  • July 16, 2025, 02:41:01 PM
Author Topic: 2013 Electric Stunter - A Build Log  (Read 30994 times)
Offline Larry Fruits
Re: 2013 Electric Stunter - A Build Log
« Reply #100 on: November 20, 2012, 02:15:11 PM »
Hi Crist,
 I buy Aero Poxy and SuperFil from Wicks. Same stuff, same price and a lot closer than California. I like the SuperFil the best.
 Nothing against California guys. It's just that central Illinois is a lot closer to Iowa. Delivery might be a little quicker.
 Larry
Online Crist Rigotti
« Reply #101 on: November 20, 2012, 05:16:16 PM »
Hi Crist,
 Larry
I hear ya Larry.  I thought when I checked, Wicks was more expensive.
« Reply #102 on: November 20, 2012, 07:28:24 PM »
I got the decals made up today.  All ready to cut out and apply!
« Reply #103 on: November 20, 2012, 07:38:41 PM »
Hi Crist,
 OK, Wicks is less than $2 more, but it may have been worth it for the two or three weeks you have been waiting.   y1 y1 y1 ;D
 Nice build thread and a really good looking profile. Hope it flies as well as the Thundervolt. Enjoyed helping you trim it at FCM.
 Later;
       Larry
Offline Bob Hudak
« Reply #104 on: November 20, 2012, 07:43:48 PM »
Crist,
 Where do you get your decals from ? I am looking for some very similar to what you have there. Are they self adhesive and can I specify a different group insignia?
    Bob
350838
« Reply #105 on: November 20, 2012, 07:48:48 PM »
Hi Crist,
 Later;
       Larry
Don't rub it in Larry!   :)
« Reply #106 on: November 20, 2012, 07:59:39 PM »
Crist,
    Bob
Bob,
I made them up my self, at least the master.  I searched the web and either copied or made up each part.  Then printed the master out on a laser printer.  Then went to Office Max and they ran the decal paper through their laser copier (52 cents!).  Then I overcoat the decal with Testors Decal Bonder.  These are water slide decals.  I use Bare-Metal decal paper.
http://www.scalehobbyist.com/catagories/Detailing_and_Weathering/BMF00000123/product.php?micr=1483
http://www.scalehobbyist.com/catagories/Detailing_and_Weathering/BMF00000125/product.php?micr=1483
http://www.scalehobbyist.com/catagories/Paint_and_Construction/TES00009200/product.php?s=3&t=1&u=5
Offline Bob Hudak
« Reply #107 on: November 20, 2012, 08:48:49 PM »
Crist,
 One last question then I will leave you alone(for a little while). You are using water slide decals on iron on covering with no problems with tearing? I thought the water slide decals would tear as the covering shrunk or expanded in the sun over several flying seasons.
  Thanks, Bob
350838
« Reply #108 on: November 20, 2012, 09:04:25 PM »
Crist,
  Thanks, Bob
The decals will only be used on the painted fuselage, fin, and rudder.  If I were to use decals (stickers) on the Monokote, they would be peel-n-stick vinyl type like most "decals" nowadays.
« Reply #109 on: November 20, 2012, 10:08:23 PM »
Sorry Crist,
 The Devil made me do it.   >:D  :) Only because I have done similar numerous times.
Hope you get the stuff soon, so we can see how this bird will end up.
 Larry
« Reply #110 on: November 27, 2012, 06:30:33 AM »
The Aeropoxy is here.  On to the fillets.
« Reply #111 on: November 27, 2012, 08:08:53 PM »
OK, here is how I do fillets.  With Aeropoxy Light, you have to stir it up real well.  I made up a wire whip and put it in my cordless drill and stirred away.  The hardener has a "syrup" on the bottom that has to get stirred in thoroughly or you'll get a rubbery fillet that won't sand.  I've included some pictures of the stuff all stirred up.  The hardener will look like melted milk chocolate when stirred properly.
I use a 10X multiplier on my gram scale so I can measure out a 1/10 of a gram accuracy.  I put the mixing cup on the adapter and turn on the scale.  When it reads 0 then its ready to go.  For the fin and each side of the stab, I used 4 grams of the filler and 2 grams of the hardener.  I know this is too much but when you buy it by the 1 1/2 pounds, you can be a bit wasteful!.  I then mix it up real well and using a craft stick I trowel it into the corner pushing the Aeropoxy into the crevices.  When that's done I use my fillet tool.  I glued on a 1/4 inch ball bearing to a 3/16 dowel.  I use the ball bearing because it gives a constant radius no matter what angle it is against the side.  Once I form the fillet with the tool, I scrape off the excess with a single edge razor blade.  I then fold a paper towel into quarters and soak the towel with 91% rubbing alcohol.  I then clean up the sides/stab/fin etc by running the edge of the paper towel very close to the fillet.  Once cleaned off I let the fillet sit for about 45 to 60 minutes to set up some.  I then dip my finger into the alcohol and run back and forth along the fillet very gently.  This action will smooth the fillet and feather the edges very nicely.  Again the fillet get the wetted paper towel to clean up all around the fillet.  I then let harden over night.  I'll sand them when they are all done.
Tonight I got the fin and stab done.  I also did the first application on the canopy too.
« Last Edit: November 27, 2012, 08:29:24 PM by Crist Rigotti »
« Reply #112 on: November 28, 2012, 08:19:39 AM »
How much time does this stuff give you before it is unworkable?
« Reply #113 on: November 28, 2012, 11:31:02 AM »
A good hour or so.
« Reply #114 on: November 29, 2012, 08:23:41 PM »
Down to the outboard side and the pushrod cover is all that is left to do.
« Reply #115 on: December 01, 2012, 11:26:32 AM »
Very, Very nice work, Crist!
I remember up the thread somewhere a really nice looking red/white/blue scheme.
What will you be using for a blocking coat on the fuselage and other wood parts??
Thanks!
« Reply #116 on: December 01, 2012, 01:25:09 PM »
Thanks!
Thanks Bill
I'll be using SIG white with a little bit of black added for a light grey coat.  Stay tuned.
Online Howard Rush
« Reply #117 on: December 01, 2012, 03:22:12 PM »
That's because different colors absorb heat from the sun differently.  You have to match the decal color exactly to the covering color.
« Reply #118 on: December 01, 2012, 05:29:39 PM »
Tonight I finished putting on the fillets.  Tomorrow I'll sand them and then on to the finish!
« Reply #119 on: December 01, 2012, 09:06:47 PM »
Bob,
I use 3M SJ4570 Dual Lock to hold the timer to the ESC.  It sure beats velcro.  There is no "rocking" with Dual Lock.   Here is a link:
http://www.amazon.com/3M-Scotch-Profile-Reclosable-Fastener/dp/B0045A182K
Crist,
I really liked the info on the Dual Lock and your method of joining the ESC and Timer.  I ordered some tonight. thanks for the link.  y1 #^
« Reply #120 on: December 01, 2012, 09:43:24 PM »
Crist,
You'll really like the stuff!
Offline John Cralley
« Reply #121 on: December 01, 2012, 09:47:34 PM »
Crist,
I too have been using 3M Dual Lock for various component mountings. However, I found that when I used it to help secure batteries to a mounting plate on the model, it required an excessive amount of pressure to get it to lock (especially when it is cold). I ended up using a strip of Dual Lock on the battery but a strip of "heavy duty" fuzzy side "Velcro" (came from China) on the battery mounting plate. That works fine for securing my batteries (there are also regular securing straps to hold these batteries).
Just my 2 cents.  ;D
John Cralley
AMA 52183
Central Illinois
« Reply #122 on: December 01, 2012, 10:05:09 PM »
 LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~.
Howard, sometimes your humor is so subtle it even gets past me on the first look...
Carried to extreme would this result in an invisible airplane?
Randy C.
« Reply #123 on: December 02, 2012, 08:44:51 AM »
Crist,
Just my 2 cents.  ;D
John,
I noticed that Dual Lock works with the fuzzy side of velcro too.  It's rather persistant!
« Reply #124 on: December 02, 2012, 05:19:20 PM »
Today I sanded the fillets and applied 2 coats of slightly thinned nitrate dope using a small touch-up brush.  After drying, I brushed on the first of the filler coats.  I used nitrate dope, thinner, and some baby powder.  I tried zinc stearate before but didn't like it.  I'll let it dry overnight and tomorrow I'l sand it off and apply a second coat.
« Reply #125 on: December 02, 2012, 05:57:11 PM »
Sounds like it will be RTF by Christmas.  Ho ho ho.
« Reply #126 on: December 02, 2012, 06:36:53 PM »
Dennis,
It would be nice so the dope stink is gone for the holidays!
« Reply #127 on: December 02, 2012, 07:54:31 PM »
A good hour or so.
Or in AZ in the summer time about 15 minutes!   ;D
« Reply #128 on: December 03, 2012, 08:05:23 AM »
Dennis,
Hey, I like the smell of dope.  Butyrate especially. n~
« Reply #129 on: December 03, 2012, 09:12:51 PM »
I sanded the filler coat and then brushed on 3 coats of SIG Lite-Coat clear.  Butyrate from now on and wet sanding too.  Total weight added so far is 24 grams.
« Reply #130 on: December 08, 2012, 10:08:13 AM »
I wet sanded the 3 brushed on clear coats and sprayed on the first coat of gray.  I'm using my airbrush for the spraying.  I can control the spray much better especially around the motor and battery bays.  Once dry, I'll start with the glazing putty.  It looks a lot better in the pictures than in person as usual.   :)
« Reply #131 on: December 08, 2012, 12:55:21 PM »
First application of the glazing putty.  Bondo type.
« Reply #132 on: December 09, 2012, 05:44:13 PM »
After sanding off the glazing compound and shooting another coat of gray and sanding that, I shot the white today.  3 coats with the airbrush.  I'll weigh it tonight and report back.  From bare balsa through the gray blocking coats total weight added is 32 grams.
« Last Edit: August 31, 2020, 09:47:20 PM by Crist Rigotti »
« Reply #133 on: December 09, 2012, 06:38:30 PM »
I weighed the plane.  From bare balsa through the white coats added 44 grams.
From bare balsa through the filler coats added 18 grams
3 coats of brushed clear added 6 more grams  for a total of 24 grams
3 coats of gray and glazing compound added 8 grams for a total of 32 grams
3 coats of white added 12 grams for a total of 44 grams
« Reply #134 on: December 10, 2012, 10:45:24 PM »
Tonight I lightly sanded the white and shot 1 coat of clear to seal the white.  On to the red trim.
« Reply #135 on: December 15, 2012, 07:58:04 PM »
The red trim is on.  I have to trim the flash but it looks good.  On to the blue!
« Reply #136 on: December 16, 2012, 07:33:26 PM »
The blue is done except I have to trim the flash.  I did my usual with the canopy.  I also started on the decals.  Whatta think so far?
Offline Zuriel Armstrong
« Reply #137 on: December 16, 2012, 08:14:35 PM »
I've been following with interest.  I refer to this and you previous build log for guidance.  Beautiful plane and I, for one, appreciate you taking the time to post your procedures.
Zuriel Armstrong
AMA 20932
« Reply #138 on: December 16, 2012, 09:26:53 PM »
Fantastic!
« Reply #139 on: December 16, 2012, 09:53:29 PM »
Thanks Zuriel and Dennis.  Getting close to having the painting finished.  Just in time to clear out the smell for Christmas visitors.
« Reply #140 on: December 17, 2012, 12:45:15 AM »
Really looking good Crist. Great job.
 Larry
Offline Jim Howell
« Reply #141 on: December 17, 2012, 06:52:19 AM »
I think it looks like a winner!
Jim Howell
Huntsville, AL  AMA 545805
« Reply #142 on: December 18, 2012, 09:41:02 PM »
Thanks guys.
Tonight I shot the final coats of clear.  I'll let it sit over the holidays for the dope to firm up and finish gassing off.  The total weight of the finish from bare balsa to final coats of clear is 61 grams.  Includes the rudder and LG spats.
« Reply #143 on: December 18, 2012, 11:46:51 PM »
Very impressive Crist. Very impressive.
 Larry
Online Howard Rush
« Reply #144 on: December 19, 2012, 03:30:56 AM »
Thanks, Crist.  Very informative.
« Reply #145 on: December 19, 2012, 11:16:00 AM »
I think it looks great, Crist, and I hope it flies as good as it looks!
BIG Bear
RNMM/AMM
Offline Ron Hook
« Reply #146 on: December 19, 2012, 06:05:50 PM »
A very impressive looking plane. I noticed that your flaps and elevators are yet attached to the plane. How do you attach these surfaces to the hinges without marring your wonderful finish?
Thanks in advance.
Ron Hook
Ron Hook
Goodyear, AZ
« Reply #147 on: February 02, 2013, 11:36:18 PM »
Ron,
I just noticed your question.  I use Klett hinges which are 2 piece.  I glue 1 half into the control surface, then when dry I use a piece of .032 music wire as a long hinge pin to locate the stab or wing half of the hinge set.  then I glue those in with the music wire still in place.  When dry I remove the .032 music wire then use .025 music wire for the actual hinge pin.  It run the entire length of the control surface and is held in place by a 1/32 eyelet inbedded in the TE of the stab or wing with a small 90 degree bend.  when done I'll include pics.
Today I wet sanded, rubbed out, and waxed the fuselage and rudder.  Hinged the rudder, and attached the landing gear.  Mounted the motor and ESC.
Offline RC Storick
« Reply #148 on: February 03, 2013, 05:47:07 AM »
so Crist on you build log. How much does the log weigh? LL~ I could not resist.
« Reply #149 on: February 03, 2013, 06:58:04 AM »
Funny Bobby, real funny!   :)
