CLICK HERE--><--CLICK HERE
Saito FS 72 sagging above 45 degrees
Started by Paul Van Dort, September 29, 2026, 07:57:04 AM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Lauri Malila
Actually, I was wrong. I have studied the 4-strokes quite a lot.
If you neglect all the crap that people use and talk and really put your mind into it, it starts to seem that 4-stroke is an ideal powerplant for us.
If you forget the mechanical complexity and look at it strictly from acoustic and gas dynamic point of view 4-s is really nice because acoustic interactions and flow paths have been reduced to minimum. Those 2 things are the 2 main problems in 2-strokes in our use.
There are other reasons too that come from structural and metallurgical things, which are mainly caused by requirements of mass-production and laziness, but they are easy to deal with.
Stunt people have a bad habit of playing with leftovers, while engines in other categories have evolved to serve better the requirements.
We started to plan this 4-stroke thing after long discussions with Yuriy Yatsenko. Even after spending nearly 40 years to perfect his 2-stroke designs he came to same conclusion; there must be a better way to do it.
I have already made my 10oz/290g 2-stroke .77's that despite of low weight are much more stable than anything else, so I started thinking that if I made a 4-stroke with similar metallurgy (Monolithic AAC wit Dykes ring, barstock- or printed case and DLC on critical surfaces), it could well be as competitive as any IC engine can be anymore.
after the first calculations it looks like in .75..77 size the weight would be 300...320g.
As a mechanical solution I find the HP (.49) rotary valve really interesting and worth developing. The HP engine itself is quite useless, very heavy and otherwise weird, but the idea is really genius. You can forget the fragility and wear of cams and classic valve systems, which also makes the engine very very quiet.
We'll see what this brings, now I just need time and motivation. L
Paul Van Dort
Dear friends, I really like the way this topic is evolving. You all know by now that I am stubborn, and therefore a bit cripple, some diseases and a hole in my foot. But besides that i am doing well, thank you very much  :-) .
As I see it, the fueltank has only 2 purposes. In CL aerobatics, but basically in many model areas:
Purpose 1. Making sure that the feedpipe is always containing fuel, without airbubbles, until empty. 4 stroke engines are particulary sensitive to this, because they don't use the enginecarter like 2 strokes do. In 2 strokes the mixture first passes the carter and eventual small fuel feed issues are dampened there. In 4 strokes, the fuel goes from the spraybar in the cylinder. Period. Any airbubble can and will stop the engine.
Purpose 2. Keeping a constant pressure at the carb/ venturi, regardless of the amount of fuel in the tank and regardless of the attitude of the model (upright /inverted) .
In my opinion, purpose 1 can best be achieved with a clunk tank, where the clunk will be following the fuel to some extend. It might be possible that the fuel moves too freely in the tank and the clunk still can become uncovered and suck up air. In that case a baffle can help reducing the movement of the fuel. For all clarity, the location of the feedpipe/ clunk combination is not responsible for the pressure of the fuel at the spraybar. Beware, convictions on this vary amongst specialists.
Purpose 2 is best achieved with the uniflow principle. Having this uniflow exit in the tank as close as possible to the engine will result in the least pressure differences at the spraybar. Independent of the attitude of the model. The height of the uniflow w.r.t. the spraybar will define the difference in pressure between upright and inverted. Can be tuned in a similar way as the principle of moving tanks up or down. Important is to keep the uniflow exit and the clunk separated to avoid that airbubbles migrate from uniflow to the clunk. Clunk at the back. Uniflow at the front seems reasonable to me. Beware, convictions on this vary amongst specialists.
There you have it. Now the carburetor/ venturi should create sufficient negative pressure to draw the fuel. Muffler pressure can help, but I hate the risk of backward starting (I don't have an electric starter). On the other hand, too much negative pressure makes adjusting of the needle very difficult and sensitive. In my case the engine creates a negative pressure of 10 inches water. Too much in my opinion. This fact is probably responsible for the issues I am having and i have posted here . the reason for this huge suction is the fact that I choke the air inlet of the engine with a restrictor of e.g. 5mm for less power. Seemed like a good idea, but probably a bad practice....
In attachment you will find the tank that I am using. It is a very short tank, but very wide and it sticks out of the fuselage at the lefthand side. It is metal with a clunk and a baffle. The uniflow is adjustable from standard to full uniflow and the height matches the height of the spraybar of the engine. The uniflow acts as overflow as well...
Lauri Malila
Paul,
Have you tried a fuel tank with more classical proportions? I mean narrower and longer.
It's not really a good idea to start with something that different without knowing what a standard setup would give.
Quote from: Lauri Malila on October 09, 2026, 07:28:23 AMPaul,
     The tank configuration is definitely something different that we don't see in this part of the world. Om studying your illustrations, my biggest question is the location of the uniflow and pick up tubes being at the top of the tank and the bottom, respectively. being much more wide than long is an interesting concept, but I would think it acts just like what we call a coffin tank used in C/L speed, where the tank is widest at the front where the pick up tube is, and centrifugal force always pushed the fuel load that way as the model speeds up. That does increase the fuel head pressure but that is regulated by the needle valve. If I had to make a guess, it's the tube configuration that may be causing the problem. There have been several videos posted in recent years where the pilot mounts one of those very small video cameras on a profile model where we can see the fuel load in one of those transparent Sullivan fuel tanks as it goes through the pattern. The fuel load gets pushed to the outboard side of the tank, and really doesn't slosh around. In the case of your tank configuration, as long as the fuselage isn't yawed out excessively, your pick up tube should be staying covered, but the uniflow tube might not be. Changing the tank over to standard venting would be a simple and easy test, since you say you can do that. I just have a feeling that the tank is "confused" above 45 degrees. Most of us are used to having the pick up tube ( where it is located in the tank and taking in fuel) is usually in the center, and the uniflow tube ( if used) is also. Raising and lowering either tube will alter the run in upright and inverted flight. Even though you tank configuration is so different, I think that matters in your case also. And the concept that four strokes don't like uniflow may be worse in your case also, or maybe not??? It's difficult in a best case scenario to try and diagnose something long distance, and especially something that different. I find it interesting, though, so keep us informed.
Paul Van Dort
Quote from: Dan McEntee on October 09, 2026, 09:04:43 AMQuote from: Lauri Malila on Today at 07:28:23 AM
Paul,
  I have been using standard uniflows for all my 2 stroke engine. Tin and plastic, clunk and fixed feed. Always happy  with them and able to adjust where needed. The 4 stroke is for me a different case. The nose of the model is shorter and I don't want to compromise the rigidity of the nose too much. The nose is build according to the principle of the Skywriter of Arden with input from Kim Doherty. Therefore I have a small cutout in the nose,  just to accommodate the tank. Engine is on its side, cylinder pointing outwards. I like to try out things. Calling it innovative would be too much honor.. :-)
For the uniflow principle, there is no correlation between uniflow and pickup. Uniflow regulates the pressure, pickup needs to be IN the fuel.
Being much more wide than long is an interesting concept, but I would think it acts just like what we call a coffin tank used in C/L speed, where the tank is widest at the front where the pick up tube is, and centrifugal force always pushed the fuel load that way as the model speeds up. That does increase the fuel head pressure but that is regulated by the needle valve.
The pick up in my design is still at the back to cover for yaw out. The clunk travel is limited by the baffle, not to cause fatigue in the connection of the silicone to the copper tube. Centrifugal push on the fuel is completely countered by the uniflow principle. Standard venting would make this type of tank lean out too much as the flight progresses.
It was my worry that the a sudden loss in line tension might push the fuel away from the pick up. Therefore the baffle. Perhaps it is useless, but it adds to the rigidity of the tank. it should do no harm. I hope :-) ...
The uniflow principles works until the uniflow is uncovered by fuel. From then onwards the leaning out will start. It is a smooth transition.
I did not show it in the drawing, but the uniflow tube can be pushed in and pulled out of the tank to adjust. This way I can define when I want the engine to lean out a bit for the overheads etc. I did not do this so far.
I assume that standard venting (removing the uniflow tube) would give too much pressure difference between start and end of the flight The tank is about 5 inches wide. A lot of fuel head... I have been flying some contests with this uniflow configuration and the principle works. (Model needs some more trimming) Just lately I am having this issue with losing power in the overhead. In the mean time I swapped to a Saito 82, I adapted the RC carb with an insert of 6 mm, velocity stack and got rid of the restrictor. Ground runs sound promising. Still need to test in the air. I will keep you informed. In any case I am having a good time experimenting and reflecting and assessing your great inputs
Mike Alimov
Paul, based on your tank drawing, your fuel pickup tube is approximately twice the length (width?) of the tank due to the internal loop. Plus the photo shows a generous loop of silicone tubing outside the airplane. I think this is the reason for leaning out overhead. It's like trying to drink milkshake through a 50 cm straw.
Paul Van Dort
Quote from: Mike Alimov on October 10, 2026, 05:56:03 AMPaul, based on your tank drawing, your fuel pickup tube is approximately twice the length (width?) of the tank due to the internal loop. Plus the photo shows a generous loop of silicone tubing outside the airplane. I think this is the reason for leaning out overhead. It's like trying to drink milkshake through a 50 cm straw.
It is indeed rather long and it is giving me problems when the temperature changes because of the viscosity changes of the fuel. The longer the pipe, the more effect of viscosity on the flow. But once adjusted and with sufficient netative presure in the venturi I should be ok. The flow resistence does not change once adjusted. I assume. Next tank will have wider piping...
Peter van de Mortel
QuotePaul Van Dort #26
October 09, 2026, 07:03:07 AM
Maybe not where the problem is and maybe you are using it already but a sintered bronze clunck will reduce the chance of unwanted airbubbles in the feedpipe.
Paul Van Dort
Quote from: Peter van de Mortel on October 11, 2026, 03:30:13 PMMaybe not where the problem is and maybe you are using it already but a sintered bronze clunck will reduce the chance of unwanted airbubbles in the feedpipe.
Very interesting, Peter. I was not aware of that. Do you need to clean the sintered clunk periodically?
Peter van de Mortel
QuoteYesterday at 11:53:14 PM
Feedpipe will also get fuel (from the clunckvolume) when the clunck is very shortly not submerged, preventing airbubbles into the feedpipe.
I used Sullivan 6 oz. slant oval tanks with sintered bronze cluncks on a few aircraft. I have no experience  with 4-strokes, these aircraft were equipped with 2-strokes. The fuel was filtered a minimum of 3 times before it entered the fueltank (1e before entering fieldjug, 2e and 3e from fieldjug to fueltank). I only cleaned the cluncks every winter but never saw much dirt.
Alternatively you could use a felt-clunck.
Paul Van Dort
A drastic decision : Replaced the Saite 72 with an 82. Fixed RC carb wide open with 6mm insert, idle needle removed.
Instant cure. Too rich but flyable in the first few flights but now full patterns on 140 cc fuel, compared to 130 cc for the 72. Easy needling, not sensitive on the needle at all. What I notice compared to the .72 is that the breather nipple is throwing much more oil. The 72 was throwing hardly any, regardless of lean or rich. There must be  something wrong with the 72, but for sure the breather nipple is not blocked.. Needs more investigation and testing on the stand. I am not giving up on the 72 just like that... Thanks for all the help!!
Paul Van Dort
Dear friends, I have put the 72 on a teststand and it behaves normally. RC carb wide open, idle needle removed and idle needle hole closed with epoxy. I notice that very little oil is exiting the breather nipple, but it is not affecting the running apparently. So easy needling, sufficient power. No issues... In the mean time I have been reflecting more. Referring to the attached drawing: In the model I had installed a tube to bring the airinlet to the outside of the model, originally intended to facilitate chocking while starting. However I found out that the power of the 72 was too much for the model, so I added a restrictor to tame the beast. I tried to tune the power with different sizes of restrictors and it appeared to work great. For the hotter summer days, I used an inlet a few tenths of mm larger. I did not notice the problems immediately, but needling became much more critical and the sagging above 45 started. Lately (yes very late, I know :-( ) I realized that the airstream is not a constant flow, but pulsating. These pressure waves become very "interesting" with enlarged intake volumes, changing RPMs and a restriction at the air entry. The dynamics of this complete system from restrictor all the way to the valves is probably super complex and is affecting the fuel draw in the venturi. For larger single cylinder motorbikes great care is taken of the volume behind the airfilter and in front of the carburator. Airboxes are installed to dampen the pulses for improved carburation. I suppose I learned the hard way. But still I learned something new, just by playing with little airplanes :-) .
spare_parts
The intake restriction(throttle / undersize venturi) should be at the spray bar. You could have any length of intake snorkel ahead of a proper venturi / spray bar and it wouldn't change anything at this scale/rpm. Effectively you have a choke on the engine. Airbox design is interesting, but nobody puts a choke or throttle upstream of the carb.
The 72's ring just seals well. This results in less blow by and oil flow though the breather.
Greg
Paul Van Dort
Quote from: spare_parts on October 16, 2026, 08:47:12 AMThe intake restriction(throttle / undersize venturi) should be at the spray bar. You could have any length of intake snorkel ahead of a proper venturi / spray bar and it wouldn't change anything at this scale/rpm. Effectively you have a choke on the engine. Airbox design is interesting, but nobody puts a choke or throttle upstream of the carb.
Thanks for the feedback. The fact that the ring seals well also reduces fuel consupmtion apparently. the 82 uses 10 percent more fuel for a flight. The choke on the intake snorkel was not the best idea. It works ok for some diameter, but clearly not for all. I now better understand the pulsating nature of the flow and the ill effect it can have on airspeed in the venturi . I was able to tame the engine with a 4.8 mm restrictor, sensitive on the meedle, but good runs. Things went "off" from dia 5.0 mm . I will surely try a reduction of the venturi size, like I did for the 82.
Lauri Malila
The restrictor at the end of plenum chamber makes the amount of restriction total guesswork. It depends on volume and frequency, and temperature becomes a factor too if the volume is big enough.
That's exactly why in some categories, like in F2D, the volume between Venturi choke and crankshaft is regulated in the rules.
Maybe it's just me, but I think you are going in wrong way when you are adding these additional complications in order to make things more stable and logical. The right way would be to simplify. a simple Venturi in turbulent air behind cylinder, and possible using the whole engine compartment as a plenum chamber is already a better and more stable option than front facing Venturi in airstream, like we see in most 2-strokes, plus it has other self-stabilising effects that may  be helpful.
I think you should get rid of the rc-carburettor, no matter how reliable you think it is, and look at something like the Beringer Venturi. L
