  • July 31, 2025, 11:24:13 AM
Author Topic: FA 40 versions?  (Read 7460 times)
Offline Terry Caron
FA 40 versions?
« on: December 07, 2015, 08:03:17 PM »
How many versions have there been of the enclosed rocker FA 40?
Where does this one fit and how does it compare to other versions?
Thanks.
Terry
NACA member, Huntsville, AL
AMA 249824
NRA Life Member
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: FA 40 versions?
« Reply #1 on: December 08, 2015, 02:55:50 AM »
I would guess there has only been two versions, the current version is designated FA-40A and looks like the one you have may be an early engine.
Google found this thread on an RC forum with a few links but only thing I could find following the links was the 40 was produced between 1980 and 1989. Didn't see anything that said when the 40A was introduced.
http://www.rcgroups.com/forums/showthread.php?t=2360061
This post shows a photo of an early 40 next to a later 40, big difference in size but not exactly sure if the 40 you have is the larger engine.
http://www.rcuniverse.com/forum/glow-engines-114/9315616-saito-history-2.html
Doubt anyone has any first hand CL experience with the early 40, my first Saito was a 40A.
Offline Terry Caron
Re: FA 40 versions?
« Reply #2 on: December 08, 2015, 08:29:03 AM »
Thanks for the links and info, Bob.
Mine does look like the older, larger one pictured.
I also found this pic, which is another older version - note the intake difference from mine.
The box is stamped "Mk II", so I'm thinking I probably have a Mk I from the early '80s.
Terry
UPDATE: A Chinn review on Sceptreflight of the original open rocker FA 40 notes it as being the Mk I, so maybe there were 2 variants of the enclosed rocker Mk II?
« Last Edit: December 08, 2015, 09:55:33 AM by Terry Caron »
AMA 249824
NRA Life Member
Offline Bob Reeves
Re: FA 40 versions?
« Reply #3 on: December 08, 2015, 10:21:46 AM »
Just from the pictures it looks like the early 40's are close to the same size and probably weight of a modern 56 but with less power than a 40A. Doubt it would be worth the effort to try and fly with it but would look nice for a display engine.
Offline Terry Caron
Re: FA 40 versions?
« Reply #4 on: December 08, 2015, 10:28:41 AM »
Not a prob as I've no plans to fly it anyhoo, I got it just to have a 4-stroke for bench-run fun.
FWIW - Note mine has "SAITO"  cast into crankcase not cylinder base; head/valve covers are different.
Also, not visible, but mine has "FA" cast but "40" stamped into lower case; 2nd engine has "FA 40" cast into cylinder base.
Examination of the Chinn review pix shows the MK I has "SAITO" and "FA 40" cast into cylinder base.
Wonder if mine could be pre-production?
Terry.
« Last Edit: December 08, 2015, 11:26:24 AM by Terry Caron »
AMA 249824
NRA Life Member
Offline Dane Martin
  • heli pilot BHOR
Re: FA 40 versions?
« Reply #5 on: December 08, 2015, 02:07:19 PM »
I had an FA series 40 that looked like that. Not super power, but very strong and dependable. I flew it in a 72" rc piper cub.
I had an FA series 65 also. Ara D. ended up with that in a big buzz bomber. Great engines. Heavier than the newer counter parts, but really reliable
« Last Edit: December 08, 2015, 02:44:42 PM by Dane Martin »
Offline Terry Caron
Re: FA 40 versions?
« Reply #6 on: December 08, 2015, 02:17:05 PM »
Still trying to sort it out for my own info, but I found an eBayed NOS cylinder marked for an FA-40S.
And I found this MK III Hemi-Head, which appears to be the same as mine.
Apparently there were several versions of the MK II series.
Are all FA series engines ringed?
Terry
« Last Edit: December 08, 2015, 03:56:46 PM by Terry Caron »
AMA 249824
NRA Life Member
Online Robert Zambelli
Re: FA 40 versions?
« Reply #7 on: December 08, 2015, 03:52:22 PM »
Terry - I had three of these and I believe I still have a new one left.
Regarding "HEMI", as far as I know, all the SAITOs have hemi heads.
This particular SAITO was my first 4S engine and it was a very user-friendly and smooth powerplant.
I had it on my Euclid which is a very slightly enlarged Sig Chipmunk.
Throttle wired wide open, no modifications (it would probably have benefitted a bit from Bob Reeves excellent intake modification)
Total weight was around 50 ounces and it would do the entire pattern with no problems.
I did win a few firsts in intermediate and advanced.
The fuel that worked best was 20% nitro, 50/50 castor/synthetic, 11-8 Master Airscrew prop.
If you use it, make sure it has plenty of cooling air as it tends to run a bit hot. Also, make sure it breathes outside air - it likes cool intake air.
It met its demise when I belled it in in the bottom of the hourglass. When the engine hit, it tore the lugs off the case!
It's a good engine - give it a try.
Offline Terry Caron
Re: FA 40 versions?
« Reply #8 on: December 08, 2015, 04:03:03 PM »
Thanks for the reply, Bob.
I do have a rebuildable Cardinal and Pathfinder which might be suitable, so flying it isn't out of possibility.
No problem w/castor gumming or build-up?
I think Bob Reeves cautions against castor.
Terry
AMA 249824
NRA Life Member
Re: FA 40 versions?
« Reply #9 on: December 08, 2015, 07:22:20 PM »
Terry - the SAITO 40 should work well on the Cardinal or Pathfinder.
I also had mine on a Brodak P-40  and it was a great combination. It's a bit heavy so I pushed it back around 1 1/4 inches.
When I used the castor/synthetic blend, that was around fifteen years ago.
I have never had a 4S engine gum up but I have heard from numerous sources that it's better to use a higher synthetic content (maybe 18/2) as the small amount of castor will proved good long-term corrosion protection.
Offline Terry Caron
Re: FA 40 versions?
« Reply #10 on: December 08, 2015, 07:37:07 PM »
Thanks, that accords with what I've read, Bob.
Maybe the Cardinal or Pathfinder will go on the "winter build list".  :)
If the one you still have is a MK III, do you have the manual for it?
Copy, per favore?
Terry
AMA 249824
NRA Life Member
Offline Terry Caron
Re: FA 40 versions?
« Reply #11 on: December 08, 2015, 08:28:37 PM »
With a bit more searching I found these, so I have the information I wanted.
The FA-40 MK III and FA-45 MK II are the same except for displacement.
Thanks to all for your interest and input.
Terry
AMA 249824
NRA Life Member
Offline Terry Caron
Re: FA 40 versions?
« Reply #12 on: December 13, 2015, 10:52:59 PM »
A further note -
There is also an FA-40S (maybe not sold in the U.S.) that's basically the FA-40 MK 3 with a high-lift cam, reportedly adds ~1K rpm.
Turns out it's a fairly simple upgrade, basically replacing 2 parts.
Parts available here:
http://www.horizonhobby.com/cam-gear-housing%3Ab-d-e-aa-ii-jj-sai5033a
And here:
http://www.horizonhobby.com/cam-gear-right%3Ab-df-r-s-aa-iijjkk-sai5035
Other sizes were available in an S version and upgrades on non-S versions of those sizes are likely as simple.
Terry
AMA 249824
NRA Life Member
