  • August 01, 2025, 08:43:50 PM
Author Topic: Enya 53-4c Reverse Rotation  (Read 8219 times)
Offline Martin Quartim
    • StuntHobby
« on: December 18, 2009, 09:27:11 PM »
I have an Enya 53 4C but haven't had the chance to try it. Hopefully next year it will power a T-REX.
I found this link that shows how to set the Enya 53-4C for reverse rotation that I thought you guys would like to see:
http://www.modelrectifier.com/resources/rcModelEngines/EnyaRevRot.pdf
Looks pretty easy to do.
If some one have been using one I'd appreciate some info about it.
Martin
Offline PatRobinson
Re: Enya 53-4c Reverse Rotation
« Reply #1 on: December 21, 2009, 01:33:29 PM »
Hi Martin,
Just out of curosity, is the purpose of reversing the rotation to allow you to use pusher props like the electric guys use, or is the purpose to use in a twin engine application? Just wondering?
        Merry Christmas,
        Pat Robinson
    • StuntHobby
« Reply #2 on: December 21, 2009, 05:55:39 PM »
Merry Christamas to you too Pat !
well one could use for a twin, it would be a bit heavy for my arms. I plan to try this one in a T-REX next year. APC and Zinger has Pusher 13x6 that should work well with it.
Martin
Offline Mike Scholtes
« Reply #3 on: December 23, 2009, 10:05:02 PM »
Hi Martin:
No matter what way you run it, you will love this engine. I had one in RC use for years and it is one  of the sweetest, most user-friendly engines I have owned. It would idle down to almost nothing and then take full throttle without a hiccup. I still regret selling it to a flying pal. I am a real fan of Enya engines, as you know. Amazingly reliable. Mine had the original Enya plug still in it when I finally sold it.
Willis Swindell
« Reply #4 on: January 03, 2010, 12:42:57 PM »
I am wondering if there is any where you can buy a Enya 53 at a discount? The last time I went looking for a Enya 53 4S I wound up buying a RCV 58. Our local HS has a control line Enya 53 but it’s way over three hundred dollars. I was hoping to find one in the two hundred dollar plus range.
Willis  HB~>
« Last Edit: January 04, 2010, 02:07:39 PM by Willis Swindell »
Offline Robert Zambelli
« Reply #5 on: January 06, 2010, 05:50:01 AM »
Willis - I may have one for sale.
Call me.
Offline Ron Merrill
« Reply #6 on: January 06, 2010, 08:47:57 AM »
Willis, If Bob Z. doesn't work out, try Randy at Aero Products, his sell for around $290.00. Ron.
Willis Swindell
« Reply #7 on: January 07, 2010, 05:54:03 PM »
Thanks everyone for the information, especially Bob.
Willis
