  • June 14, 2025, 01:17:56 PM
Author Topic: Two Profile kits for Electric  (Read 762 times)
Offline pat king
    • PDK LLC
« on: August 14, 2011, 03:54:44 PM »
I have two laser cut kits available for elecrtic or fuel power. The kits have parts and plans to build them either way. The plans have full size templates for all the parts. One is the Ringmaster 150, 26 1/4" wingspan- 150 square inches. The other is the Ringmaster Jr., 30" wingspan- 196 square inches. y1
Thanks,  Pat
Pat King
Monee, IL
AMA 168941
Re: Two Profile kits for Electric
« Reply #1 on: August 14, 2011, 06:54:21 PM »
YEAH MAN Keep them electric kits coming!!!
THANKS Pat!
Offline chuck_b24
« Reply #2 on: August 18, 2011, 06:41:42 PM »
bigger pat!!!! BIGGER PAT!!! PLEASE!!
Offline pat king
    • PDK LLC
« Reply #3 on: August 19, 2011, 10:30:55 AM »
Chuck,
How big do you want? I can do the extra plan sheets to build the Ringmaster Bipe II or the Ringmaster Tri 45 to be electric. The Bipe II is a 41 5/8 span 413 sq. inch biplane for .29 to .40 size glow. The Tri 45 is a 41 5/8 span 642 sq. inch triplane for .45 to .53 glow. I have one each in stock. Let me know if you want one of either or both with the plans and pieces to go electric.The multi wing airplanes are easy because a wing doesn't have to be changed to accomodate the battery.
I can do the design work to make almost any of my kits as an electric powered airplane. y1
Thanks,  Pat
Pat King
Monee, IL
AMA 168941
