Electric Stunt => Gettin all AMP'ed up! => Topic started by: JohnPrator on February 15, 2011, 10:39:28 AM
Title: Anyone tried the Scorpion ESC's?
Post by: JohnPrator on February 15, 2011, 10:39:28 AM
I know the Ice Lite is a great ESC but since I bought a Scorpion motor I'm sure eyeballing their ESC's, anyone here tried one? If so what are your thoughts? I'm not really too interested in data logging so that feature on the Ice isn't attractive to me at all. The price on the Scorpion seems attractive especially since it comes with the wireless programmer, here's the one I was looking at; http://www.innov8tivedesigns.com/product_info.php?cPath=22_24_71&products_id=376 (http://www.innov8tivedesigns.com/product_info.php?cPath=22_24_71&products_id=376)
Thank you!
Title: Re: Anyone tried the Scorpion ESC's?
Post by: WhittleN on February 15, 2011, 12:14:18 PM
I don't know what kind of flying you do (stunt/sport) but most ESC's don't have a brake for the prop in the Helicopter mode.  So if you are happy to land really quick after the motor stops this would work.  Also Will Hubin's timer chips can’t tolerate more than 5.5 VDC max.  This ESC has a linear voltage BEC regulator that puts out 6 VDC - this might be a problem.  Also if you are using more than a 3 cell pack, then you need to disable the BEC and install an external one.  The Good news it does come with a programmer and is about $10 cheaper than the ICE ESC. But add another few bucks for a BEC and your back at the cost of the ICE.  BTW -I don’t sell ESC’s or get paid to sell them just been there done that and gotten the t-shirt.
Regards
Norm
Post by: Wynn Robins on February 15, 2011, 12:31:24 PM
have to agree with Norm
stick with what works - there is a reason most of us (no flaming here) use the Castle ESCs......
for the sake of $10 - it is not worth the hassle to go with an unproven concept/equipment
Post by: JohnPrator on February 15, 2011, 02:47:09 PM
Thank you both for the help, took your advice and just stuck with what works. Got the Ice Lite 50 and programmer, by the way this place has them for a good price; http://www.bphobbies.com/view.asp?id=V815101 (http://www.bphobbies.com/view.asp?id=V815101) You have to "make an offer" but got them both for $99.
Thanks again Gentlmen!
Post by: WhittleN on February 15, 2011, 04:49:20 PM
Good John
Do you mean the Castle Ice 50 Lite and the Castle Field Programer?  If so that is a very good deal.
Norm
Post by: Keith Renecle on February 16, 2011, 05:40:16 AM
Hi John,
I have one of the Scorpion 55 amp heli esc's like the one you reffered to. It is a great esc and has a very smooth throttle response as well. The governor is very solid, but it is designed for heli's and as Norm says the BEC voltage is too high for the PIC chips in the timers. I also found that it runs up to a different rpm each time that seems to be related to the state of the battery. Once it gets there, it is rock solid, but this means that every time you want to fly, you will have to set the rpm just before launching. My timer output was always the same but the rpm that it locked onto was different by around 200 to 300 rpm.
My governor timer with a basic Hobbywing esc works a lot better anyway. Yesterday I tested my system with a ZTW esc that also has a governor like the Scorpion, but once again the governor is aimed at the 3-D heli business. I must say however that the ZTW also has a very smooth throttle response and worked very well with my governor timer. The price is about the same as the Hobbywing as well, around $42.00, so I reckon that I'll do some more serious testing with the ZTW. The 60 amp version looked to me like it could only handle 40 amps, (it's very compact)so I let it run for a few minutes statically on my MVVS 6,5/910 motor with the APC 12 x 6 prop. I used an R/C system to run it with a current draw of 50 amps for a few minutes and it was running slightly warm and not hot. I'm now going to fly it and see how it works out, then I'll report back to this forum.
Keith R
Post by: WhittleN on February 16, 2011, 08:43:03 AM
Have you thought about putting together a list of recommended ESC’s that are inexpensive and are ideal candidates to be a good match for your Timer/Governor?  The $75 dollar ESC that is the subject of this thread probably isn’t a good cost effective candidate for your equipment.  I know C/L flyers are always looking for a low cost solution; especially the ones that want to try electric but are scared off by the investment commitment for the very top of the line electric equipment.  I considered the ICE Lite 50 and AXI motor a lower cost solution vs. the Plettenberg and Schulze ESC - that is why I wrote the “Cookbook”.   I think there is even a lower cost “crowd” that are eager to enter the Electric Airplane Group
Norm
Post by: Dean Pappas on February 16, 2011, 03:26:52 PM
Hi All,
From Keith's post # 109
"I also found that it runs up to a different rpm each time that seems to be related to the state of the battery. Once it gets there, it is rock solid, but this means that every time you want to fly, you will have to set the rpm just before launching. My timer output was always the same but the rpm that it locked onto was different by around 200 to 300 rpm. "
Man! That disqualifies this ESC to my mind unless you are going to impose external control as Keith does with his new controller.
Dean P.
Post by: Keith Renecle on February 16, 2011, 09:54:40 PM
Norm
Thanks for the suggestion Norm, I have been building up a list of what works well, and a year ago my software would not work with some of the cheaper esc's that had a coarse throttle response. Now it is much better. The Scorpion was very smooth but somehow there was a delay, and also caused some hunting. Maybe their compensation is too smooth? My software is much better now, and works with most esc's that I've tested. The real problem in using the Scorpion for C/L with some of the available timers is that 6 volts BEC output to power the timer. Other than that it is a great esc.....for R/C.
To be cost effective I worked with the Hobbywing esc's that gave very good performance for the price. I believe that most of the Turnigy's, like the Plush series are also Hobbywings. Now it looks like the ZTW is also a good deal, and I'm going to do some serious flight testing shortly. Both of these esc's have cheap programming cards to set the timing and brake functions, so this is nice.
I've found that the E-Max/Arrowind motors are very good value for money. The 2820 is the .40 glow replacement and I'm now using a 2826 for the .50 to .60 size models. My test motors take some serious hammering, and so far I have not managed to burn out or break any E-Max motors. There are many other good motors at reasonable prices, so in the near future, I will indeed build up a data base of good combinations.
I've had a very good response in selling my timer now, and I've actually sold out! I did order more pc boards etc. a while ago, so I'll catch up within a week or two. I was rather overwhelmed in fact at the interest, so I guess you're dead right when you said "I think there is even a lower cost “crowd” that are eager to enter the Electric Airplane Group."
I'm getting some good feedback now especially with some "not-so-clear" stuff in my instructions, so this will help me to make it even better. Sometimes what I think is dead simple is not really that simple to figure, because I designed it, I know how it functions. Writing clear, concise instructions is difficult, especially for someone like me that tends to waffle on a bit. Thanks to the guys that have helped with this so far.
Keith R
Post by: JohnPrator on February 17, 2011, 06:10:21 AM
Good John
Norm
Hi Norm,
Yes sir, got both of em for that price. Haven't ordered from them before but they were very responsive and shipped quickly so I'm a happy camper! If you note on their site they have an "Make us an offer" link, the lowest price they'll take for the ESC is $76.46 and $22.91 for the field programmer. If you put these amounts in each box it will automatically accept your offer. Pop em in your cart and check out, pretty cool.
Hi John,
"snip"
Keith R
Keith,
Thank you for all the info, much appreciated. As you probably saw I went ahead and bought the Castle ESC/Programmer, but, I didn't realize you made timers/governors. They look nice, wouldn't mind giving one of those babies a go! Where can I find those babies? Are they simple to operate/program-for those of us who are simple minded? ;D
Post by: Keith Renecle on February 17, 2011, 09:04:49 AM
Hi Norm,
Keith,
Hi John,
I posted the story on a recent htread below called "KR Governor Timer now available". There is a direct link to my site at http://www.keithrenecle.co.za/Electric%20CL.htm
I received a few from the pc board guys from my previous order where they had some crystal problems, so I have about 8 with me again. As I said above, I have a bigger order in already but this may take a week or two.
You asked if they are simple to operate? I think so, but there have been a few customers that got rather confused. It's simple for me, but then I designed it and wrote the software. I have had some real good suggestions and now when I read my instructions I can see the point. This is fixed now, and maybe I'll even make a short video and stick it on You Tube or something. It's not complicated and you don't need any pc to do it. So if you need one then just let me know. Thanks.
Keith R
Post by: Mike Anderson on February 17, 2011, 10:00:18 AM
Hi John,
Keith R
I've had a chance to begin working with one of Keith's timers - here is how I would  characterize it:
If you are familiar with the z-tron, JMP, and Will Hubin's original and FM-9 timers, I would order them in "Simplicity" as
1- Hubin original (pot adjustments)
2- FM-9/programming box
3- JMP
4- z-tron
I would put Keith's KR-1/Programming module at #2 - not quite as simple as twiddling pots, but slightly easier than Will's FM-9 - although for making adjustments AT THE FIELD - perhaps the FM-9 might be slightly less hassle than than the KR-1 -- mainly because to adjust the RPM, the KR-1 actually runs the motor where the FM-9 just asks for a new value.  I am not including the Castle(s) with whatever timer because I don't have a field programming capability for mine, so it is off the scale at the bottom for "ease of use".
Note also, that I am not commenting on how well or how effectively any of the above do the job they were designed to do, only on how easy it is to learn, use and adjust the various parameters offered.  I have used all of the above, including the Castle Phoenix and it's software.
I did not have any problems with the written instructions but another guy here in the club mentioned a 'typo' that hung him up, briefly.  I don't know exactly what it was, but could find out if needed.
I would suggest that initial running/adjusting of the KR-1 be done with the prop removed and perhaps, from a safety standpoint one should make that one's normal procedure anyway.  If that is too much hassle, though, at least have a help holding the plane while making field adjustments.
I'm looking forward to getting out to the field and doing some head-to-head comparisons of the flight characteristics of the Phoenix 45 vs. KR-1/Cheapo45, as soon as our weather/field conditions permit.
Post by: Keith Renecle on February 17, 2011, 12:03:06 PM
Thanks Mike,
When I made my governor timer, I tried to make it work close to that of setting a normal glow engine where you would get someone to hold the model and tweak the needle valve watching the tach, so this is always a good idea. Safety first! You will however need something for the tach to work on, even if it's a small prop. Because it is an external governor that is using the throttle pulse width to add or subtract power, it will work better if there is a load on the motor otherwise the throttle pulse will be very low and the motor way out of its best operating torque.
If you don't have a tach, then try it at the default setting, and if it's too slow or too fast then simply set a low flying time, and adjust it a few clicks either way until it flies at the required speed. This is very similar to the way we set our glow engines without tachs. The real difference is that the glow engine will have an extremely narrow rpm range where it works well, and then you'll have to play with props, pitches, head shims, venturi's, nitro etc. etc. With electric, there is also a "happy band" but it's a lot wider and more tolerant as well. For example, if you have a certain speed with a particular prop and battery, and it's flying at the required speed, but the throttle setting is only 50%, then this is not a good, efficient system for the motor and esc. A good setting will be near max with enough power left in the battery at the end of the flight for the governor to still work. Typically after a flight I check my throttle pulse width and it is around 85% of the maximum pulse width. At the end of my flight time, I make the motor go about 25% slower for 2 seconds and then I give full throttle for a few more seconds to give some nice speed for lining up a good F2B type of landing. If it doesn't go much faster, then you'll know that you're getting near to the point of using too much battery, so you'll need to back off the rpm a little. The more tha this system is used, the clearer it will become, and id there is something that needs to be changed then I'll always do my best to do this.
Keith R
