  • August 02, 2025, 04:42:11 AM
Author Topic: Tanks for 4-Strokes : Uniflow or Standard ?  (Read 2353 times)
Offline Robin_Holden
« on: April 10, 2012, 07:03:47 AM »
Greetings guys from a windy Charente.
Which do you prefer for 4-strokes ?
A Uniflow tank [ with or without muffler pressure]  or .....
A Standard stunt tank [ with or without muffler pressure ].
Much obliged for any contributions ,
Robin.
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: Tanks for 4-Strokes : Uniflow or Standard ?
« Reply #1 on: April 10, 2012, 02:29:42 PM »
Plastic clunk tank plumbed just as the instructions that come with it shows, vent positioned in the top front inside corner on muffler pressure. All synthetic fuel, (no Castor at all) plus a means to adjust the intake choke area. You can't use the needle valve to adjust speed and why the choke area needs to be adjustable.
The reasoning and results behind this advice has been posted many times, you will learn allot by reading past posts in this section.
Offline Mike Callas
« Reply #2 on: April 10, 2012, 02:30:05 PM »
RC Clunk tank muffler pressure
