  • August 01, 2025, 08:13:10 PM
Author Topic: O.S. 30 reverse rotation?  (Read 2560 times)
« on: January 17, 2012, 09:10:11 PM »
 Does anyone here know of parts available to make an O.S. 30 run in reverse rotation? A friend of mine has a certain twin with which he would like to tame down some of the torque effect in the model by running the outboard engine in reverse. Any ideas?
Offline rustler
Re: O.S. 30 reverse rotation?
« Reply #1 on: January 18, 2012, 02:31:39 PM »
I've no idea if it's possible with O.S., but there was a Brit. 4Str. which could be reversed by swapping the pushrods over, i.e. the one which controlled the inlet -> to the exhaust, and vice versa. May have been the Magnum?
Ian Russell.
Offline Mike Callas
« Reply #2 on: January 18, 2012, 08:54:02 PM »
Cool looking plane. Is that scratch built? Was that plane ever flown off a carrier deck?
As you probably have seen, there is a post that covers reverse rotation on the 62 and 56. It appears there is no reverse cam for the 40. If there is a reverse cam it might be in the Horizon Hobby website.
Good luck
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #3 on: January 19, 2012, 03:25:59 AM »
I really can't help as I don't have any experience with OS four strokes. Reason we were able to reverse Saitos is because Saito makes a twin using the 56/62 cylinders. Martin did the research to discover the cam for the 2nd cylinder can be used in a single to make it run the other way. Does OS make a twin using the 30 cylinders? If so you may be in luck if not, guessing it will be more trouble than it's probably worth.
