CLICK HERE--><--CLICK HERE
Amp draw in climb - anyone measure it?
Started by Dennis Toth, October 24, 2026, 05:31:31 AM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Dennis Toth
Just wondering if anyone has measured the difference in Amp draw between level flight and going into the climb part of the wingover? The some of the Castle Creation ESC's had a data link that would record this. Knowing this would give an idea of how much headroom we need when selecting an ESC size that may allow us to save a small but significant amount of weight on smaller ships.
Best,   DennisT
Bob Hudak
#1
Flying my profile version of the Legacy 40. Weighs 57 oz. w/battery, on 62' lines,using a Cobra 2826/12 760kv motor,Thunderpower 5s(18.5 v) 2800mah lipo, 11 1/2"x6 APCEP F2B prop,Castle ICE 50 ESC, Hubin FM9 timer. Recorded data says 19.7 amps avg.,26.8 amps max, 373 watts avg.,543 watts max. Power output as a percentage is 71.4% avg. and  80.8% max.
350838
Paul Taylor
I have data logs too but won't be able to read it until tomorrow.
Just curious why do you ask?
My Therapy involves Balsa wood and bad decisions.                               https://www.wpmpa.com
Everyone becomes a memory. The question is: will you be a good one or a bad one?
Kindness echoes. So does cruelty. People remember both.
Brent Williams
Yes, the amp draw goes up significantly during the climbs, and then it goes down significantly during the dives.
Mike Alimov
Dennis, if you want a generic guideline, the answer is going to be.. It depends.
The exact ESC current rating for a particular powertrain setup depends on several factors: (a) size and weight of the airplane, and other things that contribute to drag (wires/battery sticking out, etc); (b) your preferred propeller (the same plane can be flown with different props; your choice is determined by your preference and budget); (c) how you chose to deliver the power - high voltage/low current or low voltage/ high current (power = voltage*current).
I am attaching data from my electrified Legacy ARF.
Look at it carefully and compare to Brent's data (not meant as a knock on his setup - this is strictly for engineering comparison purposes).
Brent is spinning a 11-6" prop using a 3S 5000 mAh battery, and is averaging 33 A in level flight, with peaks close to 50A during maneuvers.  We don't know the size and weight of his airplane - maybe he will share this data.
My Legacy, which comes in at ~ 61 oz, and is propelled by a 3-blade 12-6" prop using a 6S 2200 mAh LiIon battery, is averaging 24 A in level flight, peaking close to 45 A in maneuvers.
This shows the advantages of running a high voltage setup - it uses lower current, and therefore you can run a smaller and lighter ESC, and thermal losses (which grow as a square of current, I^2*r) are smaller too.
Now, specifics: for most 600-660 in^2 sized ships in the low-to-mid 60 oz range, I have been using Castle Talon 35. Yes, I know that it sees short current spikes up to 40-45 A.  I spoke to Castle tech support about it, and they confirmed something I have myself known from my semiconductor work: power transistors in the ESC inverter circuit can withstand occasional current spikes above its nominal rating, likely up to 50% more than nominal.  My experience shows that after hundreds of flights, the Talon 35 keeps working just fine.  I think it's one of the lightest ESCs on the market at this current rating.
Since you mentioned smaller ships, it is possible that you could step down to a Talon 25, but without knowing the rest of the airplane and prop- / battery parameters, it is hard to be certain.
One way to be certain is to install a Castle Edge Lite 50, and collect data (just as Brent and I did) to see what currents your setup is consuming. Then swap the Edge Lite for the smallest/lightest suitable ESC from the Talon line.
Agree Agree x 1 View List
Brent Williams
My setup is a 50oz Pathfinder.  I'm running it with a bit different setup than most. 3s5000 Li-ion packs(8.5oz) and a Badass 2820-1350kv.  Reason?  I just wanted to scratch the theoretical itch and see what the outer limits are for these cells.  Modern 21700 cells like Molicel p50b and Eve 40PpL and 50PL are very capable.  It runs great, but ymmv. Checking the landing voltage per cell is usually around 3.58v with a Badass 12x6 at 9330rpm and 3.6v'ish on 11x6 at 9500.  On 3s, the amp swing does look pretty dramatic on the graph.
Ken Culbertson
Quote from: Brent Williams on October 29, 2026, 01:52:03 AMMy setup is a 50oz Pathfinder.  I'm running it with a bit different setup than most. 3s5000 Li-ion packs(8.5oz) and a Badass 2820-1350kv.  Reason?  I just wanted to scratch the theoretical itch and see what the outer limits are for these cells.  Modern 21700 cells like Molicel p50b and Eve 40PpL and 50PL are very capable.  It runs great, but ymmv. Checking the landing voltage per cell is usually around 3.58v with a Badass 12x6 at 9330rpm and 3.6v'ish on 11x6 at 9500.  On 3s, the amp swing does look pretty dramatic on the graph.
Are you using a smaller ESC?  There are lots of "cheap" options 4s and under that are quite light.  Cheap has two meanings and I include both of them!  I have been toying with lower "s" values.  Haven't gone under 4 yet.  I am running my twin on a 5s p50b 4200.  Twin 2820-970s.  12-6 on a 3s?  Atts a lotta prop!
Bill Schluckbier
I started flying electrics back in 2005 just as the transition from NiMh batteries to lipos was getting started.  At the time there was a lot of discussion comparing low voltage/high current setups vs. high voltage/low current setups.  In the end most came to realize that the high voltage/low current set-ups were generally more efficient as well as being somewhat lighter.  This is the approach that I favor.
It seems that the Legacy 40 is a popular design and I am going to provide a quick summary of the setup I use on mine:
Legacy 40:
RTF weight :  54 oz
Motor         : Sunny Sky 2820 570Kv
ESC             : Castle Talon 35, set-up to run in governor mode
Timer          : Hubin
Battery        : TP 2200 mah, 6S (25.2 volts)
Prop            : Xoar 13x5 (yes, on a .40 sized model)
RPM            : 9260
Line length  : 62' (probably 67.5' from the top of my head to the fuselage centerline)
Lap time      : 5.55 sec (relatively slow)
The motor run time is of about 5 minutes and 10 seconds and after a flight I normally put about 1400 mah back into the pack. Based on the run time I can do a quick estimate of the average current draw:
Current = (mah used/motor run time(sec))x3.6
             = (1400/310)x3.6 = 16.25 amps
Before switching over to the 35 amp ESC the model had a 50 amp ESC with data logging.  In level flight the average draw was in the 14.5 amp range with peaks approaching 25 amps while maneuvering.  The values are well withing what the 35 amp ESC can handle.
The one thing that I do differently relative to what Mike posted is that the current limit setting for the ESC is set to sensitive. This means that the ESC will shut down at a current slightly above 35 amps. I do this because we fly off grass and if I have a prop strike the motor will shutdown without causing any permanent damage.
I have enclosed a couple of photos of the model in question.
Mike Alimov
Bill's setup is an excellent example of a system which, with all the data known (thanks for the details, Bill!), presents an opportunity for some weight savings.
If his airplane uses 1400 mAh per flight, it uses only 63.6% of the battery capacity (1400/2200 = 0.636). As we know, it is safe to use up to 80% of LiPo battery capacity.
 Assuming an average voltage of 3.7V per cell in flight, 1.4 Ah from a 6S LiPO pack equates to 1.4*3.7*6 = 31.08 Wh (that's Watt-hours).
If he steps down to a 5S 2200 mAh LiPo battery (which is about 2oz lighter than 6S 2200 mAh pack), the same energy will result in:
31.08/(3.7*5)=1680 mAh, or 76% of the battery capacity - still within the guidance, although closer to its limit.
Yes, the current consumption will go up a bit, but I think it would still be safe to step down from a Talon 35 to a Talon 25 ESC, which is also weight savings.  It may be necessary, however, to choose the 2820 motor with the higher kV rating.
So, altogether, we might be looking at 2 to 2.5 oz of weight savings.
It is very likely that I will be installing a very similar system on my next plane.
Dennis Toth
From what I am seeing it looks like you could get by with 30% head room from static test amps as Castle indicated that short spikes can be handled. So for instance if your static test amps are 19a then 30% higher is 24.7a so an ESC rate at 25amps should cover it?
Best,   DennisT
Mike Alimov
Quote from: Dennis Toth on November 01, 2026, 07:07:29 AMFrom what I am seeing it looks like you could get by with 30% head room from static test amps as Castle indicated that short spikes can be handled. So for instance if your static test amps are 19a then 30% higher is 24.7a so an ESC rate at 25amps should cover it?
Best,   DennisT
Dennis, I'm not sure what you mean by "static test", but if your setup is averaging 16-19 Amps in flight with occasional peaks to 24-25, then yes, I think it is safe to use a 25 A ESC- as long as it gets adequate cooling.
Bill Schluckbier
Hello Dennis,
I ran a static test on my set-up this morning and I have enclosed a copy of the picture I took.  I just picked an older pack from my stash and as you can see the voltage is a little on the low side so the amp reading is probably a little higher than it should be.  I was expecting 20 amps and measured 22 amp for about 490 watts of power. In flight you will see the base current creep up as the voltage sags as the battery discharges. While maneuvering, the current draw will be 10-15% higher than the static reading; however, there are a couple of caveats:
1) If the ESC is set-up to govern aggressively, the current spikes could be higher than the data I provided in the previous post. All of my governor settings on the Castle are to what they recommend (i.e. medium). The reason for this is that the ESC while trying to bring the prop back up to the desired RPM needs extra power to overcome the aerodynamic loads on the prop as well as the inertial loads of the motor case, prop and spinner.
2) The propeller pitch will also affect the inflight current draws.  Higher pitch props (say pitch 1/2 of diameter or greater) will unload more in level flight and might require a higher burst of current to recover RPM under load.
The other thing that was not mentioned in the previous posts is that your lap times will affect consumption; going faster takes more energy and drag is a function of the square of the velocity of the object.  Assuming a circle radius of 67 ft (top of my head to fuselage center line), a lap time of 5.55 seconds yields a level flight speed of 51.8 mph. A lap time of 5.2 seconds results in a speed of 55.3 mph. Reducing the lap time from 5.55 sec to 5.2 sec increases the drag load by about 14%. At any rate, my system is oversized simply because when I start flying the model I do not know what prop I will settle on.  The same is true for the lap time.
Now, take all of this with a grain of salt because I am just an average pilot, I am sure that others understand things better than I do.
Like Like x 1 Agree Agree x 2 View List
Dennis Toth
Mike,
By "static test" I mean a ground test not moving or on the bench.
Bill,
Agree, I like starting with a little bigger ESC with a new setup and then refine once I am in the ballpark, I usually begin by looking on the List your setup for a similar ship and motor/prop size then do a bench test.
I am working with my OTS Ringmaster that has a BadAss 2814 980Kv motor turning a MAS G series 10x7 (I am at 2350' here in Fletcher, NC need a little extra pitch) with a HobbyStar 4S 1800mha 120C pack (this pack is only 70mm long and fits in the nose of the Ringmaster perfect where the IC tank goes). Currently using a Castle Creation Talon 35A. I have been thinking of trying the CC Talon 25A to save 1/2oz (My Ringmaster is already at the limit for doing a reasonable OTS pattern at 34oz every oz counts).
I am also making a switch to YGK X-Braid Upgrade X8 No 2 (40lb test) lines from the FINS G40 40lb test lines I am currently using. The FINS lines are the same diameter (0.009") as the YGK's but the FINS go flat under tension and have the drag close to 0.018" stainless steel cable lines. The YGK's stay round and should be 30%+ less drag. This should help drop the flight amps a significant amount. Might even allow a little slower lap time which would be less rpm and less amp draw.
Best,   DennisT
Mike Alimov
Bill - your notes are very well taken, and reflect an excellent understanding of electric power systems.  I guess it all comes down to how much of a cushion one wants to have vs. the weight savings that can be achieved.  It is easier to have larger cushion in medium-to-large stunt planes (traditionally 46-60 size planes), because the electric powertrains scale up well.  Conversely, they don't scale down very well compared to combustion setups, and smaller airplanes (traditionally .15-.35 size) could use every ounce of weight savings you can get.
Dennis - given that it is a Ringmaster that you are talking about, and with the additional details you have provided, I would say that ESC is the last place to look for weight savings (which would be minimal going from Talon 35 to Talon 25).  To obtain more weight savings, I would downsize the motor from 2814 to 2320 (1 oz savings), and find a lighter battery.  Due to its 120C rating, your battery weighs about twice as much as a 25C rated battery of similar capacity.  Right there is at least 2 oz of weight savings.
Like Like x 1 View List
Dennis Toth
Mike,
You are right about the battery, problem is the HobbyStar 4S 1800mah 120C pack is the only one I have found that is short enough (70mm) to fit the RM nose area where the old IC tank would go. Going to a 2200mah 25C would require cutting into the wing and it also throws off the CG. I had a 2315 -820Kv in it (I was trying to use a 5S 1350 pack) and it just couldn't get to the rpm needed on a 10" prop and make the amp draw for the OTS pattern. I will look into the 2320 1090Kv motor option and see if there is enough room behind the can before it hits the battery pack.
Best,   DennisT
