  • August 01, 2025, 08:53:55 AM
Author Topic: The Overhead Valve is just a Passing Phase .  (Read 6329 times)
« on: November 13, 2020, 05:30:58 PM »
o.k.
Anybody seen a SIDEVALVE around 8 to 15 cc that might be adaptable to control line ?
Maybe the power characteristics could be usefull , they wernt entirely hopeless .
Offline Oldenginerod
Re: The Overhead Valve is just a Passing Phase .
« Reply #1 on: November 13, 2020, 07:42:49 PM »
I found this.
http://modelenginenews.org/cardfile/vega30.html
Sorry, can't figure out posting a picture.   :!
« Reply #2 on: November 14, 2020, 07:23:57 PM »
Thanks , this just popped up , http://www.modelenginemaker.com/index.php?topic=3573.0 , and theres a old pommy inline twin , marine. kit available
http://www.modelenginenews.org/etw/seagull/index.html
But there must be a weedeater or some resonably light comercial thing about , everything used to be ' sideys ' once . Maybe its all two stroke or o.h.v. these days .
Thinking the ' shortness ' , same as a two stroke - with the valves adjacent the cylinder , means a big square finned thing would cowl easy .
And hopeing the ' flat power band ' would be applicable , for F2B .  :-\
And theres these ' drone ' engines, https://www.d-motor.eu/ . but 125 Hp might be a bit to much .  >:(
« Last Edit: November 14, 2020, 07:41:35 PM by Air Ministry . »
