  • June 14, 2025, 12:22:43 PM
Author Topic: Basic question  (Read 6642 times)
Offline John Skukalek
Basic question
« on: November 01, 2024, 12:40:42 PM »
When connecting the three wires from the motor to the three wires from the esc, is there a way to know how to connect them to get the rotation direction that you want? Or is it just trial and error?
Online Steve Berry
Re: Basic question
« Reply #1 on: November 01, 2024, 12:43:05 PM »
Trial and error, for me. Hook it up, turn it on. Correct direction, good to go; wrong direction, switch any 2 wires.
Sent from my SM-N986U using Tapatalk
Re: Basic question
« Reply #2 on: November 01, 2024, 03:28:49 PM »
Some ESC and timers have black/white-yellow/red on both.  I normally color match them up that way with the ESC set to Nornal
 you ger right hand Rotation.  Some come with all black wires.  I think Steve has it right, it doesn't matter but I have, always swapped the red and black.  It always seems easier to swap wires than it does to program the ESC.
Online Dennis Toth
Re: Basic question
« Reply #3 on: November 16, 2024, 06:35:38 PM »
If you plug them in then test the motor (no prop) to check the rotation, if wrong switch any two wires and it will reverse direction.
Best, DennisT
Re: Basic question
« Reply #4 on: November 17, 2024, 07:08:19 AM »
I worked on model changes, modernizations, and new factories in the auto industry.
With 3-phase motors the trained, professional, educated, union electricians just hooked the BIG motors up at random and "bumped" to check rotation.  I guess they could have hit it lucky half the time.
If it was possible to do damage by reversal, they disconnected the mechanical coupling first.
