  • July 06, 2025, 11:35:45 PM
Author Topic: Saito AAC engines  (Read 22246 times)
Saito AAC engines
« on: January 17, 2023, 04:39:23 PM »
Do the Saito AAC engines have a ring or lapped? I have a new FA 30S Golden Knight and just flipping it seems like the normal ring type of compression. I know all FS use blowby to lub the bottom end so the fit is like a worn-out engine to begin with. Just curious if they use some kind of ring with a controlled amount of blowby.
Best,   DennisT
Offline Robert Zambelli
Re: Saito AAC engines
« Reply #1 on: February 02, 2023, 08:14:32 AM »
Dennis:
I have every SAITO engine from the .30 up to the .62.
I believe the .30 has a lapped piston but everything larger has ring(s).
In any case, I will check them out and get back to you.
The .30 and the .40 are my two favorite 4 cycle engines.
Offline spare_parts
« Reply #2 on: February 02, 2023, 11:13:34 AM »
AAC does not mean ringless. Saito chromes the aluminum jug in AAC engines. Only a handful of four stroke engines were ever made ringless. The very first FA-30, FA-40, FA-45 (late 70's ?) with bolted head instead of the jug cylinder, Enya 35-4C of the same era, and the more recent OS FL-70.
Greg
