  • June 19, 2025, 10:53:51 PM
Author Topic: Saito FA-30S vs FA-30SH  (Read 2970 times)
Offline Martin Quartim
    • StuntHobby
« on: April 20, 2025, 08:15:06 PM »
Good day fellows!
Does any one knows what is the difference between Saito FA-30S and FA-30SH?
What this "H" means?  Higher Compression Head, High Cam, Heli .....
I have a Saito FA-30S and it says on the box "Hemi Head", so the "H" is not about  Hemi Head.
I search the web and AI and I could not find anything.
Martin
Offline Robert Zambelli
Re: Saito FA-30S vs FA-30SH
« Reply #1 on: April 21, 2025, 11:54:59 AM »
Martin: I have a bunch of SAITO 30s but I’ve never seen or heard of a 30 SH.
Offline Colin McRae
  • Are we having fun yet??
« Reply #2 on: April 21, 2025, 12:25:49 PM »
I have a NIB Saito FA-30S. AAC design.
The box says hemi-head, but it also says 'High-Powered High Cam Series'
Maybe the H means the high cam series, but I don't know the different cam designs that Saito offers.
It would have to mean the cam design opens the valves higher and for a longer duration increasing fuel and air for more power.
« Last Edit: April 21, 2025, 06:07:21 PM by Colin McRae »
« Reply #3 on: April 21, 2025, 02:10:29 PM »
They also made a “knight “ series.
Black case, gold rocker covers.
    • StuntHobby
« Reply #4 on: April 21, 2025, 07:20:38 PM »
I have seen these 3 different Boxes of Saito FA-30
FA-30S
https://www.ebay.com/itm/156630241704
FA-30S with an H label
https://www.ebay.com/itm/316644089267
FA-30SH
https://www.ebay.com/itm/376100345739
So far I could not find if there is any performance or mechanical differences.
Martin
« Last Edit: May 06, 2025, 06:01:00 PM by Martin Quartim »
Offline Colin McRae
« Reply #5 on: May 04, 2025, 10:49:18 AM »
Hi Martin, I came across some more info this morning.
I picked up a new Saito FA-40a and was reading thru the owner's manual. The manual is a generic one that covers Saito engines 30-125 sizes.
The manual specifically calls out the FA-30S(H) and different instructions for setting the low-speed needle on the 'air bleed' type carb.
So, it sounds to me like the H engine uses a different type of carb compared to the other engines covered in the manual. Maybe that's what the H designation means. Just a different carb setup?
    • StuntHobby
« Reply #6 on: May 04, 2025, 09:03:01 PM »
Interesting find my friend
Now the question is what is different about the carb, if it has a larger intake opening it will deliver more power!
Do you guys run the Saito 30 with the rc carb lock or with a custom made venturi?
I  have a Nobler ARF collecting dust here and I am thinking  to built it and use Saito 30 just for fun.
Martin
Offline Colin McRae
« Reply #7 on: May 05, 2025, 10:44:55 AM »
Martin
I don't believe there is a difference in the carb opening size. The low speed (idle speed) adjustment on an air-bleed type carb is different than a typical 2-needle carb. The low-speed needle adjusts the fuel flow at idle speed, and the air bleed screw is just the opposite and adjusts the amount of air at idle. Both methods can richen or lean the mixture at idle speed.
In any event, one does not really need to bother with the idle speed adjustment on a FS used for CL stunt or sport, but it might be used for 3-line scale with throttle control.
Most modelers here simply wire the carb throttle fully open for CL. Some do try to use a venturi. Four-strokes are all about fuel draw or lack thereof. Larger FS's can use a fuel pump system, but the smaller size engines don't have pumps and seem fine on suction alone. And muffler pressure can be used to enhance fuel draw if needed. Others may have specific experience on the Saito 30 in a CL application.
My only experience so far is an OS 26 Surpass FS on a 40" wing Brodak Yak-9 OTS warbird model. I just use the stock carb wide open, but I use a specific setup so I can start the engine at 1/3 throttle, let the engine warm up a bit, then readjust to full speed just before launch. I find that the OS 26 starts a bit easier at 1/3 throttle. Plus, IMO allowing for a brief warm-up is not a bad idea for a FS with all the moving parts. I simply removed the carb throttle lever and inserted a small gear. The gear teeth come into contact with the Surpass choke rod to hold the throttle at a specific setting. This is specific to the OS 26 and 40 Surpass engines that have the choke rod feature.
I'm not sure a Saito 30 FS will be powerful enough for a Nobler ARF. Maybe if you boost the nitro to 20%. I'm running the new Enya SS 35 EX on a Nobler ARF and APC 10-5 sport prop. Great combination as the engine is very light.
In any event I really like the OS 26 FS and how it runs in a CL application. So much so that I am planning to use a larger 40 size FS on a future model, either a Saito FA-40a or OS 40 Surpass. I'm leaning towards the Saito FA-40a as it is a full 2 oz lighter than the 40 Surpass.  On my Yak-9 the OS 26 runs absolutely constant rpm in the air no matter what maneuver I am doing. Plus, the added benefit of 1/2 the fuel use compared to a similar size 2-stroke. And that can be important with nitro fuels being a minimum of $40 US per gallon.
« Last Edit: May 06, 2025, 05:00:06 PM by Colin McRae »
    • StuntHobby
« Reply #8 on: May 06, 2025, 05:50:57 PM »
The Enya SS35E  would be a better choice but I am doing for the fun of it and experiment with the Saito 30.
I only use 20/20 with 4S engines, hopefully all will work out fine.
Still curious about the difference in the "H" engine. I may have to get a SH just to see for my self  HB~> HB~> HB~> (engine fanatic)
I tested a Saito 40 with my old and beat up Pathfinder ARF (620 sq. win.).   20/20 fuel and a JXF 12x6 wood electric prop.  I have no experience with the OS 40, but I am willing to bet the Saito will beat it power wise too, plus still in production.
I got my Saito 40 used from a fellow in this forum, can´t remember the name now, with RC carb with the Bon Reeves nylon bolt adaptation. Plenty of power, but something was making the rpm(power) vary a bit. Not sure if it was my tank or the carb mod that was leaking air with vibration, or perhaps something more serious about the engine with valve not properly seated.
Martin
« Reply #9 on: May 17, 2025, 12:25:55 PM »
    That was an issue back in the 4-stroke era, and it was always eventually traced to small air leaks or small changes in the "throttle" setting. The stock carbs were pretty hopeless, and the solution (as discovered by Ted Fancher in the mid-80s) was to sleeve the carb barrel with a short length of tubing to remove any throttling effect and obviate any leaks around the barrel. The Berringer-style carb (which Bob Reeves brilliantly figured out how to implement with minimal machining) is much less prone to the issue, the venturi system from Steve Moon is entirely immune to it.
   In the few cases people had this issue with the Berringer-style carbs, it got fixed by sealing it somehow (silicone sealant or in one case, inadvisably, heavy silicone vacuum grease).
    • StuntHobby
« Reply #10 on: May 17, 2025, 09:58:06 PM »
People have problems with all kinds of engines, even electric ones.
Eventually I will  build something for this engine and make my own design venturi.
Martin
