  • August 01, 2025, 06:44:28 AM
Author Topic: Engine Break-in Saito CL's  (Read 2752 times)
« on: December 20, 2010, 01:57:53 PM »
As you guys know, you have to keep the Saito's under 3000 RPM's for the first break-in runs. Has anyone experienced problems getting the RPM's down with the CL carb models?
Re: Engine Break-in Saito CL's
« Reply #1 on: December 20, 2010, 02:26:57 PM »
I had to keep my finger in the venturi to slow it down and watch the tach to make sure its at around 3000rpm. It is of course much easier if you have a R/C carb to put on for the break in.  H^^
