  • July 11, 2025, 09:22:37 PM
Author Topic: 3 bolt prop adapter for Eflite 25 and 32  (Read 2274 times)
Offline frank williams
« on: September 05, 2013, 09:34:31 PM »
I'm looking for a 3 bolt prop adapter for an Eflite power 25 and 32.  They make one for the 46 and 60, but not for the 25 and 32, even though there are 3 holes tapped .  One for a Cobra or AXI might fit, I just don't know which one.  Any thoughts?
Offline Jeff Traxler
  • T-Bone
Re: 3 bolt prop adapter for Eflite 25 and 32
« Reply #1 on: September 05, 2013, 09:48:42 PM »
Hi Frank,What is the bolt center spacing.I may have one I won't use.Jeff
« Reply #2 on: September 05, 2013, 10:04:23 PM »
Jeff,  the 32 looks like 15mm between holes and the 25 is 12mm.  This is the length of the side of the triangle.
Where can I order them?
  • T-Bone
« Reply #3 on: September 05, 2013, 10:59:57 PM »
I have 2 of the 12 mm spacing with spinner,screws ect.I don't remember where/why I got them or even how much I paid.Mine are all 4 bolt and I won't use them.Send your address in a PM and I'll get them in the mail tomorrow.Hopefully they are the correct ones.Jeff
Offline Mike Scholtes
« Reply #4 on: September 15, 2013, 06:20:47 PM »
Hi Frank:
I can tell you for a fact the AXi 3-bolt prop hub fits the E25, since I just did that. Did not like the looks of the collet prop hub that came with the E25. The motor shaft needs to be tapped (or whacked) back until the tip of the shaft is flush with the motor body, like the AXi comes from the factory. I wonder if EFlite makes its own version of this item??
  • T-Bone
« Reply #5 on: September 15, 2013, 09:52:09 PM »
Hi Frank,The postman said your adapters should arrive Friday.Just wondering if you received them and if they work?I think Hobby King sells them too for one of their lesser motors.Trax
Offline Bruce Shipp
« Reply #6 on: September 16, 2013, 08:11:35 AM »
I am not familiar with these 3 bolt prop adapters.  Do they attach the prop directly to the can vs the shaft?  Could someone please post a picture or link?
Bruce
« Reply #7 on: September 16, 2013, 05:52:27 PM »
Hi Bruce: The prop shaft bolts to the end of the motor can, a machined boss with three tapped holes. I had heard the E25 is a clone of the AXi 2826 and this seems to confirm it. I would check the Hobby Lobby (RC, not crafts site) for AXi parts pictures. The item is pricey, like $25, so somebody else probably makes a less expensive version. I have not checked EFlite's site but that would be a likely source.
Online Larry Wong
« Reply #8 on: September 16, 2013, 08:35:24 PM »
PICTURE is worth a Thousand words   LL~ LL~ LL~ LL~ LL~ LL~
Larry
Offline Bruce Shipp
« Reply #9 on: September 16, 2013, 10:03:24 PM »
Thank you.  I have seen these but did not know how the were  used.  I Iearned something new today...now I can go to bed.
Online Howard Rush
« Reply #10 on: September 22, 2013, 07:31:58 PM »
I just got an E-flite 32 and saw the nice flat spot on the front with the three tapped holes. It sure looks like a good place to mount a spinner.  I can't find a 3-bolt prop adapter on the E-flite site.  I found some for AXIs at Hobby Lobby.  Is anything else available?
Offline Shawn Lenci
« Reply #11 on: September 22, 2013, 10:21:27 PM »
Howard,
Call these guys.  They are local to you.  Tell them we need these made and maybe they will add it to their catalog.
http://www.customrcparts.com/index.php?main_page=index&cPath=23_106
Shawn
AMA 97686
Online Howard Rush
« Reply #12 on: September 22, 2013, 10:44:25 PM »
Thanks, Shawn.  His motor mounts look even more interesting.
« Reply #13 on: September 23, 2013, 09:04:42 PM »
Custom RC lists the E25 3-bolt prop shaft as an available part for $7.99. The similar AXi part is on permanent backorder and is about $15 (including the motor mount plate).
