  • June 21, 2025, 07:16:42 PM
Author Topic: Reverse rotation of motor higher amp draw?  (Read 1708 times)
« on: October 01, 2009, 04:02:37 PM »
Guys,
I have been working with the APCE 12x6P for the last three months or so and have noticed more amp load with this prop (set to the same pitch as the tractor). I checked the amps and for the pusher it was 40.2amps, for the tractor 12x6 it was 34amps. The way I change motor rotation was to switch two leads. Has anyone else checked the amps on their set ups against the puller? Is there a difference in the amp draw if you change direction in the ESP?
Best,           DennisT
Offline Igor Burger
Re: Reverse rotation of motor higher amp draw?
« Reply #1 on: October 01, 2009, 04:24:12 PM »
It could be prop what is different.
Try to use the same prop, reverse the rotation, reverse also motor mounting, so the prop will spin the same direction. Then you will see if there is a difference.
Offline Mike Anderson
« Reply #2 on: October 01, 2009, 06:08:36 PM »
Dennis -
Is that running "wide open" or set to a particular RPM?
Mike@   AMA 10086
Central Iowa
Alan Hahn
« Reply #3 on: October 01, 2009, 07:34:47 PM »
I am guessing that it isn't possible to tweak the props to the same pitch bu simply twisting at one radius. This adds (I think) a constant angle to the original varying angle, which varies as a function of radius. So if you match at one radius by repitching the lower pitch prop, then its tips will actually be over pitched when compared to the other unchanged prop.
I think the fact that the stock APC pusher is less of a load than the stock tractor shows that it is easy to mess up pitch by small errors.
So that is my WAG! y1
« Reply #4 on: October 01, 2009, 08:55:00 PM »
Guys,
RPM is set at 9000 for both pusher and tractor. Lap time 5.0 both. Both props are repitched to 5.6. I have set up several of these props, the way I set the pitch is to lock the pitch gauge arm at the required pitch using a small clamp then pitch each blade. When pitched this way they all hit the same lap time for the same rpm. I agree that there may be some difference in the stock pusher which I found was about 1/2" low on pitch compared to the tractor. But once set to the same pitch as the tractor (the way this was done is to mark the back side of the pitch gauge plate to allow matching the pitch angle once it was reversed for the pusher) it hit the same numbers except for the amps.
My question is has anyone measured the amp draw when reversing rotation by switching two wires then with the wires in the normal hook up (i.e. red to red, black to black, white to white) changed rotation via the ESP and noted any difference?
Best,                 DennisT
« Reply #5 on: October 01, 2009, 10:41:43 PM »
OK - I ran some tests with my setup that I have been flying all summer.  I tried to set up something that would test Dennis' observation, Igor's suggestion, and my own question above - so I set up a motor/esc on a test stand, charged up a couple of battery packs and ran each prop CW, CCW(by programming) and CCW(by wire swapping).  The props were an 12-6 APCe, a 12-6 APC-clone from HobbyCity, and a 12-6 APCep (pusher).  None had been modified, other than normal cleanup and balancing.  Each run had the prop mounted so that it turned the direction it was designed to turn, and the "CW" or "CCW" in the table refers to the motor direction as seen from behind (ie: clockwise is normal rotation for a tractor prop).
As a final test, I ran the two genuine APC's at 7500 RPM and recorded current using the 4s A123 pack to see if the ESC at partial throttle had any effect.
The hardware:
Motor - Turnigy SK3548-1100
ESC  - HobbyCity SuperSimple 50A (Can program direction, among other things)
         (the timing advance was set at 7 deg., and the freq. at 16 KHz.)
Control - Will Hubin's TE-1 throttle emulator
3s2p 4200mah, 20C Hyperion LiPo
4s1p 2300mah, 30C A123 Pack
         Battery - 3s2p Hyperion, 20c, 4200 mah
                           12-6 APCe           12-6 Clone         12-6 APCep
   Dir.               RPM @ Amp         RPM @ Amp        RPM @ Amp
   CW                8100  39.5          8300  42.5          8400  41.0
   CCW(Prog)      8300  39.8          8500  44.5          8500  42.0
   CCW(Wire)      8400  40.5          8300  43.2          8400  41.0
         Battery - 4s1p A123, 30c, 2300 mah
   CW                8400  41.0          8400  44.0          8400  42.0
   CCW(Prog)       8500  42.0          8400  44.0          8500  41.5
   CCW(Wire)       8400  40.2          8400  44.5          8500  43.0
   CW                7500  25.1             --   --             7500  25.2
   CCW(Prog)      7500  25.2             --   --             7500   25.0
   CCS(Wire)       7500  25.4             --   --             7500   25.1
It seems to me with MY setup, direction (however it is achieved) doesn't have much effect on current or RPM for any particular prop.  The small current differences can be attributed to the battery state of charge and the amount of time I allowed RPM to settle before recording the current and RPM.
I should probably add, also, that both of the genuine APC props were checked for pitch earlier in the year and both pitched out almost exactly the same - pretty much 6 in. of pitch at each station.  This measurement was borne out in my flight results - I've only flown the Pusher a couple of times, but lap times are virtually identical (with no changes in my timer settings) to the tractor version and I personally can't tell much, if any, difference in the flight handling.  I've not been able to notice the difference in performance that other's have written about, but have only the one pusher to use.
One last item that may be pertinent is that this is pretty much your 'basic flight package' - and the above is pretty much the way I fly it.  Cheap ESC, 3 cell battery and an SK Turnigy motor - I can't speculate on how a Governor Mode speed control might affect the performance.  I fly the Hubin timer with the 'throttle advance' feature set to give me slightly faster speed at the end of the flight than at the beginning.
Mike@   AMA 10086
Central Iowa
Alan Hahn
« Reply #6 on: October 01, 2009, 10:42:41 PM »
Guys,
<snip>...
Best,                 DennisT
I know for one of my test measurements that I switched directions--primarily to have the high velocity airflow be away from my measuring stuff--it was easier to handle that way, and was a lot less sensitive to my hand movement around the test stand. I don't recall noting anything untoward going on.
Also I will state that there really is no reason to expect the motor rotation to matter at all. The brushless motor is mechanically symmetric in both directions of rotation. Likewise the ESC is picking up the magnet motion as it moves over the stator arms, and that too is completely symmetric. So unless your bearings have a strange problem, I can't see how the motor can be the cause of the problem.
You might try the same test I did (using just one prop), and see what difference the rotation direction makes. You might see some change due to the airflow direction reversal if you leave the motor on the plane.
Actually one asymmetry comes to mind ---is there some type of fan cooling setup on the motor? I don't believe that could matter as much as you see.
But getting back to your original issue, you get the same lap speed after the re-pitching, but see different loads. Taking things at face value says that   for some reason, my interpretation would be that the pusher rotation direction causes extra drag---not sure if I understand this, especially since it is such a large difference. For example, I always see small differences in level flight speeds for inverted and upright. This isn't a lot (compared to what you are seeing), but it is noticeable both in power draw and even in the lap times.
But finally, my guess is still my first guess, but slightly altered to fit your "facts"! y1   If you are getting the same lap speed with different prop loads, then the prop with the higher load pitch distribution has got to be less efficient. So are you sure the pitch is the same at every station?
If that is the cause, then I am becoming very impressed with the way APC designs and makes props! H^^
« Reply #7 on: October 02, 2009, 09:26:09 AM »
I think Alan is on to something about the props especially if both are modified but (possibly) a little different.
In our tests of 12x6 pusher vs tractor we also concluded that they behaved the same (needed same RPM) Rick Sawicki did the test and concluded that he needed to SLOW the pusher to get the same airspeed as the tractor - this is NOT the same experience that others have reported!
I am wondereing if the flight trim is starting to come into play here.  My supposition is this: the slipstream effects off the pusher increase line tension.  If you have a bird trimmed out using a RH prop then just swap props the effect could be additive to the point where it actually seems like the bird is crabbing o'b and requiring more power to fly.  it takes less power to fly around the circle then to crab out.
When Crist made the change (see his thread on the 570 profile) he noted that his bird seemed to settle down on the end of the lines.  That could be amanifestation of the reversed slip stream.  BUT he also reported having to run a little faster.  I do not recall that Crist ever re-trimmed for the pusher...?
We had the Strega trimmed out with the 13x4 tractor, switched to the new 13x4.5 pusher and ended up moving the leadouts about 3/16" forward.  we have actually run out of room to move any farther forward - unless I can reach in a remove a couple shear webs so the back line can clear.
I guess this is a round-about way of suggesting that when we change from tractor to pusher, the flight trim should ALSO be changed?  Ironically the better the bird is trimmed & optimized for the tractor prop, the more things MIGHT have to change for the pusher.
« Reply #8 on: October 02, 2009, 10:29:15 AM »
Mike,
Nice test data, seems to match with my static load amps. Also seems to say there is no significant difference in the method of reversal. Maybe this weekend I will have some time to do the test on mine. Could be that something else in my setup caused the difference.
Best,             DennisT
Offline Dean Pappas
« Reply #9 on: October 02, 2009, 01:06:18 PM »
Yup,
The leadouts move forward, at least that's what Bob and I found.
Dean P.
Dean Pappas
Alan Hahn
« Reply #10 on: October 02, 2009, 01:39:04 PM »
So now I am wondering if you can get substantially the same effect with a little right thrust.
Moving the leadouts forward tends to pull the nose back into the circle.
Offline Dean Pappas
« Reply #11 on: October 02, 2009, 08:25:00 PM »
No Alan,
the reason is this: anything that increases the spiral airflow, like a slowdown in airspeed at fixed RPM or an increase in current and torque as the governor kicks in, will impart more right rudder yaw as it happens. It is the right thing for what happens as you go above 45 degrees. Normal prop rotation will always be in the wrong direction.
The forward leadouts reduce line tension when the plane is moving faster and centrifics are good, but the rudder, right-thrust and now correct direction spiral airflow effects yaw the nose out to help when either the airplane slows or when the governor "throttles up".
I think you had figured this out already!
best regards,
Dean P.
Dean Pappas
Offline Bill Ervin
« Reply #12 on: October 02, 2009, 10:06:45 PM »
Aha, good post Dean.  Brought it all together for me.  Thanks!
But now it begs the question, one could surmise that, ostensibly, a rudderless ship wouldn't benefit from the now correct direction spiral airflow.
Should Mr. Hunt add a conventional rudder to the Genesis?
Tags: pusher
