  • July 20, 2025, 09:27:47 AM
Author Topic: A weak cell?  (Read 2057 times)
Online Perry Rose
A weak cell?
« on: April 30, 2020, 04:46:13 PM »
I figured out why a few of my batteries don't make the whole flight. They are over temping and the ESC is saving them. Now they are charged to 16.97 or better. Other batteries of the same brand and Amperage complete the flight with no problem and are much cooler. I measured the cells and I can't detect a weak one. This is on the same plane same day charged an hour before flights. 20 minutes between flights. 60 Amp ESC from Brodak. From what I read in the directions over heating is the culprit. Am I missing anything else?
Offline Fred Underwood
Re: A weak cell?
« Reply #1 on: April 30, 2020, 06:17:52 PM »
Please clarify 'they are over temping."  I think you are saying that the batteries are getting hot, over temperature, and the ESC is saving them.  I don't think that the ESC senses the battery or cell temperature.
What is the battery voltage and or % remaining when the flight stop?
How many mah re-charge goes into those batteries compared to ones that work well?
Fred
352575
Re: A weak cell?
« Reply #2 on: April 30, 2020, 07:36:16 PM »
Perry, I read your previous thread about "battery switch."  What is your charger?  Are these cells meant to be over charged, over 4.2v/cell?  I'm guessing 4s packs, and if not HV packs, then 16.8v for 4S packs.
Fred
352575
Online Perry Rose
Re: A weak cell?
« Reply #3 on: May 01, 2020, 05:38:25 AM »
The directions for the F2B Hornet 60A ESC it will cut the power to 35% if the battery temperature hits 110 degrees. The batteries are HRB 3300 4S units. I have a I Max Quattro B6 charger from RSM and a Black Magic X-Loader from Brodak. Both are set to 4S 3.3V charge cut off is 16.8V. After charging I change to balance mode. After a flight I have 15.1/15.2 V left in the batteries. Even the hot ones. I'm going to try a cut down 12 x 6 to 11.25 x 6 APC next time out. I have a few smaller planes with 11 x 5.5 props I can try the offending batteries on.
Online Perry Rose
Re: A weak cell?
« Reply #4 on: May 01, 2020, 09:46:51 AM »
The info sheet doesn't say but the 110 degrees is Celsius
Offline William DeMauro
Re: A weak cell?
« Reply #5 on: May 01, 2020, 11:38:08 AM »
When you have a bad cell its usually noticeably different if you check the individual cell voltage. the batteries will probably also take much longer than normal to charge and balance. Are you charging these in balance mode? Why are you balancing them after you charge? They should be balancing as you charge. The 110C is most likely the temp of the speed control as it would have no way of knowing the temp of the battery. I have a feeling you are hitting low voltage cut off and that's where they are being "saved". You very well may be right on a failing cell or battery. How much are you putting back in when you charge them? I looked up the HRB 3300 battery and that's a standard lipo, for best performance and lifespan they really shouldn't be charged above 16.8 volts.
AMA 98010
Re: A weak cell?
« Reply #6 on: May 01, 2020, 12:00:55 PM »
Normal operating temperature for Lipo is up to around 110°F, not C.  That is however the top temperature range for ESC's, (110°C).
There is an online manual for the "Hornet series" from HTIRC which says that the ESC has overheat protection at 110°C, when the ESC is that temperature.
https://img.banggood.com/file/products/20170112214632HTIRC%20Hornet%20Series%20ESC%20User%20Manual.pdf
I didn't see an online manual specific to Brodak Hornet, but probably similar.  Some of these manuals are translations, and not great ones.  That said, your specific of 110°C would be for the ESC.
While charging, you can likely look at the individual cell voltages on the charger.  Are they very close to the same?  Especially look at the cell voltages when you first put the pack on the charger after use.  You should be able to see a low volt cell if that is the problem.
I'm not sure why you would charge a pack, and then balance charge the pack, as opposed to using a balance charge the whole time. It sounds like you are charging a pack to 16.8V cutoff and then putting the pack on balance charge when it already has 16.8V?  If 16.8V and not balanced, are some cells over-volt?  Again, look at the individual cell voltages.
Are the hot packs older then the cooler ones?  Internal resistance on the packs can go up and they will get hotter.  Also, a single cell can be going bad as your concern.  Looking at the individual cells, especially when first hooked up, will help to see than.
15.1V/4 is 3.775V which is well over 20% left, so that does not seem the problem, unless the bad cell.  So, see if each cell is about that. There are lots of these devices available, but I have 2 of these, one with the charger and one in my flight box.  They are inexpensive and probably only semi accurate, but give decent information.
http://www.valuehobby.com/accessories/batttery-accessories/battery-capacity-checker.html
This will add to William's post, he was faster.
Fred
352575
Online Perry Rose
Re: A weak cell?
« Reply #7 on: May 02, 2020, 09:15:45 AM »
Now we're getting somewhere. I learned how to properly charge batteries from the advise on here. I also learned how to find the cell Voltages as the charging processes. (stupid directions) Now what is left is when to charge the batteries. I have been charging them right after the flying session and topping them off the morning of the flying session. What is the proper way to go about charging them before flying?
Re: A weak cell?
« Reply #8 on: May 02, 2020, 11:43:16 AM »
Perry, I’ll give this a try.  There are going to be many opinions on battery charging and best practice.  There is what is best battery care which will help longevity and number of cycles, and then there may be what is best for flying.  Obviously on one end of the spectrum, you can place the batteries in a box and not use them and they will last for a long time, though not many cycles.  Most agree that batteries don’t like to be discharged to less than 20% capacity and this is around 3.74-3.75v as rest.  The voltage will likely be a bit lower while flying/discharging.  Many smart phone with Lithium batteries have a low volt warning at 20% to help battery life.
Batteries don’t do well being held at full charge.  Longer time at full charge decreases longevity.  Some studies show that 80% charge may greatly increase the number of battery cycles over full charge.  Of course this is not practical for flying as we need to keep battery size and capacity (weight) to a minimum.  But, keeping batteries fully charged (or close) is not good for the battery.  Longer time is worse, so charging the day before is not best for the battery, though it may be best for the flyer’s schedule.
Fly the battery and when done, charge it to storage if not flying the pack again.  There should be a storage charge setting on the charger and it will shut off at somewhere between 40 – 60% charge, usually around 50% and not critical.  In general, batteries of same age and health will use about the same number of “mah” for a flight, so that they will take about the same number of mah to reach storage charge.  You can also look at cell voltage as you have found.
On the day of use, balance charge to full.  Balance charge is a bit slower than regular charge because of the balancing where the smart charger keeps the cells equal or balanced.  Many chargers also have a fast charge function and this usually slightly undercharges. Part of the reason that it is faster is that the tapered slow top off isn’t done, so slightly less full, less mah input.  You can actually use this to your advantage if you are not close to 20% after flight.  Say the fast charge leaves off a couple of % from full slower charge, but if you have 25% left, that works fine.
Some flyers have found that if they try to maximize what is best for the battery, they spend too much time getting ready in the morning, so they charge at night.  If you have 4 packs and fly 200 flights in a year, that is 50/pack and you might not notice any problems.  If you accurately keep track of cycles on a pack, you tend to get more cycles with better battery care.  But, do you get more flying or more time caring for batteries  :-)
Fred
352575
Online Perry Rose
Re: A weak cell?
« Reply #9 on: May 02, 2020, 01:51:41 PM »
I flew 3 batteries this morning and they were sitting waiting for an answer. I found the storage setting and all 3 said overcharged. I then put them on regular charge for 30 minutes and will balance them next time they come around in the que. The next time out will have the two problem batteries. I will give them the balance treatment first. No overhead stuff until I'm certain they are back to normal.
Re: A weak cell?
« Reply #10 on: May 02, 2020, 02:02:56 PM »
When you put them on the charger, did you see a total pack voltage, and individual cell voltage?  Most chargers will either charge or discharge to storage, whichever is needed.  I'm not sure what overcharged meant, unless you didn't use much battery and they were above storage charge.  Again, most storage cycles will either charge or discharge and switch automatically to which is needed.
While working on this problem, please document more.  If you can't charge on storage, but can on regular charge, look at (record) the total voltage of the pack and individual cell voltages.
Why regular charge for 30 minutes?  Does the charger have a time setting or are you timing?  What if they don't need 30 minutes?  Just trying to understand your process and charger.
In particular, please document voltage total and individual cells for the problem packs, at start and finish.
Fred
352575
Online Perry Rose
Re: A weak cell?
« Reply #11 on: May 02, 2020, 03:47:08 PM »
Generally the total voltage is 15.2V roughly 3.2 per cell.  It takes an hour or more to fully charge so to get me to the field early I put in 30 minutes and the rest during breakfast. That 30 minutes means a lot as the temperature is rising quickly now.
Re: A weak cell?
« Reply #12 on: May 02, 2020, 03:57:13 PM »
Individual cell voltages will help in the future.  3.2v/cell x 4 cells is 12.8.  15.2/4 is 3.8v/cell and if you have that after a flight, you aren't using much battery.  I picked 4 cells from previous posts, is that correct?  How long a flight?
Please record the mah input for the 30 minutes, and then the mah input for the completion of charge for a pack tomorrow.  That total will be your usage for a flight.
Also, please note your charge rate.
« Last Edit: May 02, 2020, 08:55:36 PM by Fred Underwood »
Fred
352575
Online Perry Rose
Re: A weak cell?
« Reply #13 on: May 03, 2020, 05:12:22 AM »
3.8/cell is right. I didn't carry the 4 or something. MAh in out? It's Greek to me. Volts before and after I can get.  Flight time is 5 min. 30 sec.
Online Perry Rose
Re: A weak cell?
« Reply #14 on: May 03, 2020, 06:13:28 AM »
I prepped the batteries and one showed a very weak cell. I was going to leave it home but put it on another charger and it showed fine readings. I'll give it a try in an hour.
Re: A weak cell?
« Reply #15 on: May 03, 2020, 10:38:04 AM »
When you first put the battery on the charger after use, look at the voltage total, then look at the voltage for each cell.  It you look at the cell voltage before the charger has time to balance, you can see a cell with abnormal voltage.  The low volt cell will be the weak one if that is the problem.
Milliamps input (mah) is the amount of charge that the charger is putting back into the battery.  It should show on one of the screens.  If you look at that number when the charger is done, or when you stop it (your 30 minutes) then you have the charge or mah of input.  Keep track of the total charge input (milliamps), the 30 minutes and then the final charge in and you will know about the charge used per flight (equals the total replacement input charge).
How did the prepped battery show a weak cell?  How was it different on a different charger?
Fred
352575
Re: A weak cell?
« Reply #16 on: May 03, 2020, 10:54:56 AM »
Here is an online manual for B6 charger.
http://www.milehighrc.com/Manuals/ImaxB6manual.pdf
On page 14 under heading Charging lithium battery in the balance mode one screen shown has the heading "supplied capacity and other screens called charged capacity."  The supplied/charged capacity is the amount of charge going into the battery.  Units of charge capacity are the "mah," so think of the terms as interchangeable.   Please keep track of supplied capacity (mah) as noted above.
Fred
352575
Online Perry Rose
Re: A weak cell?
« Reply #17 on: May 03, 2020, 02:20:28 PM »
After flying I charged the batteries and on the one that was good, now not good, the voltage was 16.92. After sitting an hour the voltage was down to 16.85. There is a drain someplace. It took 85 minutes to charge the batteries and still no finished beeps at that time.
Re: A weak cell?
« Reply #18 on: May 03, 2020, 02:41:22 PM »
I don't understand the "one that was good, now not good?"
How are you measuring voltage?  Voltage on the charger while charging will be higher than resting voltage (voltage measured while not charging).  That voltage may remain high for several minutes.  Voltage just off discharge, immediately after a flight, will be lower for several minutes and will settle a bit higher.  Cell chemistry, resistances, heat.... come into play.
You may have a cell problem, still not defined.  Again, please check battery voltage and individual cell voltages on the charger shortly/just after flying.  Read them just after you turn the charger to start charging so that it will show the voltages before any significant charge.  You can make this easy by selecting a charge rate that is very low, for long enough to get the values.
You may have a charger problem, it shouldn't charge to over 16.8v for four cells.  Is that the same on each of your chargers?  It may charger to 16.8v and then settle a bit, but 16.9 seems too high. The charger doesn't seem to be sensing the peak and shutting off properly.  If that was proper for your charger, then all batteries should do that.
How much charge in during 85 minutes and what charge rate?
Fred
352575
Re: A weak cell?
« Reply #19 on: May 03, 2020, 03:26:35 PM »
Here are a few pictures of my charger readings. I took a few they should be pretty self explanatory. I did get to fly today so I took pictures before, during and after the charge. After completion and I get my numbers I'll take them back down to storage. I could have just brought them up to storage.  Just so you know, there are 2 versions of the B6 charger . One is a "REAL" version and the other a known and admitted counterfeit. The counterfeit version has known balancing problems. There are a few threads on rcgroups on these chargers,including a few on how to tell the real from the fake. That is probably not your biggest problem anyway. I feel that most of your issues are from leaving your batteries fully charged for extended periods of time. That is known to shorten lifespan. If you want to go over this by phone, let me know and I'll send you my number. It may be easier than trying to type this all out.
AMA 98010
Online Perry Rose
Re: A weak cell?
« Reply #20 on: May 04, 2020, 08:34:44 AM »
I flew the problem batteries on my smallest electric plane. It has an Aerowind 2820/07 motor, APC 11 x 5.5, 40 Amp ESC and Hubin basic timer. Flight time was 5 min. 20 sec. All three batteries performed well. The plane is scratch built profile using the Legacy 40 wing and modified tail. Beginning voltage, using a digital multi meter, 16.86, 16.86 and 16.92. End of flight voltage, taken within a minute of landing, 14.92, 14.89 and 14.89 respectively. Voltage when I got home 15.07, 15.07 and 15.13.  I popped them on the charger/balancer, initial cell voltages, 3.76, .76 .78, .74. / 3.76, .76, .74, .76. / 3.79, .80, .79, .79. I'm probably over charging and actually taking power out by doing so. I didn't do any extra charging of these batteries before flying like I have been doing.
  My chargers are at least 3 years old and one has 4 stations the other one station. Bought from reputable vendors, not Amazon or ebay. I think they are working properly but I'm not. More experiments tomorrow with the Legacy size profile and equipment.
Re: A weak cell?
« Reply #21 on: May 04, 2020, 10:59:36 AM »
You are slightly overcharging but its nothing very drastic. Your discharge numbers look acceptable to me. I'll post a lipo chart that I found on the Net so you can see where your numbers are. The main thing to remember is to not keep the batteries at full charge for any longer than necessary and if you don't fly a battery  but you do charge it take it down to storage as soon as possible especially if its going to sit for more than a day or two. Charge them as close to your flying time as possible too.
AMA 98010
Online Perry Rose
Re: A weak cell?
« Reply #22 on: May 04, 2020, 11:47:57 AM »
I'm printing the chart now.
I have 4 batteries on discharge at the moment.
 I have been mistreating them all along.
At least I learned how to best use the chargers.
Re: A weak cell?
« Reply #23 on: May 05, 2020, 12:05:42 PM »
When you fully charge, is the charger telling you that it charged to 16.92. or did the charger note 16.8 and then the multimeter said 16.92?  The charger should shut off at 16.8 for 4 cell pack.  Take the 16.92 pack and put it on the charger and tell it to charge normally.  It shouldn't charge, but when it starts to "charge," it will check the battery.  At that point, you can read the total voltage and individual cell voltage on the charger meter.  You can repeat that in each charge station and second charger and see how they agree, or not agree.  Alternately, some charger have a setting to "monitor" instead of charge.  That monitor setting will also read the total and individual cell voltage(s).  My multimeters give approximation and most agree that the inexpensive meters are good tools for the flight box, but not overly accurate or well calibrated.  Mine don't always agree with each other.  If your charger is overcharging and shows that on the charger meter, then it seems a problem.  Not necessarily a problem if only on the multimeter.
On good batteries without problems, I usually find the cells within 0.01v of each other as read on my charger.  I also use Powerlab chargers as WD.
Fred
352575
Online Perry Rose
Re: A weak cell?
« Reply #24 on: May 05, 2020, 01:52:18 PM »
The charger reads 16.8 when it stops charging. I check the battery right after and get 16.9xx.
I charged the three batteries in this investigation yesterday about 1000 am. I went to the field 27 hours later, without recharging, to run them down and starting voltage was 16.8xx on two and 16.7xx on the third. All three flew full flights 5 min 20 sec. without complaining. end voltages are 14.89, 14.81 and 14.76.
It seems I have been torturing the batteries. From now on I will only charge them the day of flying.
Your help has been very valuable. Thank you.
Re: A weak cell?
« Reply #25 on: May 05, 2020, 02:13:10 PM »
Great job sorting through this, and thanks for completing the thread.  I'm happy to be part of the help.
Fred
352575
