  • June 25, 2025, 03:26:10 AM
Author Topic: Charger power supply question  (Read 4871 times)
« on: January 09, 2015, 04:17:56 PM »
OK, I know this must have been asked before, but I can't find what I'm looking for in the search function.
If I have a I306b charger, how many watts do I need in a power supply to charge 4 batteries at once? Figure 5S or 6S 2700 to 3000mah batteries at 25 or 35C.
Offline William DeMauro
Re: Charger power supply question
« Reply #1 on: January 09, 2015, 05:31:09 PM »
This is just a rough estimate from experience. I have a 306b and if I remember right it pulls about 22-25 amps from a 24V server supply to charge 4s batteries at 30 amps. To charge a 5s battery at the full power of the charger would probably take 27-30 amps out of the 24v power supply. I suspect if I did the math my numbers are on the high side. I always like to have some head room anyway. The number of batteries does not matter as long as you don't exceed the manufactures charging rate for the battery. For example if you are charging a 4s 3000mah battery that can be charged at 5c max, you can charge that battery at 15 amps max for one battery (5x3=15)or 30 amps for 2 batteries in parallel After 2 batteries you are exceeding the charger max and your rate of charge just slows down. Pile as many on as you like your charging rate just slows down proportionally. I am using a 24v 75 amp power supply so I cant even come close to the limits of my power supply even while using my PL 8 and 306b at full power 70 amps output (40+30) or about a 50amp draw from the power supply charging 12 4s batteries at the same time. With this set up I sometimes pop the breakers in my house.
AMA 98010
Offline Fred Underwood
« Reply #2 on: January 09, 2015, 05:36:22 PM »
Though for Powerlab chargers, this calculator also is useful.
http://www.revolectrix.com/PL6_calculators_Main.htm
You can vary 12v or 24v input.  What power supply are you using?  If none yet, these are easy to convert
http://www.ebay.com/itm/Lot-of-2-HP-Proliant-DL580-G5-438202-002-DPS-1200FB-1200W-Power-Supply-/291285365649?pt=US_Server_Power_Supplies&hash=item43d1f5f391
« Last Edit: January 09, 2015, 05:55:10 PM by Fred Underwood »
Fred
352575
« Reply #3 on: January 09, 2015, 05:44:08 PM »
I am using the ones that Fred linked too. They are small and work great!!!
AMA 98010
« Reply #4 on: January 09, 2015, 05:49:40 PM »
For the DPS 1200 noted, here is step by step conversion.  Fairly easy to do.
http://www.rchelination.com/setting-hp-dps-1200fb-power-supply/
Fred
352575
« Reply #5 on: January 10, 2015, 12:05:35 AM »
Well, I was looking at a 600W power supply and was just wondering if that was enough.
« Reply #6 on: January 10, 2015, 02:56:19 AM »
Can you link, or post a picture, to what power supply you are looking at? The DPS 600pb is rated at 47 amps 585 watts and also works great. I was able to run the PL 8 and the 306b up to full power together to charge 4 cell packs in a 24v configuration. Even though they were rated at 47 amps, I tried a few times to try to cause one to fail just to see the limits. I pushed it as high as 53 amps and never had a failure. Are you running a 12V power supply or 24v?  If you are running 12V you most likely will NOT be able to max the 306b out. Your wires will also get really hot. By the way, if this is a PC power supply most are WAY OVERATED and NEVER put out even close to what they claim they do. I've experimented with a few pulls and even at FREE they are not worth my time to make up. So I guess to specifically answer your question, I still need a little more info on exactly what power supply you are looking at. I need to know more than just the watts. Volts, and Amps rating need to be factored in.
AMA 98010
Online Howard Rush
« Reply #7 on: January 10, 2015, 03:33:57 AM »
Me, too, on Will's recommendation.  I got 5 for $70.  Did you get in on that deal?
Offline John Rist
« Reply #8 on: January 10, 2015, 09:30:34 AM »
Not as cheep as the computer supply but easy to use.  Pick your size and pay the price.  Low of $5 high of $100.
http://www.ebay.com/itm/Universal-12-24V-2-3-5-10-15-20-30A-Switching-Power-Supply-Driver-For-LED-Strip-/400766807980?pt=US_Lighting_Parts_and_Accessories&var=&hash=item5d4f902fac
12V or 24V models.  I am a low end user and one of the 12V models works for me.
« Reply #9 on: January 10, 2015, 11:22:29 AM »
Again, the calculator will help, noting what you can expect out of a power supply at its rated voltage and amperage.
Fred
352575
Online Howard Rush
« Reply #11 on: January 10, 2015, 07:56:39 PM »
Get a refurbed server power supply and use the difference for gas money for the Nats.
« Reply #12 on: January 10, 2015, 08:04:42 PM »
If I understand correctly you want to charge 4 battery packs in parallel.  If you mean that the listed discharge rate is 25C - 35C burst, that does not specify the charge rate. I have Zippy Compact 2700 mah, and IIRC, you had some of those. The site says 5c for charge, but I don't go over 2C for those. Some of the 60C discharge batteries might tolerate 5c charge.
If you use 80%, about 2000 mah, then at a 5 amp charge rate, 2C being 5400 mah or 5.4 amp, you can put in 2000 ma replacement in about 30 minutes allowing for slowing at the end. That means 20 amp output into 4 packs parallel, 5 amp or 2C/pack.
If that makes some sense, then your setup should work fine, i306 and 18V 60 amp charger. Perhaps more at limit if 6 packs and 30 amps output needed, or 4 packs at 7.5 amps or about 2.5C.  Also, you may get close to the limit with 4 packs of 6 cells.  The charger output and/or input limit can control that.  The reason for higher voltage is to get more watts into the charger below its amperage input limit.  I could not see an input amperage limit for the i306b.  I recently searched before getting a PL8.
Sorry if this is overly wordy and perhaps too simplistic at the same time.
« Last Edit: January 10, 2015, 08:27:30 PM by Fred Underwood »
Fred
352575
« Reply #13 on: January 10, 2015, 10:50:14 PM »
Thanks, Fred. This was mostly that I bought a I306B charger and wasn't sure how much power supply I needed to charge 4 5S 35C 2700mah batteries at a time.
« Reply #14 on: January 11, 2015, 06:20:50 AM »
This is a DPS 1200 that I recently made up for someone this puts out 24V 1800 watts which exceeds the capabilities of your charger and is way more powerful than that Hobby King Power Supply you linked to.
« Last Edit: January 12, 2015, 01:31:38 AM by William DeMauro »
AMA 98010
« Reply #15 on: January 12, 2015, 10:38:36 AM »
OK. I think I've got an idea now. I'll find something. I can see the parameters now.
« Reply #16 on: March 03, 2015, 03:23:47 PM »
Just to follow up. I ended up getting a PRC600 power supply to go with the iCharger 306b. Seems to work OK.
