  • August 05, 2025, 02:38:50 AM
Author Topic: A very strange way to lose a brand new plane.  (Read 2555 times)
Offline Andrew Borgogna
  • Andy
« on: March 05, 2013, 01:34:04 PM »
My brand new take apart Ringmaster was lost this morning on it's second flight.  The conditions for the crash are truly one for the books, bizarre!  I had just completed the full pattern on the plane was doing a couple of outside loops to unwind the lines from the triangles.   I started climbing out of the second loop when the motor slowed down to signal end of flight.  The lines went a bit slack but nothing I couldn't recover from, but then the motor came back up to landing RPM.  The torque from the motor snap rolled the plane in at me and the plane dropped into a spin and hit the ground on the outboard wing.
I not only have never heard of such an event like this, but for the first few minutes I could not even explain what I had just seen.  Fortunately my flying buddy Larry Renger was there and saw the whole thing.  He is the genuine rocket scientist from MIT, the first thing he asked me was what did I see from where I was.  I said it looked like the plane did a quick roll toward me and spun in just after the timer signaled end of flight.  He smiled and said "OK that's exactly what I saw.".  He then explained that the plane was flying up near vertical as it was slowed down from the motor dip.  Just as it was approaching stall speed the motor revved back up to finish the landing, a perfect combination for the torque to roll the plane.  I tell you I have never seen anything like it, in fact I am not sure it can happen on a gas plane.   Larry and I talked about this for several minutes and we could not come up with any other explanation that fit what we had just seen.
Heck of a way to lose a new plane, if I had just flown out the laps at the end I would still have the plane.  I'm a little sick over this.   :-[
Andy
Andrew B. Borgogna
Re: A very strange way to lose a brand new plane.
« Reply #1 on: March 05, 2013, 01:47:31 PM »
My sympathy.  I feel the worst about those crashes that wouldn't have happened if I'd just done six minutes of boring level laps instead of trying for stunts or whatever.
I could see this as being possible with a glow powered plane, but it'd take a perfect set of coincidences for it to happen.
Offline John Cralley
« Reply #2 on: March 05, 2013, 02:48:50 PM »
Bummer Andy,
Although I have one of Keith's KR timers I have not used it yet (as I gaze out the window at the snow coming down). The Will Hubin timers that I have been using just give a slight drop in the RPM and no where near a full stop. Therefore, the winding back up to flight RPM does not seem to be that great. Granted I have not had one do the end of time approaching signal while in a vertical climb. Actually, I usually use a talking timer which counts down the last minute at ten second intervals and the old ten, nine, eight etc, countdown for the last ten seconds. Al Hahn put me on to that years ago -- it has clip that hangs it onto my shirt pocket. That little timer would have save you a Ringmaster. Sigh!!
Sounds like your take apart was a good flier too.  HB~>
John Cralley
AMA 52183
Central Illinois
Offline Crist Rigotti
« Reply #3 on: March 05, 2013, 03:01:26 PM »
What direction were you spinning the prop?  Tractor or pusher?  Sounds like an entirely way too much and too long a dip in spped for the EOF signal.  Also maybe the ramp up speed is too fast?
Sorry for your loss.
  • Andy
« Reply #4 on: March 05, 2013, 03:03:50 PM »
I can't for sure how far down the KR timer goes but it is not a full stop at all.  It's just a dip for a couple of seconds and then back up to flight power.  The problem this time is where the dip happen and where the power came back on.  It's been a while since I flew on a Hubin timer, but I seem to remember it had a dip as well.  In my case the power dipped just when the plane needed it most and then came back on.  As I often say the laws of physics are self enforcing.  We need to know when the flight is about to end and the dip in power seems to be the standard for the timers I have seen.  Such is life.
Andy
Andrew B. Borgogna
  • Andy
« Reply #5 on: March 05, 2013, 03:09:11 PM »
Good question Chris, I just checked the prop to be sure.  It was set up for Tractor prop which made the torque roll left and in at me.  Had I put a pusher prop on the plane this might not have happend.  The roll would have been away from me and the line tention might have kept it from snapping over.  I need to give that some thought.  As a rule I don't normally fly with tractor props, but I was given this one to try out.
Andy
Andrew B. Borgogna
Offline Dave Denison
« Reply #6 on: March 05, 2013, 04:37:25 PM »
Andy
Andrew
Sad to lose any good ship.  But Crist hit it on the head with the Prop type.  Not really sure that the ship could have been saved "fully" with either prop, but the tractor prop sealed your fate. The KR timer gives 3 seconds of motor retard then back to the chosen RPM.....not to be blamed for the crash
You may want to look  into a timer/timing device to have with you when flying. These work very well and are easy to set up and use.  The item I've pictured is one brand, I've used this one for 9 years plus....just change the batteries every year or so.   This has saved a couple of planes so far.
ama41041
ama 41041
« Reply #7 on: March 05, 2013, 04:58:10 PM »
As I stated on someone else goof while flying,  We live and learn.   Too bad the plane did what it did.   Not only did you push the time, but you should realize that with only a few flights on a new plane, not to do any thing after finishing a pattern.   Hopefully you didn't hurt too much and will have it flying again soon.    You have done so many E power planes that I have been tracking and I think this Take Apart Ringmaster was going to be the one I really wanted with your recommended power set up.
« Reply #8 on: March 05, 2013, 05:15:37 PM »
Andy,
Sorry about the ship going in, hopefully you can repair it (that's the good thing about electric - no oil). I setup my systems without the power dip warning. Originally I used it, but got caught coming out of the last loop on the clover one time and had to pull out short of the stem. I like to set the timer up to give me 7 - 10 laps after the last maneuver. This varies with the pattern (OTS vs PA) and line length/lap time.
I never undo the loops - seen to many top fliers lose ships with the engine quiting early. Some guys put one outside turn in before takeoff so there is only one turn at the end. . I just keep the lines clean. Let us know if you get her back together.
Best,          DennisT
« Reply #9 on: March 05, 2013, 05:31:34 PM »
That STINKS!
Offline Larry Renger
« Reply #10 on: March 05, 2013, 06:17:45 PM »
There was some minor fuselage damage.  The wing is toast since it hit hard, straight on the wingtip. But since the wing is removable, a new wing kit could put that baby back in the air!
Offline Keith Renecle
« Reply #11 on: March 05, 2013, 10:03:52 PM »
Bummer Andy,
That is a bummer Andy, maybe the thin wing section on the Ringmaster played its part as well?? The rpm dip is not drastic........just enough to be noticed and some time ago, Andy recommended getting rid of my full power setting after the dip............just as well it seems! So now it goes a little faster than the set governed rpm and not at full throttle any more.
John, if you like, I'm sure that Andy can update the program (firmware) in your KR Timer for you. There have been some nice improvements made since you got yours, especially the variable gain setting.
Keith R
Keith R
Offline jim gilmore
« Reply #12 on: March 06, 2013, 12:35:20 AM »
is that the same effect that causes crashes is real ww2 aircraft when they(pilots) decide to go around and add too much power to quickly ?
  • Andy
« Reply #13 on: March 06, 2013, 12:51:25 AM »
Keith is right it was not that the motor dipped it was when it dipped and what the plane was doing at the time of the dip.  Add in the tractor prop and you have the perfect storm.  It was a new plane and I should have shown more sense and just flew out the level laps after the pattern, if for no other reason than to see how many were left.  Anyway it was a lesson learned and one I will not soon forget.
This .25 size electric power system that RSM will be offering is killer.  It's light in weight and really hauls, I was swinging a 10 x 7 prop with way more power than the Ringmaster required.  In fact the next thing on the list was to drop the power down and retest with a smaller battery.  I have made no secret about what I think of the KR timer, it is all I use on all my electric control line planes.   y1
Thanks for the input and kind words I think I will build another one, I have a special place in my heart for the Ringmaster.
Andy
Andrew B. Borgogna
Offline ericrule
« Reply #14 on: March 06, 2013, 08:10:34 PM »
Andy:
I keep telling you that "Take-Apart" does not meant that you use the ground as a tool!(lol)
Sorry about the ding to the Ringmaster. From Larry's post it appears that the fuselage survived (probably all of the lamination which adds in enormous strength without weight). I look forward to seeing the results on Friday. By the way, I have a new Take-Apart Ringmaster for you. I just know how much you love building!!!
Eric Rule
Offline Dean Pappas
« Reply #15 on: March 06, 2013, 09:33:47 PM »
Andy, I'm bummed for you.
The torque-roll ... heck that's a proper maneuver for the RC guys! You did one.
Yes, with a pusher prop you'd still have the ship unless the same thing happened in an inverted climb.
That doesn't help at all, I know!
Really, the power goes away for seconds (as in plural?) Maybe it's a full second, but just one-quarter of a second would suffice.
  Dean
« Last Edit: March 07, 2013, 07:40:09 AM by Dean Pappas »
Dean Pappas
