  • July 07, 2025, 09:54:16 PM
Author Topic: AMA Control Line Electric Speed Records  (Read 1090 times)
Offline dynasoar1948
« on: September 20, 2010, 09:57:03 PM »
Whittier Narrows California, September 18, 2010
Class A and B records were set at meet today.
Class A Howard Doering  110.66 MPH
Class B  Will Stewart       142.46 MPH
William Stewart
Offline Scott Jenkins
Re: AMA Control Line Electric Speed Records
« Reply #1 on: September 21, 2010, 09:58:37 AM »
Will,
How about some specifics on the innards of both the A and B Class planes
I am still interested in trying E Speed.
Scott
Scott Jenkins
AMA 43122
FAI F2C VOLUME 2 SECTION 4, 4.3.7
m) During the refuelling and the restart of the motor, and until the time when he releases the model aircraft, the mechanic must keep the model aircraft in contact with the ground by at least one point and with the centre line outside the flight circle. During that time the pilot must be crouching or sitting inside the centre circle. He keeps one hand on the ground and his handle and his lines as close to the ground as defined by the F2C panel of judges until the model aircraft starts again.
« Reply #2 on: September 24, 2010, 10:25:56 AM »
Scott,
Howard's A ship uses top of the line Neu components.  Am not sure about his ECU, but the timer is, like mine, from Will Hublein.  The airplane is his old record holder from the mid nineties, modified to accept a  5A LiPo, which expanded the fuselage to resemble a Grumman Avenger.  Pix should appear in the Speed Forum soon.
My ship uses the same AVEOX 1415-2Y I was using 15 years ago, with the Hall effect sensors removed and a Castle Creations Phoenix 80 ECU.  The battery is a cheapie 6S 3A-40C from Red China.  The ship itself has 108 sq in wing area and about 33 stab.  It uses the dread 'wing tip bellcrank' so feared by mid-west Sport Jet types.  The prop was a maple 8/8 which I carved using old time technology.  This natural composite material still has some advantages, even at high RPM.
Now that we wil have to increase line length and diameter to stay in conformance with AMA guidelines, future speed will probably be at least 15 MPH slower.
Build an electric speed ship and join the fun.  Since a long skid is needed to protect the prop, Form 40 landing gear would not be much of a handicap and would eliminate the complication of a takeoff dolly.
Will
William Stewart
« Reply #3 on: September 30, 2010, 07:14:31 AM »
Will,
Whats the deal with the wing tip bellcrank I cannot picture
this in my noggin or understand why it is a threat in speed.
Scott
Scott Jenkins
AMA 43122
« Reply #4 on: October 12, 2010, 09:43:57 AM »
Scott,
Responding to your message in this forum and your recent e-mail.
The wing tip bellcrank, as used in my Sport-Jet ships is about as you described in your e-mail- the bellcrank located at the inboard wing tip, moving a pushrod positioned spanwise behind the trailing edge of the inboard wing. This pushrod is linked to a small triangular bellcrank behind the wing which connects to the elevator control horn.  All in keeping with the original North American Speed Society Sport Jet rules which require the entire control system to be external to the normal contours of the airplane.
Why bother?  The couple of feet of control line normally running over the wing to a conventional bellcrank location are the fastest moving highest resistance part of the line system. The spanwise pushrod is submerged in the wing's boundary layer and adds no drag.  Does it work?  My ships, under the old fuel rules recorded flights about seven MPH faster than the NASS 'sportsmen' who pushed through the rules change outlawing them- (165 MPH).  On the new jet fuel, I believe the results so far with the wing tip BC are still at least five MPH faster than the next quickest Sport Jet- (158 MPH).
The S-J rules change disqualifing my ships specifies that the BC be located within four inches of the fuselage and specifically eliminates the spanwise pushrod.  My 'New Rules' SJ is sitting on my desk as I type this, ready for the December Toys For Tots contest, and should have a similar low drag advantage.  We'll see.  If it works, and is written out of the 2012 NASS rules, there is still another configuration waiting, after all this is what I spent my career in aerospace doing and enjoying!
The only reasons I used the wingtip setup in the 142MPH B Electric is to eliminate some binding with the internal BC under the 85# pull and for fun.
Regards,  Will Stewart  AMA 1947
William Stewart
« Reply #5 on: October 13, 2010, 06:51:00 AM »
Will,
Your bellcrank system is definitely ok and what you say about the elimination of excess line is spot on Innovation truly is the mother of invention. You must have scared them real bad for them to change the rules more power to you solid engineering principles will keep them guessing and you winning keep shaking them up. S?P
I am going to send you another pm with a wing dynamics problem I have with a new design.
Scott
Scott Jenkins
AMA 43122
