  • June 22, 2025, 02:07:13 AM
Author Topic: My Saito .40 - Worn ring?  (Read 3221 times)
Offline Terry Caron
« on: May 21, 2016, 03:01:48 PM »
My Saito .40 turns a 12-4 APC at 9.5K on 15/65/20 fuel, which seems low.
This is very subjective but, turning a prop slowly by hand, there doesn't seem much compression.
Do 4-S normally feel "soft" or is it likely I have a worn ring?
Terry
NACA member, Huntsville, AL
AMA 249824
NRA Life Member
Offline Robert Zambelli
Re: My Saito .40 - Worn ring?
« Reply #1 on: May 21, 2016, 04:07:27 PM »
Nothing to worry about.
I've got around 20 SAITO engines and they all will occasionally behave like that.
It's normal to have some leakage past the ring - that's how the bearings and valve gear get lubricated.
And, I've never had to replace a ring or bearing on a SAITO.
« Reply #2 on: May 25, 2016, 03:03:20 PM »
Terry
Seems low? A 40 turning a 12" prop at 9500 seems pretty darn good to me. You can certainly go flying with that.
Offline Terry Caron
« Reply #3 on: May 25, 2016, 03:10:41 PM »
I appreciate the encouragement, Milton.
It's my first 4-S, the older Mk 3, bought used, so I don't really know what performance to expect.
I'm thinking of a Brodak P-40B, a Pathfinder or Cardinal for it.
Terry
AMA 249824
NRA Life Member
