  • July 18, 2025, 07:08:22 PM
Author Topic: enya 40 open rockers  (Read 6796 times)
Offline Joe Hunt
« on: September 15, 2019, 07:34:49 AM »
a friend of mine just acquired from an attic find a new old ,I assume, open rocker enya 40. for a favor I can acquire it and was just wondering if anyone had any experience with this engine.  thanks, joe hunt
Re: enya 40 open rockers
« Reply #1 on: September 15, 2019, 11:07:33 PM »
For a favor, do it.
1) He's a friend, so why need anything in return for a favor.
2) It's a four stroke for practically nothing.
3) You can always re-sell it.
Mark
Offline Robert Zambelli
« Reply #2 on: September 15, 2019, 11:27:19 PM »
Joe: I have a few of the open rocker ENYA engines (35 and 40).
Although a bit heavy, they are remarkably smooth and quiet, also very easy starting.
I would not hesitate to run the 40 on any 40-size plane - you will just have to shorten the nose a bit.
The Brodak/Johnson P-40 would be the perfect candidate!
I run mine on Brodak 10/23 or Powermaster 10/22.
Before you run the engine, pump some oil into the crankcase and tilt the engine around to insure that all internal parts are lubricated. The excess will blow out through the breather.
Some oil on the rockers can't hurt.
These engines turn at a moderate RPM but develop substantial torque. 11-6 and 11-8 props work well on the 40.
ps - SAITO also made a neat little open rocker 30!
Offline Joe Hunt
« Reply #3 on: September 16, 2019, 05:18:08 AM »
bob, thanks, joe
