher RPM than that then not sure where you will find it.
