  • July 22, 2025, 02:20:54 PM
Author Topic: Great day to fly in South Africa  (Read 1059 times)
Offline Percy Attfield
« on: May 02, 2013, 09:45:24 AM »
Yesterday was a great flying day with good company in Henry Kurowski and Roston Dugmore.
Attached are my 2 Centurions, they have Impact outlines but are different.  Especially the white one has longer nose and tail moment arms, a thicker wing with a blunter leading edge, more leading edge sweep and a larger stab with smaller elevators.
I love to fly it #^
The yellow one has a tricycle undercarriage inspired by the Bob Hunt thread on his new extended tricycle Crossfire. It flies great and take off and landings are a pleasure.
Both planes use MVVS 8/680 motors powered by 25C 2700 mAh Thunder Power batteries.
The white one uses a 13x5 (repitched Dennis Adamisin 13X4 1/2PF2B series) prop giving 5.3 second laps at 9240 revs measured with a rev counter.  The yellow one flies better on a 12" prop than a 13" prop. It uses a 12x5 (cut down repitched 13X4 1/2PF2B series) prop giving 5.3 second laps at 9480 revs.
I think they could fly a little faster but last September when I was fortunate to fly with the Vancouver group Chris Cox said I fly to fast at 5.1 seconds. I am trying to get used to the slower speed. However if I do decide to increase the speed I will simply add 1 click to my KR Timer/Controller and increase the speed by 0.05 seconds or add 2 clicks and increase the speed by 0.1 seconds to 5.2 second laps. y1
Percy Attfield - South Africa
Offline ericrule
Re: Great day to fly in South Africa
« Reply #1 on: May 02, 2013, 06:56:57 PM »
Hi Percy;
Nice work on the models my friend!
It's great to see you still active after all of these years and still representing S. Africa at the Worlds.
Best personal regards
Eric Rule
« Reply #2 on: May 03, 2013, 04:48:41 AM »
Thanks Eric.
« Reply #3 on: May 03, 2013, 08:29:48 AM »
The planes look great.   Now, I am still not sure about lap times when it comes to flying a plane.   If the plane flies great for you at the settings you have fine.   I too fly a little fast at times, but as someone told me, the plane itself has a happy medium as far as speed.   If too fast for the pilot, use longer lines.    If too slow, use shorter lines.    Anyway, when you keep picking up those first place awards you can tell him the speed is fine for you. H^^
Offline Andrew Borgogna
  • Andy
« Reply #4 on: May 03, 2013, 12:31:26 PM »
Hi Percy
Keith has mentioned you many times over the past couple of years.  Is this the field he fly's at?  Very nice looking planes I wouldn't mind owing one.
Andy
Andrew B. Borgogna
« Reply #5 on: May 04, 2013, 02:47:26 AM »
Thanks Doc it is true that each plane has its own speed sweet spot.
Yes Andrew that is the field Keith flies at.
Offline Chris Cox
« Reply #6 on: May 06, 2013, 02:25:09 AM »
Of course, 5.1 second laps at your altitude may be totally necessary. We have considerably more air down here at sea level!
Offline MarcusCordeiro
« Reply #7 on: May 06, 2013, 07:45:14 PM »
Nice models!!
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
