  • July 22, 2025, 02:57:37 PM
Author Topic: Aluminum spinners  (Read 1743 times)
Offline James Mills
Aluminum spinners
« on: June 21, 2017, 04:52:09 PM »
I have a stash of Randy's spinners that I'd like to use on my electric set up.  I'm using the Hyperion prod adapter (HP-ADAP-50XL) and the collett doesn't fit.  What adapter do I need to make this work?
James
AMA 491167
Offline Alan Resinger
Re: Aluminum spinners
« Reply #1 on: June 21, 2017, 05:09:14 PM »
James,
The shafts on the unit you have is more than likely metric.  You will need to get someone to make your a long nut with the metric thread going in one side and the standard 1/4 - 28 on the other.   Jim Lee could probably do it for you.
Alan
« Reply #2 on: June 21, 2017, 05:47:34 PM »
James
Hi James.
I believe it has the M6 thread, which is the same as the AXI prop adapter for rear mount.  Pat Mackenzie makes the M6 to 1/4-28 thread x1" adapters.  I got a couple from him just recently and they're quite well made.
Infos are in the post below.  (reply #9)
http://stunthanger.com/smf/gettin-all-amp'ed-up!/axi-question/
Online Dennis Adamisin
« Reply #3 on: June 22, 2017, 05:59:09 AM »
Hi James
Brodak has an M8 to 1/4-28 adapter, #BH-1900
Offline James Mills
« Reply #4 on: July 04, 2017, 05:20:37 PM »
I spoke with Jim Lee and he made me 2 assemblies that work perfectly, I can't recommend his services enough.  A BIG THANKS JIM.
James
AMA 491167
« Reply #5 on: July 05, 2017, 01:18:46 PM »
Huh. I use an EFlite Power 32 motor with an ElectriFly collet adapter and a Randy spinner without issues.
