OK Folks Please everybody listen up. The terms hardware and firmware mean the following: Hardware is the physical unit itself, the timer-governor you can hold in your hand. Firmware is the program that Keith designed and he or I can download into the hardware. As to which level of Firmware you need continue reading. The programming stick is the device you plug into the timer-governor in place of the on/off switch and use to change the RPM, Start up Delay, Flight Length, and Gain Value.
Which firmware you need depends on two things:
1. Which hardware version of the timer-governor you have? Version "1" has the Red LED on the programming stick and NO LED on the Timer-governor. Version "2" has the LED on the Timer-governor and NOT the programming stick.
2. You ask yourself the question: Do I have a version 1 Programming Stick (the one with the LED on it) and do I want to use it with a Version 2 Timer-governor (it also has a LED on it).
Keith allows people who purchased an early version 1 timer-governor and the version 1 programming stick to use the version 1 programming stick with version 2 timer-governors so they would not have to buy a new version 2 programming stick. It was for this application he designed the Version 1.2 firmware.
Below is a matrix of what goes with what.
Version 1 timer-governors with version 1 programming stick, you use Version 1 firmware.
Version 2 timer-governors with version 2 programming stick, you use Version 2 firmware.
Version 2 timer-governors with version 1 programming stick, you use Version 1.2 firmware.
Version 1 timer-governors with version 2 programming stick is not allowed.
One last thing as far as usability the version 1 and version 2 hardware/firmware work the same. I use both versions in several planes and they both work just fine.
If you still have questions contact me directly at 714-401-6514 or at abborgogna@hotmail.com
I know it is a bit confusing, but I hope this helps, if not call me, I'm here to help.
Andy
