  • July 08, 2025, 02:51:42 AM
Author Topic: A do-it-yourself Watt Meter  (Read 724 times)
Offline Jim Moffatt
« on: March 08, 2010, 11:01:27 AM »
The attached picture shows the watt meter I cobbled up this winter from parts and two meters I have.
The small black coil is a 1 milli-ohm shunt made of 14 gage (AWG) house wire. The 1 ft. piece of wire shown in the picture cost $0.19. I had all the conectors and the two meters so my total cost ws $0.19. The meters are typically available for $10 each or less. To make the 1 milli-ohm shunt use a 7 1/4" piece of the 14 gage wire. Alllow an additional 1/4" on each end for the solder connections.  I rolled the wire into a coil but first folding it in half then winding it makes it non-inductive. The shunt produces an output voltage of 1 mv per ampere so with the meter on the 200 mv scale it reads amps directly. The second meter reads the voltage between the battery plug contacts. It will handle at least 30 amps continuously and probably 50 or more for a short time. Not as elegant as a real watt meter but definately less expensive.
Offline Warren Leadbeatter
  • AUS-14782
    • My Home Page
Re: A do-it-yourself Watt Meter
« Reply #1 on: March 09, 2010, 02:58:03 AM »
Very good.   But for $23.99 you can get one of these Turnigy Watt Meter and Power Analyzer
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=10080&aff=210543
Cheers
Warren Leadbeatter
Port Stephens, Australia
AUS-14782
Offline Jim Moffatt
« Reply #2 on: March 09, 2010, 05:16:27 AM »
Warren
I saved the $23 and bought a lipo for my Super Clown!   ~>
