  • July 23, 2025, 07:53:43 AM
Author Topic: 31 days and in the air (flight report)  (Read 4566 times)
Offline RC Storick
« on: April 28, 2013, 11:25:43 AM »
In less than 30 days I have completed a beam airplane. Beam wings are by far the easyest construction in my opinion. First photo is the start date.
Following photo's are outside and in less than 30 days. Now I must be honest these have been long days but it shows you that with some determination and perseverance it can be accomplished., The plan is one more coat of clear today and glue flaps and elevators on and go fly. I can sand rub and buff as I fly it. All up weight is 58 OZ. that's three ounces off my goal but I think it has to do with the speed in which this was finished.
« Last Edit: May 01, 2013, 03:00:44 PM by Robert Storick »
Offline Allan Perret
  • Proverbs
Re: Less than 30 days
« Reply #1 on: April 28, 2013, 11:47:19 AM »
30 days, that's Amazing !
I started a Crossfire build little over a week ago.  Should finish with the wing panels and flaps today.  I'm using foam cores from Hunt for wing, flaps, and stab/elev.  Wanted to compare how I am doing weight wise to your first Crossfire, but having a problem with the search function and can't find the build thread on the first one.  Can you post the links to both of your Crossfire builds.   Did you use the same power system for both ?
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #2 on: April 28, 2013, 11:59:59 AM »
yes, but have you flown and trimmed it yet?   LL~
Offline RC Storick
« Reply #3 on: April 28, 2013, 12:19:03 PM »
Talk to god about the weather. If it looks good for tomorrow I will fly it.
Offline ash
« Reply #4 on: April 28, 2013, 05:19:31 PM »
Well done Sparky. Your work ethic is inspirational!
Offline Jason Greer
« Reply #5 on: April 28, 2013, 08:28:51 PM »
Looks great Robert.  Look forward to seeing it at the nats!
Jason
El Dorado, AR
AMA 518858
Offline Dean Pappas
« Reply #6 on: April 28, 2013, 09:18:54 PM »
Hi Sparky,
It's bound to be killer at that weight.
later,
  Dean
Dean Pappas
Online jfv
« Reply #7 on: April 29, 2013, 08:42:29 AM »
Gotta love the look of a Beam wing.  Always enjoy your builds.
Jim Vigani
« Reply #8 on: April 29, 2013, 09:30:26 PM »
 Just curious for comparison, what did your last P-47 weigh RTF?
Offline RC Storick
« Reply #9 on: April 29, 2013, 09:34:33 PM »
If I remember right the last contest weight in Memphis it weighed 69 OZ Too heavy for that plane
Offline RC Storick
« Reply #10 on: April 29, 2013, 09:57:08 PM »
Well how it played out today was I didn't get to fly it. The hinges are glued and it's now bench trimmed. If the weather is good it will go to the air tomorrow. Exactly 1 month to the day after start. I have built some faster but none as nice as this one this quick. I didn't think about anything I just did it. Should be a good one.
All up weight after everything it hovering around 59.OZ 4 over goal. Has to be the paint. I am glad I didn't use urethane would be 2 OZ heavier.
Offline Doug Moon
« Reply #11 on: April 30, 2013, 08:45:07 AM »
59 oz. is AWESOME!!! At that weight for that size its going to fly great.  You wont be hampered by weight in any situation you come across.
The paint you used was butyrate dope?  If so it has gloss hardeners in it to make it fuel proof so it is not the lightest weight material if weight is one of the main concerns.  The automotive paint can be a little lighter as far as colors go.  BUT the auto clear weighs more so there is the trade off.
I have used a comparable auto primer in spray can that you used, fills awesome, dries quick, layers nicely. Most of the rattle can primers out there DO NOT LAYER properly.  Its a pain!  Got mine at the auto paint store.  I was able to fill that plane with three cans.  BUT IT WEIGHS A TON!!!!  No matter how much you sand off there is weight gain.  I don't know why it is that way, but it IS.  A few coats of Sig nitrate dope and zinc sanded out prior to auto primer can help reduce the amount of autoprimer needed to fill it.  And if you want you can stay of the bottom with it and only fill the bottom with nitrate and zinc.  On my last plane I was coming in real light until a gun problem caused me to have to re-primer the plane and I got in hurry and I just sprayed it on until filled and then sanded it all back off. Bad move. Cost a couple of OZ right there!!  But in Muncie they can trend heavier and still perform.
On my new plane I will be using Zinc and nitrate first then auto primer I mix myself.  I will mix it about 60/40 thinner/primer.  I will have total control of the amount I use in the mix.  I am going to use the small gun to apply it. Bob G used to paint his whole plane with an airbrush to keep the amount of material applied to the plane very low.  He is a big proponent of not using more than you need, especially filler. I will spray and sand in small areas working slowly only putting on as much as need.  Instead of layer it up and sand it off.  My really light planes were done this way in the past.  It seems to work better.  I don't know why that is BUT it is.
At 59oz your plane is light and its going to fly great!!!!  You did a great job on it, and a dope finish that quick too!!!
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
« Reply #12 on: April 30, 2013, 10:04:23 AM »
For the record, I am curious how much you added weight wise,, in JUST color and clear?
when I painted the 109 a week back, I measured,, the color and one coat of urethane clear added 3.1 ounces,, the clear was a little less than one ounce of that weight
Offline RC Storick
« Reply #13 on: April 30, 2013, 10:34:00 AM »
My total finish is 10 oz. Bare wood up
Offline RC Storick
« Reply #14 on: April 30, 2013, 11:05:38 AM »
This is the first round of sanding and polishing. I will have to wait a few weeks for it to dry to get the final buffing. I just can not bring it to the field look shaggy. Here it is for what it is. There is not much paint on it but still acceptable.
Today it's 30 days old.
It doesn't look as good as yours I am sure. There's no paint on mine.
« Last Edit: April 30, 2013, 11:22:32 AM by Robert Storick »
« Reply #15 on: April 30, 2013, 11:45:03 AM »
Robert,,
not trying to "compare" as it were,, Just trying to get a feel for weights comparatively
It is very easy to put on two, or even three to four ounces of urethane clear,, I weighed mine at each step just to know what the color part was,, I have lost my notes from when I build the airframe so I really do not know what the primer and dope added..
I was actually surprised that it added no more than it did with the clear.
Yours looks great! I tend to end up with my paint jobs being to busy, sometimes simpler is better, I just love the creative aspect of coming up with something different,,
and the 109,, well it looks good in pictures, but there are known issues,, ( known to me) the paint job is effective in masking some of them,, the next one will be better,,
Offline RC Storick
« Reply #16 on: April 30, 2013, 12:35:35 PM »
Mark if I remember right you are a painter right? If so you know how hard it is not to miss things. My tag line reads the finish starts at first piece of wood cut. It is so true I cant emphasize it enough. A dope finish is super hard to make light in 3 months let alone a week. So some things have been over looked. I hope it don't shrink a bunch this season. To get this plane with this weight the coats are light and thin. only 3 thin coats of clear on This plane. The shine is accomplished in the sanding and rubbing.
« Last Edit: April 30, 2013, 02:33:55 PM by Robert Storick »
« Reply #17 on: April 30, 2013, 02:08:51 PM »
I was a painter,, actually make a living on the computer now,, ( autocad and revit,, Project coordination) but yes I have a lot of years holding a spray gun,, thats why I react rather pointedly to some posts regarding painting and shortcuts,, been there done that,,
and if you get stunt news, you would see I quoted you in my first column( and again later I think)
its VERY true,, probably the single most overlooked aspect actually,, because without a good base, you cannot build a LIGHT quality finish on top of it,,
I have done custom cars, show cars, and everyday drivers,, each step up the quality ladder doubles the time involved in obtaining the results,,
typically a good finish takes as long as the building does,, at Least that long.
I am continually impressed, and surprised actually, by the quality of finish work I see by people who are NOT painters,, its cools to see,, and It brings me pleasure to share knowledge with those who want to learn...
More than one way to skin any cat,, however, like Phil says,, depend on the fact that something works to know it works,,
and what you do works,,
Offline RC Storick
« Reply #18 on: April 30, 2013, 02:22:04 PM »
When was your first column?
« Reply #19 on: April 30, 2013, 03:37:57 PM »
man I dont recall, it was after VSC last year, ( thats when Bob cornered me LOL)
I think it was march april? I will have to look back,
Offline RC Storick
Today it went in the air.
« Reply #20 on: May 01, 2013, 02:07:13 PM »
Ted Winterman and I went out this morning. I flew it around 7 flights. The wing was high for a temp fix I tweaked the flap. The wing is straight so the lateral center of gravity is too high. I got home and I am making a few battery holders to try next time out. Even with the 11.5 nose moment this airplane has a smoken corner. Turns and locks. I am extremely happy with the flight characteristics of this model. With some more trim sessions this plane should come around.
The only down side I have with electric so far is charging time. I have 8 batteries and it took almost 5 hrs to charge them. This should be fixed this weekend when I get my 24V power supply. I still have 2 New Hyperion 25C 4S 4000 batteries for sale in classifieds.
Ted post the pictures in this thread please.
« Last Edit: May 01, 2013, 03:04:54 PM by Robert Storick »
Offline ptg
« Reply #21 on: May 01, 2013, 03:56:51 PM »
Thanks for the reference Mark, kinda splitting hairs but it goes like this; "Rely on the fact that something is working to validate the fact that it does work'
PT Granderson
« Reply #22 on: May 01, 2013, 04:12:52 PM »
Phil, thanks for correcting that,, I did not research to refresh my memory, (?) before blasting away on the keyboard,,
at least I got the main thrust of it?
Offline RC Storick
Re: Today it went in the air.
« Reply #23 on: May 01, 2013, 04:14:22 PM »
I did have one issue I am working on. The motor surges sometimes. I was told to change the pmw to 16 instead of 12. I have no clue what that means but I did it?
Re: 31 days and in the air (flight report)
« Reply #24 on: May 01, 2013, 04:37:25 PM »
Lightest finish I did (that looked decent) was my 3rd Slider. The red and yellow one. From bare wood to let's go flying: 6.8oz. That's with a 4 color finish and urethane topcoat. I was pretty proud of that.
Offline RC Storick
« Reply #25 on: May 03, 2013, 02:05:19 PM »
pic at the field
Offline RC Storick
« Reply #26 on: May 03, 2013, 06:08:27 PM »
one more pic. Today I have been making wheel pants.
Offline Alan Resinger
« Reply #27 on: May 03, 2013, 10:16:43 PM »
Robert,
If you have time problems with charging batteries, you can parallel balance charge batteries depending on the capacity of your charger system.  I sometimes charge 3 5S 2700 mAh Thunder Power batteries in parallel at 15A, or about 1.8C, in about 25 minutes time.  Max output of my I-charger 208B is 20A, so I could charge 6 batteries at 18A in parallel.  I don't charges them that way ofter but when time is short it gets the job done in a hurry.  If you need info on parallel charging, Progressive RC has a short video on their website.
Alan Resinger
Offline Dean Pappas
« Reply #28 on: May 05, 2013, 08:58:45 PM »
Hi Sparky,
Okay, you say it surges.
Where in the pattern, when, and if it sounds like an oscillation in RPM, how many cycles?
Changing the PWM or chopping rate sounds like a bit of a long shot to me, but I am curious to hear if it has an effect.
take care,
  Dean
Dean Pappas
Offline RC Storick
« Reply #29 on: May 05, 2013, 09:10:15 PM »
Hi Sparky,
take care,
  Dean
I beleive I have figured it out. I had it set to new phoenix high and only 3.2 firmware. Its on phoenix high rpm now.
Offline RC Storick
« Reply #30 on: May 05, 2013, 10:40:16 PM »
My 2 day wheel pants
« Reply #31 on: May 05, 2013, 11:01:38 PM »
that works Robert,, Hope she trim s out fast for you
Offline RC Storick
« Reply #32 on: May 05, 2013, 11:27:17 PM »
Me too I don't have a lot of time. The NATS is my 1st contest of the year. It use to be SIG but now who knows. Now if the weather would clear up. The only reason this was a fast build is I was running out of time. I was lazy all winter and did not build till the beginning of this year. My fleet was getting old and I figure it was time for some new flying stock. I like to go into the season with at least 2 of the same planes. Hence CF 1 and 2.
Offline MarcusCordeiro
« Reply #33 on: May 06, 2013, 07:49:04 PM »
Those pants look nice...
Then again, the whole model looks amazing!!
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
Offline RC Storick
« Reply #34 on: May 07, 2013, 12:06:18 AM »
Thanks Marcus. Seeing as the weather is bad I am rubbing it out now. Because this plane has very little paint on it that makes it hard. While it is shiny it does not have that made of plastic look.
