  • June 30, 2025, 12:21:56 AM
Author Topic: Stuck exhaust valve  (Read 20906 times)
Offline Robertc
Stuck exhaust valve
« on: October 16, 2022, 10:20:15 AM »
Saito 91 with very stuck exhaust valve and also the tiny bolt that holds the rocker arm won't budge.  Have tried heating to 250 degrees, putting WD-40 but still won't move.  If I bang lightly on the rocker arm, can get the valve to open a tiny amount, but won't go back or open.
Any ideas?
Online Tim Wescott
Re: Stuck exhaust valve
« Reply #1 on: October 16, 2022, 11:46:26 AM »
Aero-kroil is like WD-40 on steroids.  I don't know how it works on castor, but on rust it's the bee's knees.  If you're down to penetrating oil and heat, the best thing to do is to be patient and keep trying.  You're hoping the oil will seep into some very narrow spaces, and that takes time.  Spray, let it sit, heat it up, tap it gently, then repeat once or twice a day until you're either successful or so fed up you're ready to damage things to get it apart, and buy new pieces.
(Or -- eww -- hand it off to an engine expert).
« Reply #2 on: October 16, 2022, 12:55:23 PM »
  Yeah, this is a patience thing. Oil, some heat and some gentle pressure. Save the WD-40 for something else. Try the Kroil if you can find it near you, or for a spray can I like PB-Blaster, I think it's a good second choice to Kroil. I understand that ATF and acetone mix works pretty good also if you have no other choice. Mix 50-50. Cycle the heat and oil as you can. If get the valve to move by lightly tapping it, make sure you oil it again right away, heat it and try returning it to the original position. Then more heat and oil and go back the other way. The back and forth action will help. Patience and pressure and keep it oiled and you will get there.
Online Tim Wescott
« Reply #3 on: October 16, 2022, 08:57:25 PM »
Looks like there's a bazzilion places that carry Kroil mail-order.  So if you don't mind doing that, you're all set.
« Reply #4 on: October 26, 2022, 08:14:28 AM »
Robert,
It sounds like the valve stem could be bent and causing the valve to bind. I would first try some targeted heat from a small propane torch like a "Super Cub Propane Touch" or maybe even a candle lighter to heat just the head/valve guide area and see if it moves.
Best,    DennisT
Offline Robert Zambelli
« Reply #5 on: November 22, 2022, 06:26:22 AM »
Dennis is right on.
When flying RC, people will often put a plane into a fast vertical dive.
The prop can windmill causing the engine to over-rev, allowing the valves to float.
At that point, there will be interference and the piston can hit a valve, bending it.
A long time ago, I bought a used SAITO 40 with a stuck valve.
After dissassembling it, I found a small crescent-shaped mark on the piston crown and a bent valve.
Fortunately, the valve guide was not damaged and installing a new valve solved the problem.
The engine ran perfectly.
When you reassemble, you need a special tool to properly set the cam/crankshaft relationship.
The tool is very easy to make if you have a small lathe.
Let me know if I can help.
Offline spare_parts
« Reply #6 on: November 22, 2022, 08:04:44 AM »
Bob, I would guess the valve was stuck when someone tried to turn it over, or it was mis-timed previously. Few engines are interference by design. The RPM at which the valves float in RC engines is well above what you might observe in a dive. Doppler has an impact on what you hear. I've never seen or heard of an engine stopping due to a bent valve in flight.
Not my video, but if this didn't float and bend a valve at 15,500, what kind of RPM would it need? The FS-52S and old FA-40S was run out to 17k. I have no comment on the power figures.
Stuck valves are usually varnished. I strip engines like this unless it's obvious the crankcase isn't gummed up just as bad. The last thing you want is a plugged up big end oil feed hoping it clears up before failure.
Greg
Greg
« Reply #7 on: November 22, 2022, 10:36:28 AM »
Hi, Greg - good points.
The engine I was referring to was not the engine in the video but a very old SAITO 40.
I spent considerable time with one of the engine technicians at Horizon Hobby, the SAITO importers at the time, probably more than 20 years ago.
They also suggested that the issue might be due to over-revving, as they had a number of engines returned with similar issues.
Depending on the severity of the float, the momentum of the moving valve could carry it past the point of interference.
Regarding improper valve timing, that could well be the case. I just dissassembled the engine without checking.
In any case, with quite a bit of four cycle experience, I have never had a stuck valve due to varnish.
I have used straight castor, 50/50 castor-synthetic and straight synthetic.
« Reply #8 on: December 08, 2022, 03:20:03 PM »
Robert,
I saw an old Windy video when he started working with the four strokes and there was a short discussion about how the exhaust valves could stick if the engine was run with a lot of castor. They indicated that you need to check the valve stem for baked on castor and carefully polish it off with something like a Scotch brite like getting the baked on castor off a Fox head.
Best,    DennisT
« Reply #9 on: December 09, 2022, 09:39:39 AM »
 Hi, Dennis.
You are absolutely right.
Straight castor and even 50% castor will cause serious carbon accumulations on the exhaust valve.
My recommendation is 20% total oil, and no more than 5% of that castor oil.
Many very successful 4-cycle flyers go with 20% full synthetic and 20% nitro.
