  • July 31, 2025, 03:09:46 PM
Author Topic: 4mm Collet Style Prop adapter for BadAss 2320 820Kv  (Read 9836 times)
« on: June 25, 2024, 04:35:40 PM »
I have been fighting a vibration problem with my BadAss 2320  820Kv motor setup. Turns out it is the Collet Style Prop adapter. Seems that although the adapter I have says it's for 4mm but it is not running true causing lots of prop noise and vibration like a Fox35. The adapter unit is from Great Plains. Is there any better units out there that you guys have used on 4mm shafts?
Best,    DennisT
Re: 4mm Collet Style Prop adapter for BadAss 2320 820Kv
« Reply #2 on: June 26, 2024, 08:37:23 AM »
Thanks Ken, I ordered 2 so will have a backup. I did a no-load motor only test and no vibration or shaft wobble so if the collet is just a little off it will shake around even though it is tight on the back part of the shaft.
Best,   DennisT
