  • August 01, 2025, 08:49:36 PM
Author Topic: JXF Pusher Props for Counter Clock use Enya 53-4C and Saito 62  (Read 4023 times)
Offline Martin Quartim
    • StuntHobby
I have posted before about reversing the Enya 53-4c and the Saito 62 and now I am please to report that my favorite prop for 4S will be soon available. The  JXF 13x6 and 14x6 pusher props should work amazingly well with the Enya 53-4C and Saito 62 in reverse mode.
13x6 Pusher Prop:
http://www.himodel.com/plane/JXF_13x6_inch_Beechwood_Propeller_for_Electric_Airpalne_Counter_Rotating.html
(fwiw, jxf electric props has been contest proven down here by most of us that use 4S, including  Brazilian Champ Bene Rodrigues)
Or there is the regular prop for glow, but by far not as efficient as the electric ones.
http://www.himodel.com/plane/JXF_13x6_inch_Beechwood_Propeller_Counter_Rotating.html
Martin
Offline Robert Zambelli
Re: JXF Pusher Props for Counter Clock use Enya 53-4C and Saito 62
« Reply #1 on: June 01, 2010, 04:58:04 AM »
Martin - I know that you can retime the ENYA cams for CW rotation but how do you do it on the SAITO?
    • StuntHobby
« Reply #2 on: June 01, 2010, 06:43:03 AM »
Hi BobZ.
I think you missed my earlier post about that
http://stunthanger.com/smf/index.php?topic=15952.0
I hope the Saito Reverse CAM part still available and that it works as the R/C guy suggests, unfortunatelly it works only for the Saito 62, so they say.
Martin
« Reply #3 on: June 01, 2010, 09:22:01 AM »
Thanks, Martin - I somehow missed that post.   n~ n~
    • StuntHobby
« Reply #4 on: June 01, 2010, 04:37:52 PM »
Can any of you guys call Horizon and see if this cam gear
http://www.horizonhobby.com/Products/Default.aspx?ProdID=SAI200TI35
will really work on the Saito 62 to reverse the engine?
In my understanding if it works in the 62 it should also work for the 72 since the Cam Gear P/N is the same 6535A  Item 35 of the part list.
Martin
