Engine basics => Four strokes only => Topic started by: Colin McRae on May 03, 2025, 12:13:06 PM
Title: OS 40 Surpass FS vs Saito FA-40a
Post by: Colin McRae on May 03, 2025, 12:13:06 PM
I have both of these engines NIB and plan to use a 40 size FS on a future CL stunt/sport build. Probably a profile warbird model. For those that have direct experience with these engines, which one is considered to be more powerful? If I was guessing at this point, the warbird model will weigh in the neighborhood of 48 oz, with a wing loading around 14.
The Saito FA-40a is interesting as it is a full 2 oz lighter that the OS 40 Surpass FS.
Thanks in advance.
Title: Re: OS 40 Surpass FS vs Saito FA-40a
Post by: Martin Quartim on May 06, 2025, 05:54:02 PM
https://www.youtube.com/watch?v=Wiyo8TrI6Nc
Post by: Mike Alimov on May 22, 2025, 05:39:08 PM
I don't have the Surpass 40, but the Saito FA-40a is a lovely engine, very impressive power! Comparable or better than most 46-size two strokers. You are a lucky guy!
Post by: Dennis Toth on May 23, 2025, 10:47:55 AM
Saito 40 is 2oz lighter, go with that. At a wing load of 14 you need to save all the weight you can. If you need more power adjust the prop and nitro. The 40 will turn a wide blade BBY&O 11x5 at a good rpm (could tweak to a 5 1/2" or go to a 6" pitch and trim diameter to 10 3/4'). For nitro, 10 - 15% is a good starting point and could go up to 20%.
Best,   DennisT
Post by: Robert Zambelli on May 23, 2025, 03:43:38 PM
I have/had three of each.
The SAITO 40 is a wonderful piece of engineering, perfect for our needs.
I consider the Supass 40s, on the other hand, to be "Reverse Excedrin"* engines.
Of the three I HAD, the performance was  nowhere near that of the SAITO.
Each one was carefully broken in EXACTLY according to OS instructions.
Inconsistent runs, broken crank pin, difficult starting, etc.
One of my close friends had one with which he experienced similar issues.
I've owned over 100 4 cycle engines including ENYA, OS, SAITO, WEBRA and HP and Morton.
I still have well over 60.
In defense of the OS, I've owned every one from the 20 up to the 70 and the only one that had issues was the Surpass 40.
*doesn't cure headaches, it causes them!
