  • June 19, 2025, 12:42:00 AM
Author Topic: First electric  (Read 1165 times)
Offline Fred Quedenfeld jr
First electric
« on: August 26, 2019, 06:23:58 AM »
Will the Turnigy D3536/9 910 KV  or the Exceeds rc rocket 86mb81  pull a 450 sq  in plane?
Have hubin timer and 35 esc
What prop should I try?
thanks
Fred Q
Offline William DeMauro
Re: First electric
« Reply #1 on: August 26, 2019, 07:09:45 AM »
Short answer yes, I'm assuming you plan on using a small 4 cell battery thats 1600-2200 mah range. I would use an APC thin electric 9x6 prop. I couldn't find that exceed part number but it seems like you are looking at the 3015 rocket motors. Out of the ones that are currently in stock use this one  https://www.hobbypartz.com/86mb22-rocket-3015-1035kv.html     Exceed RC Rocket 3015-1035kv . Here is a link for that prop https://www.towerhobbies.com/cgi-bin/wti0001p?I=LXZK94&P=ML   Those motors will swing a slightly larger prop if needed.
AMA 98010
Online John Rist
Re: First electric
« Reply #2 on: August 26, 2019, 08:54:21 AM »
What airplane are you going to use?
