  • June 18, 2025, 02:10:10 AM
Author Topic: The competitive edge  (Read 3337 times)
Offline RC Storick
« on: April 27, 2013, 09:39:35 AM »
One f the reasons that electric appeals to me is that I can go to the Hobby shop and buy a power train that is the equivalent to the top dogs. Hence the E-flight, now after dabbling with this stuff for a bit and trying to get up to speed I am doing some experimenting myself. Recently someone posted a link to Zippy batteries so I thought I would give them a try. So far so good. They are only 10 grams heaver than the Hyperion and slightly longer. So this was a good match. They Hyperion batteries are 25C and the Zippy's are 35C. The best thing about them is they are only 35.00 instead of 75.00.
I have heard someone say they would not fly them in a official. I ask why? If they do the job at home why would they not do the job at a contest. Of coarse common sense comes to play. If you had 500 flights on a battery I would at least use a fresh one in a official.
Many things can be found on line way cheaper than in the Hobby shop. Motor 69.00 battery 35.00 controller 45.00 and timer 15.00. Now you will need the timer box 50.00 and a charger. But if you think about it you only need those once.
By no means am I trying to convert anyone because I have IC too. But I am looking at this on a piratical mode. Start up cost is pricey but I do see the maintenance cost less. The only draw back I have found the is the charging of the battries. You kind of have to plan your flight date. With IC its grab and go. With electric its plan and wait for a charge then go. I am currently working on this issue with a fast charger but with that comes some risk. http://www.progressiverc.com/icharger-updates
« Last Edit: April 28, 2013, 02:56:59 PM by Robert Storick »
Offline John Rist
Re: The competitive edge
« Reply #1 on: April 27, 2013, 03:34:44 PM »
I am not sure what timer @ $15 you are talking about but I would recommend the KR timer from RSM:  http://www.rsmdistribution.com/index-2.htm
With the program card it is around $50 however it gives you constant RPM with a cheep speed controller.  It has the added advantage of protecting the ESC, motor, etc in case of a prop strike. I also found it  easy to program in the field (no computer required).  I think it fits in the cheep but as good as the big boys use category.
« Reply #2 on: April 27, 2013, 03:38:36 PM »
the castle speed controls also provide prop strike protection, however in MOST cases its a mute point since basically this only happens when you crash,, at which point, your toast anyway
Offline Jason Greer
« Reply #3 on: April 27, 2013, 06:19:11 PM »
Robert,
I've been using the same 5 Zippy Flightmax 5s 3000 packs for the past two years.  I haven't had any problems and this includes all official flights at the nats last year.  If I remember correctly the packs I'm using are 20 bucks a piece.
Jason
El Dorado, AR
AMA 518858
« Reply #4 on: April 27, 2013, 06:25:43 PM »
Robert:
I think people are less than entirely trusting in the quality of the Zippy and other cheap Chinese packs.  You pays your money and you takes your chances.  Jason's story makes it sound like a good risk.
Jason:
I'm not sure about what they were, but I've been looking at prices of 3300mAh, 4S packs -- which are currently running at around $30.00 a pop at Hobby King's US warehouse.  It may be less if you get it from Hong Kong -- but then you've got to pay an arm and a leg in shipping.  I don't know about the 5S, 3000 mAh - but I'll bet they've gone up.
Offline Jason Greer
« Reply #5 on: April 27, 2013, 06:40:08 PM »
Looks like they've gone up about 2 bucks at the usa warehouse.  They are out of stock at the moment though.  http://www.hobbyking.com/hobbyking/store/%5F%5F16700%5F%5FZIPPY%5FFlightmax%5F3000mAh%5F5S1P%5F20C%5FUSA%5FWarehouse%5F.html
El Dorado, AR
AMA 518858
Offline Bob Hudak
« Reply #6 on: April 27, 2013, 07:28:34 PM »
Turnigy has a motor that looks like a drop in replacement for the Eflite 25. On Hobby Kings website it is called Turnigy G25. It has the same kv rating looks the same but has a different sticker. I ordered one to try, my total came to $30.85(had some points accumulated). Sure beats $70 if it works. I have some Turnigy Nanotech batteries and they only cost $26 instead of $75 for ThunderPower. Same bang for less bucks ! ArrowWind motors can be swapped out with Emax motors for less than half the cost also.
« Last Edit: April 27, 2013, 08:16:09 PM by Bob Hudak »
350838
Online Howard Rush
« Reply #7 on: April 27, 2013, 07:41:09 PM »
Hobby King's US Warehouse is just south of Tacoma.  One can order stuff to pick up there with no shipping charge.  Mike Haverly and I made an expedition down there a few weeks ago.  Although their Web site is quirky, the lady at the warehouse is very conscientious.  Tim, this is a good excuse for you to come to the Stuntathon.  You can stop and get you some Zippity Doo Dahs on the way.
« Reply #8 on: April 27, 2013, 08:08:16 PM »
Guys,
Has anyone tried the FLIGHTPOWER NANO ~ EVO-ULTRA LITE (http://www.flightpower.co.uk/index.php?main_page=product_info&cPath=15&products_id=274)? They seem to be light weight and a good price.
I have been using the ThunderPower Lites but the EVO's seem to match the weight at half the price.
Best,         DennisT
Offline Mike Haverly
« Reply #9 on: April 27, 2013, 08:26:29 PM »
I tried to order some of these http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=21351 but it seems they are only available from Hong Kong at this time.  I ordered four and received them in five days.  Shipping was expensive but still less than the high priced spread.  I used them at NATS last year and will use them again.  The four from last year have about 40 cycles each on them and they are still fine.  The more expensive Thunderpowers that I have are relegated to duty in my profile model.
« Reply #10 on: April 27, 2013, 08:37:34 PM »
What's the address in Tacoma?
Offline William DeMauro
« Reply #11 on: April 28, 2013, 06:59:22 AM »
Sparky, Great thread!!! I used gens ace batteries in all my official nats flights last year. they were the freshest ones I had. like you I doubt I would use a battery with lots of flights on it. Nor would I use a brand new one.(you don't need to find out you got the one dud in the lot during an official. I too bought some zippy 4s 3700's 35 c to try and they actually weigh about 10 grams less than my hyperion 4s 4000's. (just a thought, If you can play with your wire length you may be able to shed those 10 grams, that stupid ten gauge wire is heavy!) I charged those 4 Zippy's in 14 min from storage mode. this morning on my power lab 8 at 40 amps. and my 4 gens ace took 22 minutes at 30 amps on my I charger 306. these are older batteries so the balance mode takes slightly longer.
As far as the G25's from hobby king go. THEY ARE NOT CLONES OF THE Power 25's. I ordered one for a local flyer and have seen them side by side. While similar, THEY ARE NOT THE SAME!! For one the bearings are smaller!!
He as not flown it yet so that doesn't mean it is not a good motor, just not the same. I have a feeling they will make a great sport flyer motor and possibly more.
 As far as the KR timers go, I haven't used one and cannot comment on them. But I can comment on cheep speed controllers. Why would anybody trust their planes to cheep speed controllers that have NO Manufacturers backing? If one searches around, plenty of deals can be found on the castle speed controllers, both new and used and they are backed up forever by castle. Justin the last week I saw a NIP phoenix 45 for 45 dollars on an rc board and a new phx 35 for 30 dollars and a new phx60 for 55 dollars. if I ever try a KR, I'm linking it to a PHX!!!
 Like Sparky says its good to experiment but be cautious. I don't like to compromise on the castle speed controllers and I feel a good charger is well worth it!
AMA 98010
Offline Dan Bregar
  • Field Marshall
« Reply #12 on: April 28, 2013, 07:42:56 AM »
As far as batteries go I have only used 2 brands beside Thunder Power, and they are Blue Lipo and Sky Lipo, both from Hobby Partz. The Sky Lipo is my preference since the Blue Lipo's have some very cheap wire which is used on the balance tap and is very stiff and tends to break on a fairly regular basis. At first I thought it was a poor soldering job by the factory. But after It happened on 3 or 4 different batteries I confirmed that it is actually the wire itself that breaks. I own 6 of these and have had to fix all of them in the last two flying seasons. So no more Blue Lipo's for me.  The Sky Lipo's have a nice flexible silicone wire balance tap and I prefer them these days. Just sayin.  :)
AMA 33676
Offline Robert Redmon
« Reply #13 on: April 28, 2013, 08:00:39 AM »
I bought a couple Turnigy G25s a while back. I replaced a Aerowind 2820/07 with one, and it flies a 40 size plane (540 sq. @ 50oz) very well. I needed the extra weight for balance. It works fine in this application; however, it is a 10 pole motor (vs. 14) and besides the smaller bearings (which have not been a problem so far) the build quality appears to be significantly poorer than the E-flite 25 (magnets not spaced equally, wire dressing, etc.) Also, try what I may (including the use of a small press), I have not been able to reverse the shaft in the motor to allow front mounting. From what I have seen, the E-flite motors are a bargain for their quality and power. Even though the Turnigy costs less, I am not sure I would call them a bargain.
Bob
Robert Redmon
AMA 58073
Offline Andrew Borgogna
  • Andy
« Reply #14 on: April 28, 2013, 10:58:24 AM »
This is a really good thread.  I am asked often what is the difference between an expensive motor and a cheap motor.  Here is what I have learned over the past couple of years.  Quality of the shaft bearings, I have had to replace bearings in cheap motors but never in an expensive motor.  Then there are the less obvious differences like the resistance of the wire used the less resistance the more efficient the motor is.  Next the quality of the magnets used in the rotor, the stronger the magnets the more efficient the motor.  The gap between the rotor and the stator the smaller the gap the more efficient the motor is.  Finally the quality of the metals used in making the motor.  I had a motor prop shaft bend after just three flights on a small 1/2a motor I was testing.  So this begs the question, what price efficiency?  This is an important question; if you are flying in club contest in the lower levels you can well afford the lower efficiency.  You will need a slightly larger capacity battery to make up for the lower efficiency of the motor.  This leads to slightly less performance in the pattern, and a lower score.  But if the level of competition is such it really does not matter.  The opposite can be said for flying at the highest levels of competition where every gram counts, because every gram equates to points.
I use zippy batteries and am quite happy with them but I am an intermediate flyer.   I use good motors but not the most expensive and get excellent results for my level of flying.  I watched an expert flyer yesterday using the same quality equipment I use turn in one of the best patterns I have ever seen on an electric plane.  So I know what I use is competitive.  The answer to the question of what is right really depends on what you want and what you are willing to pay.  As somebody else pointed out always take a good look at the shipping and handling charges especially for Hobby King, they use it to jack up what looks like a good price to a price that is really not so good.
Anyway that's my opinion for what it's worth.
Andy
Andrew B. Borgogna
Offline RC Storick
« Reply #15 on: April 28, 2013, 11:17:57 AM »
For anyone looking for 4s 4000 Hyperion batteries I have 2 in classifieds among other PA goodies
Offline John Rist
« Reply #16 on: April 28, 2013, 12:02:21 PM »
The big problem is not crashes but nose overs on a grass field.  If you read through the threads the castle ESC works some of time - but not all of the time.  I have tested my KR by grabbing the motor with a rag.  The shoudown is instant!  This is with a $30 speed controller.  Are you willing to test the castle this way and risk a $80 ESC.
« Reply #17 on: April 28, 2013, 12:12:25 PM »
I have ,,
both with RC and with CL I have had unintended prop strikes,, with no failures,,
« Reply #18 on: April 28, 2013, 12:21:23 PM »
OK, here's a dumb question. So, if you have a prop strike and the thing stops. You back it up and maybe replace the prop. Do you have to somehow reset the system or does it automatically reset when you press the start button again?
I know, neophyte questions, but I've been wondering about it.
« Reply #19 on: April 28, 2013, 01:28:29 PM »
Randy,
if you hit the start button again ( to stop the timer) ,, have a prop strike, or any other planned situation, including test runs with the timer set for only a couple minutes,,,
you need to disconnect the battery to reset the timer and it will start over from zero,,
« Reply #20 on: April 28, 2013, 01:46:12 PM »
Wow! I had no idea that they were 10 pole motors!! If that's the case they wont work as well for us as I thought that they would. Does anyone have any idea how many pole the g15 has? Thanks for the info Robert. I knew a couple of other budget motors were 10 pole but I didn't think this one was.
AMA 98010
« Reply #21 on: April 29, 2013, 11:55:18 AM »
Dumber yet would be changing the prop with the system still armed!  It would be prudent to unplug the battery which resets everything in any case.
« Reply #22 on: April 29, 2013, 12:08:18 PM »
ahhh Mike, you spoiled it,, I was looking forward to seeing Randy jumping around in the pits trying to change his prop on a live setup LOL,,
ok not really, I thought the same thing but did not type that, ( I am trying to change my habit of using 4500 words to explain a 10 word situation)
« Reply #23 on: April 29, 2013, 12:52:56 PM »
I got it. Pull the arming plug before you do anything. I sort of already figured out that part.   :P
Offline Bob Hudak
« Reply #24 on: April 29, 2013, 08:16:16 PM »
What a bummer on the Turnigy G25. The description of the motor made no mention of the magnet pole count or bearing size. Only one mention in the reviews of there being 12 poles, I took this to mean the winding poles. The quest continues for an inexpensive powerplant!
350838
Offline ericrule
« Reply #25 on: May 01, 2013, 09:06:34 PM »
Bob:
Andy & I have just finished all of our field testing on the KDA brand of motors. We have run systems equivalent to .15, .25, .40, .46 & .76 glow power. Each of these motors worked perfectly (and we compared them to the high priced Hacker motors of the same power range).
If you are looking for an inexpensive electric motor that will run with the big boys take a serious look at the KDA's. If you purchase them from RSM remember that we guarantee all of our products. Our warranty is and has always been "if you are not satisfied we will either replace the product or refund your money".
The KDA motors are listed on our web site www.rsmdistribution.com
Eric Rule
