  • July 31, 2025, 05:45:22 AM
Author Topic: 4s 3000 mha what would you charge at?  (Read 2232 times)
« on: November 13, 2013, 05:53:18 PM »
I have a few 3000mha 4s batteries. I now understand if I change the out put amps on my charger it will charge faster. (1.2 amps vs 3.0 amps). My charger will output as much as 7 amps. What is a good rule of thumb?
Offline Curare
Re: 4s 3000 mha what would you charge at?
« Reply #1 on: November 13, 2013, 06:12:27 PM »
If you want the packs to last, charge at 1C (1x the capacity of the pack), so in your case, 3.0 amps.
I've had packs that are 5 years old, have had over 500 cycles and only now are struggling to push out 80 amps.
they've always been charged at 1C, and ALWAYS have been put on a storage charge if left for more than a day.
Greg Kowalski
AUS 36694
Offline Fred Cronenwett
    • Lafayette Esquadrille
« Reply #2 on: November 13, 2013, 06:13:35 PM »
I charge mine at 3.0 amps, 1/10 of the mah rating of the battery
Fred
Fred Cronenwett
AMA CLSCALE7 - CL Scale
Offline Curare
« Reply #3 on: November 13, 2013, 06:47:29 PM »
Fred
only if your battery pack was 30000mah is 3 amps 1/10 of the capacity.
3000mah, = 3AH  so 1C is 3 amps.
Greg Kowalski
AUS 36694
Offline William DeMauro
« Reply #4 on: November 14, 2013, 04:06:23 PM »
In  your case it probably wont matter but exactly which 4s 3000mah batteries do you have? Different brands can be charged at different rates. Maybe you can post a link to the exact battery? Most batteries these days can be charges at a minimum of 2c or 3c. I try to buy batteries that can be charged at 5c for myself then I charge them at 3-4c to take it easy on them. When I charge from storage mode I pretty much follow the same procedure as Bob does.
AMA 98010
« Reply #5 on: November 14, 2013, 04:19:29 PM »
Spec.
Capacity: 3000mAh
Voltage: 4S1P / 4 Cell / 14.8V
Discharge: 25C Constant / 50C Burst
Weight: 299g (including wire, plug & case)
Dimensions: 150x45x24mm
Balance Plug: JST-XH
Discharge Plug: 4mm bullet-connector Connector
« Reply #6 on: November 14, 2013, 05:03:56 PM »
From the specs it looks like this one. http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=20442 . If so that battery is rated at a 5c charge. Even if you max your charger out you wouldn't even be hitting 50% of that batteries charging capability. So feel free to charge up to full speed with the charger that you have. That battery can be charged at 15 amps max.
AMA 98010
« Reply #7 on: November 14, 2013, 08:36:43 PM »
Thanks guys for all the feedback. Im learning a bunch of new stuff.  #^
And three more electric flights before the sun set this afternoon.  ;D
Offline Curare
« Reply #8 on: November 14, 2013, 08:38:43 PM »
In my experience with nano-techs, while you can charge them at 5C, they lose their punch fast.
AS a matter of fact, it seems like anything you do to those packs, they loose their punch. Even leaving them sitting charged seems to have an effect.
I've been running a 3000 4s in one of my 3D planes, and while it only got charged at a max of 2C, it's weaker than a 2200 4s now.
Greg Kowalski
AUS 36694
« Reply #9 on: November 16, 2013, 11:43:44 AM »
Thanks guys H^^
Offline Curare
« Reply #10 on: November 17, 2013, 04:39:46 AM »
Bob, yeah they are. A friend of mine works for a company manufacturing UAVS, and during testing they tried just about every pack that was available at the time. After countless cycles the Hyperion G3 was the chosen one.
Greg Kowalski
AUS 36694
