I am starting to build a Brodak 59 Ares with the Universal A Electric Conversion Kit #BH-1943.
What I have determined is that you must adjust the height of the E motor mount to put the E motor shaft on the same center line as the original wet engine. It also looks like you need to adjust the fore/aft location of the motor to allow the fiber glass cowling to fit.
My big question It that it doesn't look like the motor can be easily removed after you build up around it. Am I missing something here?
PS This is my first rear mount motor. All my front mount motors are easy to remove.
