CLICK HERE--><--CLICK HERE
Plane size range for Saito 40
Started by Mike Bush, July 01, 2026, 05:30:52 AM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Mike Bush
Good Morning,
To those of you that have used a Saito 40. What would be the plane size range in sq in to be powered by a saito 40 ?
Colin McRae
#1
I have used the Saito FA-40 on a Brodak P40 ARF (53" wing, 560 sqin, 55 oz). On my P40, I use an APC 11-6 sport prop at 9,200 rpm on the ground (about 300 rpm below peak to keep it slightly rich). And I run VP 15% AIR fuel, with a little Klotz KL-198 lite syn added to boost the total oil from 18% to 20%.
And seen a Saito 40 on a profile Pathfinder (55" wing, 620 sqin, not sure of the model weight), and also an OS 40 Surpass on a TF Doctor.
Colin
Like Like x 1 View List
