  • June 15, 2025, 10:48:18 PM
Author Topic: Shaft ext on AXI 2826/10  (Read 1313 times)
Offline Vincent Corwell
« on: November 05, 2007, 02:03:43 PM »
Would it be safe to Dremel off the shaft projecting out the rear
of bulkhead mounted AXI 2826/10 motor?, need the space in the
battery compartment , Anybody please ?
Vincent
Alan Hahn
Re: Shaft ext on AXI 2826/10
« Reply #1 on: November 05, 2007, 03:41:10 PM »
As long as you leave the circlip on, I see no reason---except you won't be able to turn the motor around and have a front mounted motor in the future.
Offline Rudy Taube
  • Ret Flyboy
« Reply #2 on: November 06, 2007, 12:14:27 AM »
Like Allen said, NO PROBLEM.
I have over 100 flights on my AXI with the shaft cut off. I was not sure how important the shaft wheel collar was, but I left it on (in addition to the C clip) to be sure. Like you, I needed the extra room for the Battery.
In the future I will be using a front mount and keep the shaft for the prop. This is so I can use the rear fan units for better cooling.
Rudy
AMA 1667
Offline Igor Burger
« Reply #3 on: November 06, 2007, 01:11:57 AM »
Be carefull, otherwise all that trash from cutting will end up on your magnets.
Offline Rudy Taube
  • Ret Flyboy
« Reply #4 on: November 06, 2007, 12:10:56 PM »
Igor,
That is an excellent point. I forgot to mention that I cut my shaft off (Yikes, that does NOT sound good!) by mounting my motor to a piece of 1/8" x 4" x 6" ply that has a hole in it just big enough for the shaft to go through. I think (hope?) this is big enough to keep anything from getting into the magnets.
Rudy
AMA 1667
