Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
July 30, 2025, 08:10:02 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Electric Stunt
Gettin all AMP'ed up!
(Moderator:
Dean Pappas
4mm Collet Style Prop adapter for BadAss 2320 820Kv
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: 4mm Collet Style Prop adapter for BadAss 2320 820Kv (Read 9828 times)
Dennis Toth
2020 supporter
Trade Count:
0
Admiral
on:
June 25, 2024, 04:35:40 PM »
I have been fighting a vibration problem with my BadAss 2320 820Kv motor setup. Turns out it is the Collet Style Prop adapter. Seems that although the adapter I have says it's for 4mm but it is not running true causing lots of prop noise and vibration like a Fox35. The adapter unit is from Great Plains. Is there any better units out there that you guys have used on 4mm shafts?
Best, DennisT
Logged
Ken Culbertson
25 supporter
Trade Count:
0
Admiral
Re: 4mm Collet Style Prop adapter for BadAss 2320 820Kv
Reply #1 on:
June 25, 2024, 05:31:44 PM »
I am using the prop adapter on my 2320's but I have had similar problems with the 5mm. These are about the cheapest collets out there but they really work. You get a 1/4 28 shaft that tightens easily.
https://www.bing.com/shop/productpage?q=spectrum+4mm+prop+adapter&filters=scenario%3a%2217%22+gType%3a%2212%22+gId%3a%22218526729926%22+gIdHash%3a%220%22+gGlobalOfferIds%3a%22218526729926%22+AucContextGuid%3a%220%22+GroupEntityId%3a%22218526729926%22+NonSponsoredOffer%3a%22True%22&productpage=true&FORM=SHPPDP&browse=true&cvid=541B64C3B5E44A5B9163D292274A22D8
ken
Logged
Dennis Toth
2020 supporter
Trade Count:
0
Admiral
Reply #2 on:
June 26, 2024, 08:37:23 AM »
Thanks Ken, I ordered 2 so will have a backup. I did a no-load motor only test and no vibration or shaft wobble so if the collet is just a little off it will shake around even though it is tight on the back part of the shaft.
Best, DennisT
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Electric Stunt
(Moderator:
Dean Pappas
