This is what I do: I bring the airplane to the circle, set up my lines, walk back to the airplane. Battery has been pre-installed and the arming switch is out.
my assistant holds the airplane, and I plug in the arming switch to activate the electronics. the ESC gives back a series of audible chirps to indicate
that everything is ready to go. I listen carefully to those audible tones. if I forgot to plug in the ESC to my FM-9 timer, the last tone is missing, indicating
that I messed up last time I made an rpm adjustment, and forgot to re-connect the ESC to the timer, or something else is askew. I can stop now,
go back to the pits and troubleshoot the problem, and not be charged for an attempt. If everything is OK, I signal the judges, they start the clock, I push the button to
start ignition sequence, and walk to my handle (do not run). I allowed 30 seconds on the timer to do this. Once I get to my handle and am ready, I signal
my assistant to back away from the model. I wait for the prop to turn, and begin my pattern. I like the model alone on the field during takeoff as
I think it looks more realistic.
