  • July 31, 2025, 09:29:49 AM
Author Topic: Props for Saito 40 (Link)  (Read 15148 times)
Offline Bob Reeves
    • Somethin'Xtra Inc.
« on: June 30, 2009, 09:42:48 AM »
As some of you that have been following my Saito 40 posts know, I've been looking for a readily available prop to replace the Rev-Up 11-7's I have had such good luck with.. Well I found it.. The Thunder Tiger 11.3 X 6.5 works great.. This is the prop I was flying on the purple and white profile Shoestring at Brodaks. I didn't fly worth a hoot but the engine and airplane preformed perfectly. If you are looking for Saito 40 props this one is worth ordering...
http://www.thundertiger4u.com/cyclone-prop113-p-7666.html
Update on the TT props..
Seems as though the 11.3 X 6.5 has been back ordered for a while but are now back in stock. You can buy them two ways, single or in a package of 6.. They have also revamped the web site and the above link no longer works..
Single
https://www.thundertiger4u.com/store/comersus_viewItem.asp?idProduct=3269
6 pack
https://www.thundertiger4u.com/store/comersus_viewItem.asp?idProduct=3286
« Last Edit: August 05, 2009, 02:34:12 AM by Bob Reeves »
Offline Martin Quartim
    • StuntHobby
Re: Props for Saito 40 (Link)
« Reply #1 on: June 30, 2009, 05:40:07 PM »
Hi Bob,
Have you tried a TopFlite Power Point 12x6?
Martin
Offline Bob Reeves
« Reply #2 on: June 30, 2009, 05:51:52 PM »
Hi Bob,
Martin
Nope, most everything I have had a 40 on didn't have clearance for a 12 so everything I tried was an 11. The PP's I did try didn't have the vertical getty-up I was getting with a Rev-up. At first I thought the new Evolution 11-7 was going to work then I tried the Thunder Tiger and have pretty much decided I can quit looking.
Offline Ralph Wenzel (d)
« Reply #3 on: July 01, 2009, 05:51:44 AM »
Just lazy, I guess, but the APC 11-7 worked so well on my Saito .40 that I never bothered to search for something better . . .
Ralph Wenzel
AMA 495785 League City, TX
« Reply #4 on: July 04, 2009, 10:16:59 AM »
Bob, have you ever tried any of the Master Airscrew Wood props.  Those that I tried in 10-6 and 11-5 range seemed to have a wider blade than any Top FLite's I have.    That 9-7 on my little OS is pulling the Cardinette with a lot of authority.  Thanks,  DOC Holliday
