  • June 15, 2025, 09:26:04 PM
Author Topic: 4 Stroke ignition - gasoline fuel  (Read 8255 times)
« on: October 25, 2013, 10:19:12 AM »
Guys,
I just got a look at the latest Model Aviation and saw a ad for both and OS 40 and Satio 40 4 stroke ignition engines. Has anyone tried running one of these? The systems seem to be a magnetic pickup so oil would not interfere with the spark triggers. It seemed that being able to use reliable ignition for stunt could give us better tuning for max torque when we need it. The use of gasoline (or Coleman fuel) would be about half the amount of regular fuel so any weight for the ignition system could be offset with less fuel weight. Could be interesting.
Best,         DennisT
Re: 4 Stroke ignition - gasoline fuel
« Reply #1 on: October 25, 2013, 10:29:49 AM »
$3.00 a gallon as opposed to $15.00 a gallon for fuel sounds REAL GOOD to me!!
Offline Douglas Ames
« Reply #2 on: October 27, 2013, 04:59:36 PM »
I work with a guy who's very active in R/C. The glow engines are going away - FAST. They are being replaced by Electric and Gas/Ign engines. There's no comparison to the relic ignition engines of your youth and the ignition boxes really don't weigh as much as they look. Keep in mind your tank will about half the capacity. Operational cost is almost a crime - In Tulsa? $2.79/ gal + 2 stroke oil.
You'll see ignition kits on eBay for conversions but the problem is getting enough lube to your rod journal on a traditional glow engine. The dedicated factory gas engines have this taken into account. Gas runs hotter (higher EGT) BTW! Carbon pipes??? (unknown)
FOX is selling a .50 gas engine also, would be neat to try it.
« Last Edit: October 27, 2013, 05:17:53 PM by Douglas Ames »
AMA 656546
« Reply #3 on: October 27, 2013, 05:27:23 PM »
Guys,
Best,         DennisT
They look like they are 40cc not .40 CID. But...Evolution, Fox and others make 9-15cc Gas engines.
AMA 656546
« Reply #4 on: October 27, 2013, 06:36:40 PM »
Offline Chris Wilson
« Reply #5 on: October 27, 2013, 07:57:58 PM »
I know it ain't fourstroke but ...........
http://www.nvengines.com/
MAAA AUS 73427
« Reply #6 on: October 27, 2013, 08:54:44 PM »
I wonder if they are using higher compression to accomplish ignition?
Never heard of running a glow plug with Gasoline.
That silicone tubing is worrisome.
AMA 656546
Offline Martin Quartim
    • StuntHobby
« Reply #7 on: October 30, 2013, 07:25:32 PM »
Enya was the first to introduce a Glow Gas Engine (as far as know)
http://www.enya-engine.com/180XGS_E.html
Martin
« Reply #8 on: November 12, 2013, 09:26:32 AM »
Just because it's ignition doesn't mean you can run gasoline only.
With the smaller engines, in most cases you cannot.
Charles
« Reply #9 on: November 12, 2013, 03:41:22 PM »
Charles
   Why can't you run gas/oil in a small two stroke engine on ignition? Explain please?
    Dan  McEntee
« Reply #10 on: November 12, 2013, 05:48:24 PM »
    Dan  McEntee
Dan,
Sorry, I wasn't clear.
You CAN run gas, with a 20-1 mix, but the engine runs much hotter with that mix, which is not a good thing.
For the best run using the CH Ignition, using nitro will allow for a cooler run with more consistancy in the run time.
I think I got it right.   n~
Charles
« Reply #11 on: November 12, 2013, 07:14:28 PM »
  Well the Arden and Atom .09s ran just fine on gas and oil. I have a synthetic oil I used in my vintage race bikes that I run at close to 100 to 1 and it would probably work fine in smaller engines like that. It's a concentrate, so that allows the higher ratios. Plane old 70wt. motorcycle oil and straight gas or white gas @ 3 to 1 will work just fine also like it always did back in the day. The biggest problem is downsizing the components required so everything fits. Don Hutchinson converted a Magnum .40, I think it was, for ignition and it ran so well, they outlawed it in OTS competition. You just have to know what you want, then know how to go about it during the process. Glow fuel is expensive now, but will moderate some as it always has after each crisis and new fangled fad comes and goes. I'll just stick with what I have and know best and always works.
Online Jim Kraft
« Reply #12 on: November 27, 2013, 06:52:44 PM »
According to Horizons web site instructions for their 60 2 stroke ignition engine, it says to use 2 stroke oil and 87 to 89 octane gas at a 20 to 1 mix. For some reason they say not to use any form of Amsoil ever.
Tags: ignition  gasoline
