  • August 01, 2025, 09:30:17 PM
Author Topic: A push /pull sport stunt model  (Read 7200 times)
Offline frank carlisle
« on: December 02, 2006, 02:17:43 PM »
I'll be using Dick Sarpolus plans (modified for in line props)  for a Fokker D-23-a foam Nobler wing- and an Axi 2826-10 motor and Poli-quest 3700 mah 2C battery.
What do you think an appropriate prop size would be?  Front and back.
Frank Carlisle
Offline Dean Pappas
Re: A push /pull sport stunt model
« Reply #1 on: December 05, 2006, 01:08:24 PM »
Hi Frank,
Are you ganging the two on a common shaft?
Counter-rotating? it actually matters.
If they were closely coupled counter-rotators, then the diameter would be almost exactly the same.
Put them far apart, and the diameters would need to be maybe 87% of a single prop.
why? power is proportional to diamter ^5 for all other things equal, so 1/2 power absorbed is 87% diameter.
If they don't counter-rotate, I have no idea, especially as the effective pitch of the back prop will be reduced by the spiral airflow from the front one.
for what little it helps,
Dean
Dean Pappas
« Reply #2 on: December 05, 2006, 01:26:05 PM »
Dean,
I'm putting the on a common shaft. The distance is 22" from prop tp prop. They'll be rotating in the sme diction. One tractor-one push.
Axi 282610. 3700mah 3c.
Efficiency in this case isn't as important to me as efficacy.(big word hope I used it right).
Sport model , twin boom with Nobler wing.
Frank Carlisle
Online John Paris
« Reply #3 on: December 05, 2006, 05:22:07 PM »
Frank is such a trend setter.  For general flying, it may not be an issue, but if you wanted to get a stunt run out of the deal, would there be enough battery on board to swing 2 props for that long?
Additionally, on a common shaft, would you want to offset the props so that they appear as 4 blades when viewed from the front or rear or would lining them up be better?
So many things to think about.
John Paris
269
« Reply #4 on: December 05, 2006, 05:53:15 PM »
You've already seen the electric Smoothie go John.
I'm thinking this one would be a sport model.
And yes I think the AXi could turn two props. Same difference as putting a downsize 4 blade prop on where a 2 blade prop was.
Jan will be making bearings , shaft and couplings.
Frank Carlisle
