  • July 30, 2025, 12:40:31 PM
Author Topic: Magnum .52a  (Read 3368 times)
Offline David Zwolak
Magnum .52a
« on: April 13, 2025, 05:05:08 PM »
Anyone have any experience or thoughts on the Magnum 52a four-stroke for stunt use?
Thanks - David
Online Robert Zambelli
Re: Magnum .52a
« Reply #1 on: April 15, 2025, 07:55:22 AM »
Dave - a few guys in the Philly Flyers tried the first version of the Magnum 52 around 20 years ago.
It appeared to be a copy of the OS Surpass 52.
It ran well, very smooth but not quite up to the power of the OS. I tried and compared the two of them on the Polaris and the power difference was noticeable.
However, the Magnum had very little run time so it may not have been fully broken in.
I have a Magnum 30 4S and it makes very good power.
If yours is a 52A, there may been some performance improvements.
Best to put some run time on it and then try it on a plane.
Re: Magnum .52a
« Reply #2 on: April 18, 2025, 05:54:59 PM »
Hi Bob
Excellent.  Thanks for the good advice as always.  I will put some flight time on mine and see how it does.  I hope to see you at Brodaks.
Cheerio
David
Re: Magnum .52a
« Reply #3 on: April 19, 2025, 01:05:53 PM »
Hope it works out for you.
Regarding Brodak’s, I’ll be there!!!
Re: Magnum .52a
« Reply #4 on: April 19, 2025, 01:09:34 PM »
I forgot to mention, after an hour or so of run time, check the valve lash - as I recall it’s .002 but you might want to double check.
Re: Magnum .52a
« Reply #5 on: April 20, 2025, 06:54:58 PM »
Will do.  Will do.  Thanks for the valve lash target spec number.  See you soon.
Cheers
DZ
