  • July 07, 2025, 12:10:45 AM
Author Topic: Saito .40  (Read 11597 times)
Offline Gerald Schamp
Saito .40
« on: April 04, 2010, 08:53:21 PM »
Hi All,
I've been running some Saito .40 four strokes for awhile and find that it is an incredible engine with lots of power. Currently I have one in a Pat Johnston profile Corsair and it works great. This plane has a really thick wing and a lot side area. Does great. Am wondering though how big a plane this engine will really handle, in comparison would it fly something like a Fancher Imitation? Of course the weight would have to be kept manageable, but is this realistic place for this engine. Going up to the next size engine seems like having to go to a larger airplane, like a Saturn size and really didn't want to do that. Any sugggestions would be greatly appreciated.
Thanks much,
Gerald Schamp
Offline schuang
Re: Saito .40
« Reply #1 on: April 05, 2010, 06:27:11 PM »
Gerald,
I am not sure about the size of Imitation, but I am using Saito 40 to pull a Fury (577sqin, 44oz) with line tension everywhere.  The line length is 61ft (eyelet to eyelet) and I am using 15% nitro during the winter.  Tucson elevation is around 2800ft so I may use 20% nitro during the summer time.
Sean
Re: Saito .40
« Reply #2 on: April 05, 2010, 09:53:30 PM »
My Saito 40 is it baby!! As someone who has been around model airplane engines virtually all of my life, the Saito 40A is without doubt one of the absolute finest pieces of hardware I have ever owned!
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: Saito .40
« Reply #3 on: April 06, 2010, 09:52:58 AM »
Don't think anyone has ever really pushed it's limits. I'm running two and both have more than needed for what I'm flying. One is a Ringmaster 576, 576 sq/in at 46 ounces the other is a big Shoestring that uses a Brodak P-40 ARC wing at about the same weight as the Ring. Don't think I would put one in something over 50 ounces but I like more power available than whats really needed as it's easy to run out of power in Oklahoma wind.
It would be nice if Saito had something between the 40 and 56 but think it would be a niche that maybe only CL guys would be interested in. My 46 size RSM Skylark would be a good candidate for this tween engine. It's really too big for the 40 and the 56 would be much too heavy. Right now it a ST 51 and does OK when the engine decides to behave.
Re: Saito .40
« Reply #4 on: April 06, 2010, 12:22:08 PM »
Thanks all for your feedback. The Fancher Imitation is about 620 Sq. in. I am pleased with the power this engine has. I have been running SIG Champion fuel, 10% nitro with the 10/10 blend of lube. I have been recently told that I should not be running fuel with any Castor in it as this gum up the valves. I haven't tried running the engine on the new fuel, 20% nitro with all synthetic lube, so I can't compare yet. Was running an 11 X 5 Rev-Up prop, but not quite enough pitch although the plane stayed out on the lines just fine on 62' line eye to eye, lap times were a bit slow at 6.0, really. Could eat a sandwich between manuevers, but while it was kinda fun, more pitch was needed. I am ready to try an APC 11 X 7 and see what that does. The Corsair is a big plane, 600 plus sq. in. and with a huge profile fuse. So the engine will work no doubt about it. Was just trying to find out what the capabilities are.
Gerald Schamp  H^^ H^^
Offline Bob Reeves
Re: Saito .40
« Reply #5 on: April 06, 2010, 02:50:36 PM »
Look at the Saito 40 prop thread and order you some Thunder Tiger props.
http://stunthanger.com/smf/index.php?topic=13100.0
Set your engine for 8400 and it will be doing right at 5 second laps on 60-61 foot lines.
Never ever run less than a 6 pitch prop on a Saito 4 stroke and the only reason I say 6 is because some are making them work but not sure how well. I'm not running anything less than 6.5 on the 40's and as high as 7.5 on my 56's.
Re: Saito .40
« Reply #6 on: April 06, 2010, 06:12:17 PM »
I have never run anything less than 6 pitch on any of my Saito's. They are not really designed for that low pitch high RPM business. When you stick the nose of a Saito up, (say, a reverse wingover) they don't fall off like a 2 stroke. They run more like a Toyota Tundra.
Willis Swindell
Re: Saito .40
« Reply #7 on: April 09, 2010, 06:14:53 AM »
I had a Saito 40 in a Time Machine 50. I don’t think I would put it in any thing bigger. The 50 is about 600 sq. inch with a very thick airfoil.
How about the Saito prices at Horizon and free shipping.
Re: Saito .40
« Reply #8 on: April 09, 2010, 08:06:57 PM »
Thanks for the picture Willis, that is exactly what I was looking for. I am considering this size plane, only a profile fuse. Actually have the fuse and tail feathers framed up. I am going to use Randy Smith's Vector wing, pretty much all Vector. This is the mid size Vector not the .40 or the SV-11. It should work pretty well, film and rattle can finish, trying to keep it light as posible.
Thanks, oh and by the way, I got some of the TT 11.3 X 6.5 props too, 3 days to get them, wow.
Walter Hicks
Re: Saito .40
« Reply #9 on: April 10, 2010, 01:28:34 PM »
Gerald ,
    You may want to try - Master Airscrew  11x7 Beechwood Props, Rev Up 11x7,Pro Zinger 11x7,tt11X7.7.top Flite 11x7,11x8- Coming soon.
Re: Saito .40
« Reply #10 on: April 12, 2010, 02:56:15 PM »
Thanks Walter, I really appreciate them.
Gerald  H^^ H^^
Offline Mike Callas
Re: Saito .40
« Reply #11 on: August 08, 2010, 05:42:09 PM »
Guys,
I'm looking for a motor for a TF Nobler. Would a Saito 40 be enough. It seems pretty light. How heavy and much wing area is appropriate for the Saito 40??
Offline Allan Perret
  • Proverbs
Re: Saito .40
« Reply #12 on: August 09, 2010, 06:11:20 AM »
Guys,
More than enough,  TF Nobler is smaller and lighter than most of the designs discussed above.  Nobler was designed for Fox35,  some guys fly them with strong .25's.
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Mike Callas
Re: Saito .40
« Reply #13 on: August 09, 2010, 11:49:50 AM »
Thank you Allan
« Last Edit: August 09, 2010, 03:15:20 PM by Mike Callas »
Re: Saito .40
« Reply #14 on: August 09, 2010, 06:07:50 PM »
Guys,
I own a Saito 40A weight 45-50 oz. Saito 40A is a 550sq. class engine.
Offline Mike Callas
Re: Saito .40
« Reply #15 on: August 09, 2010, 09:49:48 PM »
Bought a Saito 40 today. Will be in the Nobler this Thursday.
Thanks guys
Offline Robert Zambelli
Re: Saito .40
« Reply #16 on: August 10, 2010, 12:43:05 AM »
Mike - I have the Brodak Nobler and I have flown it with a number of different engines, including the SAITO 30 and 40.
The 40 was way more than enough power. The flying weight was around 46 ounces and for me, it was a bit too much power.
I think the TF Nobler is a bit larger than the Brodak version so it may be a better match to the 40. Remember, you can always throttle it back a bit.
With the stock length nose, I can almost guarantee that you'll need quite a bit of tail weight.
For what it's worth, I flew the Brodak profile Cardinal and P-40 with the SAITO 40 and it worked extremely well on both.
Offline Mike Callas
Re: Saito .40
« Reply #17 on: August 11, 2010, 12:14:03 AM »
Thanks Bob, that's good to know.
I'll report back here after setting the cg.
Offline SteveMoon
    • www.ultrahobbyproducts.com
Re: Saito .40
« Reply #18 on: August 13, 2010, 01:36:12 PM »
Gerald: I used to have a Saito 40 on my Imitation (electric now for
learning purposes) and it had absolutely no problem at all hauling
it around. The Saito 40 is plenty powerful to handle planes with
600+ sq in of wing. The Imitation/Saito 40 is an excellent combo;
go for it.
Later, Steve
Re: Saito .40
« Reply #19 on: August 23, 2010, 10:19:26 PM »
Steve,
Thanks for the feedback, sorry to take so long to get back in here. Our computer got a bug and really messed things up. But we are good to go for now. Do you still carry the Imitation kit?  Price?
Gerald Schamp
geraldschamp@comcast.net
Offline Mike Callas
Re: Saito .40
« Reply #20 on: August 28, 2010, 03:19:51 PM »
Change of plans on the TF Nobler Saito combo.
I put the Saito 40 in a Pathfinder ARF. 55" wing 620" area. 11.3X6.5 TT prop, 20/20 fuel.  Clunk tank with muffler pressure. Spray bar hole opened up to .046" and I removed the venturi insert.
Open venturi RPM ~ 8800. I choked it down to ~8400 rpm. With an APC 11X6 it turns 9300 rpm unchoked..
On 61' lines it turns laps at ~6 sec (TT prop launch at 8300 rpm), 2oz of fuel lasts 4:30 min.
Right now I'm flying straight and level. It's a bit windy and the motor only has ~1 hr so it probably needs some more break-in time and calm winds.
Seems like I should be using more fuel and going slightly faster, but this is a big plane for a 40 4S.
Offline Greg L Bahrman
Re: Saito .40
« Reply #21 on: August 28, 2010, 04:12:14 PM »
Mike,
(Seems like I should be using more fuel and going slightly faster, but this is a big plane for a 40 4S.)
Not to worry, As the motor gets broke in it will increase in power and tend to use less fuel. I used an 11 x 7 on mine per Bob Reeves and was happy with it.
Lou
« Last Edit: August 30, 2010, 01:41:45 PM by Greg L Bahrman »
Greg Bahrman, AMA 312522
Simi Valley, Ca.
Offline Bob Reeves
Re: Saito .40
« Reply #22 on: August 28, 2010, 05:07:38 PM »
Sounds like you are in the ballpark, I would shorten the lines a couple feet before messing with the prop or RPM. It might need to turn the TT prop a little faster to overcome the drag of the airframe. I would try for 5.3-5.4 lap times.
Your not out of the ballpark with your fuel consumption, now that I discovered a Sullivan 4 ounce slant only holds 3 1/2 ounces I figure I only use about 3 ounces for 6 minutes.
Offline Mike Callas
Re: Saito .40
« Reply #23 on: August 28, 2010, 05:58:14 PM »
Hi Lou, Hi Bob,
Thanks for the feedback. I've been reading all the posts I can get my computer to pull up.
I'll wait for the wind to calm down and actually time multiple laps with a watch for an average.
I leave the setup alone and see if the motor comes up alittle with more run time.
Mike (the newbie stunt plane killer)
Offline Mike Callas
Re: Saito .40
« Reply #24 on: August 29, 2010, 06:02:02 PM »
Oops...my bad.
I timed the Pathfinder today and 5 laps in windy conditions took 27s. Thats about 5.4 sec a lap.
I can only guess that the difference between flying the plane and counting off 1 mississippi...2 mississippi.... vs watching the plane in my lawn chair using a stop watch is another confirmation of Einstein's theory of relativity. Or, the stop watch is more accurate.
Naw! You can't buck the laws of physics.
The Saito 40 was spinning faster on the last couple of flights today than yesterday. I choked off the motor back down to 8500 rpm. Must be the motor breaking in as Lou suggested.
I had an experienced Valley Circle Burner fly the plane and he really liked the consistency of the Saito throught the flight.
