Engine basics => Four strokes only => Topic started by: Mark Mc on August 15, 2020, 09:35:48 PM
Title: Breaking in a new .26 Surpass?
Post by: Mark Mc on August 15, 2020, 09:35:48 PM
I just bought this new O.S. .26 Surpass from Mike Hazel's latest Flying Lines listing.  As you can see, it has the Zambelli type venturi mod.  It's going into either a Flight Streak or a Brodak ARF Ringmaster.  I am going to be using Powermaster YS/Saito 20/20 to run it.  From a quick browse through past threads in this section, I'm gonna try a MA 9x6 first, then maybe an APC 9x6 to see how it likes them.  The engine did not come with the instruction sheet covering the break-in procedure, though I'm not sure I could have followed it anyway with the CL conversion done already.  What would be the best method for doing a break in as it is now?
(https://i.postimg.cc/sgmP5WQB/OS-Surpass-26.jpg) (https://postimages.org/)
Mark
Title: Re: Breaking in a new .26 Surpass?
Post by: Robert Zambelli on August 24, 2020, 04:26:59 PM
Hi, Mark.
I've broken in around ten of these engines, both the R/C version and those on which I did my venturi conversion.
9-4 or 9-6 props seem to work fine.
I run them a bit rich for 5 to 10 minutes at a time, allowing them to cool between runs.
They will usually be ready to fly after around 4 or 5 runs.
I was originally using 10% nitro, 22% 50/50 castor/synthetic but I switched to 20% nitro, 20% synthetic with a few ounces of castor oil per gallon.
Never had a problem.
Hope this helps.
Post by: Mark Mc on August 24, 2020, 10:01:26 PM
Okay, thanks, Bob.  I'll break it in tomorrow.  I was planning on doing some bench running anyway.  I'm sure I have the right props.
Thank You,
Mark
