  • June 18, 2025, 12:17:09 AM
Author Topic: Motor timing  (Read 1083 times)
Offline Russell Bond
  • Bandolero
Motor timing
« on: November 18, 2014, 02:56:02 AM »
I've been using 15 degrees timing on my Plettenburg, however Plettenburg say to run 24 degrees, which I have now tried.
I didn't see any difference, however I think it used less battery on 24. (I only had one flight on each so I will try a lot more flights to assess.)
What are the symptoms of having too much or too little timing set on the motor?
Bandolero
