  • June 19, 2024, 11:51:31 AM
Author Topic: Tight bend 90 deg exhaust header for Saito 56  (Read 2641 times)
« on: October 26, 2022, 12:41:18 PM »
Anyone know if Saito or a aftermarket seller has a tight bend 90 deg exhaust header for the Saito 56? I want to have the header and muffler more inline with the fuse side rather than sticking out at 45 deg. Also what is the thread size for the header nut?
Best,    DennisT
Update: I found this website that has both a 90 deg fitting and a aftermarket muffler that is 90 deg. Here is the site:  https://www.rcspecialties.net/products.php?model=TH10X1A
« Last Edit: October 26, 2022, 09:00:36 PM by Dennis Toth »
Re: Tight bend 90 deg exhaust header for Saito 56
« Reply #1 on: November 04, 2022, 04:17:20 PM »
I understand that it's a specialty part.  But $69.95 plus shipping?  You really gotta want the "look".
Mark
« Reply #2 on: November 04, 2022, 09:14:40 PM »
  The stock elbows are steel, I believe.  The elbow in my Saito .56 is bent to a 90. Crist Rigotti assembled the model and the engine and he said he sent it off to some one to bend for him. Old school procedure would be to fill the tube with fine sand, then heat it to bend it. I think I have seen that some one, maybe even Sait6o and Horizon Hobbies offered an accessory 90 bend exhaust elbow in more recent times.
Offline bill bischoff
« Reply #3 on: November 05, 2022, 12:01:27 PM »
SAI50163 from Horizon Hobbies $33.67  miter cut and welded 90 deg. elbow, steel, 10mm male threads on both ends. In stock.
« Reply #4 on: November 08, 2022, 07:27:39 PM »
Any idea if the hard 90 header backpressure affects the engine run?
« Reply #5 on: November 09, 2022, 04:47:05 PM »
  Yes, that would be my concern. It's pretty short also, and you do want a little clearance from the fuselage side. I have never seen any other kind of performance engine exhaust have such a tight turn. I would think it would increase back pressure a bit.
« Reply #6 on: December 20, 2022, 07:19:22 AM »
Is there a reason these headers are steel rather than aluminum? I know they don't want similar metals to prevent galling but since the head is aluminum why not an aluminum header pipe with a flared end and steel nut?
Best,    DennisT
