  • June 17, 2025, 08:22:22 PM
Author Topic: Ring Gap  (Read 17164 times)
Offline pat king
    • PDK LLC
Ring Gap
« on: December 07, 2009, 07:28:38 AM »
What should the ring gap be for a 2 ring Enya 60 II Model 7032?
Thanks,  Pat
Pat King
Monee, IL
AMA 168941
Offline Frank Bowman
  • Bowman's Rings
Re: Ring Gap
« Reply #1 on: February 09, 2010, 10:10:31 AM »
Hello Pat, On All of my Custom fine grained Cast Iron rings I go by machinest Hand Book standards . For rings to 1" bore .001 to .0015 is best steel or chrome liner no difference. Above 1" bore or approx .70 & up .0015 to .0025. For the Enya 60 my low tension rings with a 2 ring piston will last quite a long time and an increase in power. Thanks Frank :)
Frank Bowman
Offline pat king
    • PDK LLC
Re: Ring Gap
« Reply #2 on: February 17, 2010, 09:00:20 PM »
Frank,
Thanks for the info. I put in a set of factory rings I had in my stock of parts. When I need rings in the future I'll give you a buzz.
Pat
Pat King
Monee, IL
AMA 168941
