  • June 17, 2025, 09:19:30 AM
Author Topic: Switching an old model question (Maple motor mounts)  (Read 1968 times)
« on: September 14, 2012, 03:07:52 PM »
OK, Guys, how have y'all gone about removing the maple motor mounts?
Then what do you do to mount the elec. motor?
Thanks!
BIG Bear
RNMM/AMM
Re: Switching an old model question (Maple motor mounts)
« Reply #1 on: September 14, 2012, 05:22:59 PM »
I just use a Permagrit drum sander, put on a mask and have at it. The smell is awful and the dust is a pain, but it only takes about 10 minutes to remove the maple mounts.
  That Permagrit sander is great!  Much much better than the old sandpaper cylinders - eats through maple like a hot knife through butter. Emphasis on "hot", but it doesn't get as hot and burn the wood as badly as the sandpaper.
    I have a wide array of the permagrit tools, I don't know how we managed without them.
Offline Allan Perret
  • Proverbs
« Reply #2 on: September 20, 2012, 09:21:13 AM »
Permagrit drum sander ?  Is this something used in a Dremel tool ?  What is a good source for these ?
Allan Perret
AMA 302406
Slidell, Louisiana
Online Crist Rigotti
« Reply #4 on: September 20, 2012, 11:53:58 AM »
A big thank you to Bob and all.  I will go about getting some more of the PermaGrit sanding drums, etc,.
What is the recommended firewall thickness for the front mount?  This is for a ".35-.40" equivalent electric system.
Thanks, again!
Offline Andrew Borgogna
  • Andy
« Reply #5 on: September 20, 2012, 12:26:43 PM »
I use 1/4" for anything over a .40 size motor, some will say it's overkill but I have never had a failure.
Andy
Andrew B. Borgogna
« Reply #6 on: September 20, 2012, 12:30:23 PM »
Andy
Thanks, Andy!
The only electric "system" I now have is a front mount motor.  Guess I just need to make a really *thick* nose ring.
BIG Bear
RNMM/AMM
« Reply #7 on: September 20, 2012, 01:45:24 PM »
Bob Hunt has some really cool-looking fiberglass/epoxy motor mounts.  It's 1/8" and predrilled for the motor: all you need to do is get it attached solidly to your airframe.
« Reply #8 on: September 20, 2012, 02:28:22 PM »
Thanks for the info, Tim.  I'll have to get with Bob as to just what I need to do.
BIG Bear
RNMM/AMM
  • Andy
« Reply #9 on: September 20, 2012, 11:00:14 PM »
Hi Bill
Bob Hunt does have some very nice motor mounts for front mounting.  Depending on what kind of motor you have you may be able to reverse the prop shaft in the bell and rear mount the motor.  The motor pictured in the PT-19 was originally a front mount that I reversed.   What type of motor do you have?
Andy
Andrew B. Borgogna
« Reply #10 on: September 23, 2012, 03:00:30 PM »
Hi Andy,
The motor is an Arrowind (came in Brodak Super Clown package) and is a front mount as is.
Thanks!
